Results 1 to 25 of 44
    Apr 2021
    AZ
    Default pain in the a_ _
    Looks like can-am spyder is a pain in the a$$ to work on, need to strip everything down to work on or add accessories!
    Dec 2015
    Oakley Utah
    Gee. Never knew that. Thanks for the heads up.
    2014 RTL Platinum
    Mar 2013
    Maumelle, AR
    Once you "learn" how to remove and reinstall the tupperware, it takes no time at all. Well worth the time and effort to learn.
    2020 RT Limited , Chalk
    Apr 2021
    AZ
    Doesn't make a person want to rush out and buy one! BPR trying to force people to go to shop for work!
    Dec 2015
    Oakley Utah
    Quote Originally Posted by azwiz View Post
    Right you are. And yet....here's a forum of Spyder enthusiasts. Go figure.
    2014 RTL Platinum
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Sell it
    2008 GS.....PE # 2888
    Apr 2021
    AZ
    Quote Originally Posted by Big Arm View Post
    Sell it
    Cant find a sucker, guess I need a bigger hook or maybe a better ear of corn!
    Oct 2020
    Arizona
    Man, I was sure the OP was going to complaint about the seat. I was so wrong! For some unknown reason I enjoy working on my Spyder.
    Nov 2017
    San Francisco Bay area
    Enough. This thread is going nowhere.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Linden, CA
    Welcome to the club
    Feb 2020
    N. Wilkesboro, NC
    The F3s are easier to work on than the RTs due to less tupperware and the 2020+ RTs are easier than the previous years since you don't have remove the mirrors for everything. Still, it's not too bad. I'm mechanically challenged and I've installed all sorts of stuff including the frunk liner which had me completely remove the front end. I don't enjoy working on it but it sure beats $100/hr in shop costs to install something that can take me a few hours.
    Enough--Twice Even.
    Most technical items seem to be built from the inside out. Nothing is easy to work on these days.
    We are very familiar with the Spyder here. They are difficult to work on.
    Nov 2015
    Chardon, OH
    Enough--Twice Even.
    If it’s “enough”, then lock the thread.
    Doug
    ”Freedom is not a loophole”
    Active Member WDAVEY's Avatar
    Jul 2019
    FL in winter, CNY in summer
    Spyders are no worse than newer pickup trucks. On most, it's easier to remove the body from the frame to work on any major engine components like turbos, heads, etc. When they are built a chassis comes down the assembly line with the engine, trans etc already installed. Then a body floats down from the sky and is joined to the frame.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Not coming to Spyders from GoldWings, I guess.
    1976 RD400c
    Oct 2020
    Arizona
    We have a 2020 Edge ST Twin turbo 2.7L V6 and I could not even find a route through the engine compartment to get an extension cord to the battery maintainer, you can not see the ground anywhere in the engine bay. I ended up running out the corner of the hood. Maybe they lift the body off like the Ford PU to service it. I put an oil catch can on it the other day, luckily it was on the top of the engine.
    Durham,Maine
    your not trying hard enough, got a friend just sold his in one day, had six other buyers behind him!!!
    2012 RTL , Pearl
    PA
    Welp I can say this with total confidence and not joking. Go work on an arctic cat, yamahas, Suzuki, Polaris or Honda! BRP has the best fit and finish of all off-road and on road vehicles! Take any of the above apart and the plastic looks like crap once it reassembled! There’s some great videos on YouTube how to take and remove all the plastic. It’s not difficult at all once you do it once.
    We were referring to the attacks on the OP. The discussion matter is fine. The thread could become locked if it goes south again.
    Oct 2020
    Missouri
    1st Spyder here even if it is the wifes bike. 2020 Spyder RTL and I an dreading trying to learn how to change the oil and she is wanting to know if they make turbo kits for them.
    PA
    I don’t know this guy from Adam but I think he has some of the best video explanation on YouTube. Look at his videos and watch, pause, perform, watch, pause and perform. Remove plastic, oil,remove frunk, swaybar, shock adjusters. He’s got it all covered. I’m guessing he’s a member and I don’t know it but I appreciate his time.
    https://www.youtube.com/c/ItsYoursOWNIT/videos
    Northern Kalifornia
    "BRP has the best fit and finish of all off-road and on road vehicles!" Oh Lord, I hope that's not true.
    Aug 2019
    southwest oHIo
    Yes, there is a lot of Tupperware to remove. There are a couple of things to keep in mind to minimize your frustration.
    DON'T add one farkle* at a time. Make a list of all the farkles you wish to add. Think about it for a while before you actually purchase them. When you finally have all the stuff together that you want to add, remove the Tupperware ONE TIME, install the farkles, then re-install the Tupperware. To minimize the mental shock to your body, you might consider separating the job into "front half" and "rear half" of the Spyder.
    However, like others have said, it's not all that bad for some of the routine stuff. You did not mention the year of your Spyder. If it's pre-2020, it seems like you have to remove the mirrors to do anything except check the air pressure in the tires. "Magic Mirrors" are a system of high-power magnets that replace the stock clips. Not exactly cheap, but worth EVERY penny. After that, it's just a few minutes with the right tools, and you can have the bike pretty much naked.
    *FARKLE
    Fancy
    Accessory,
    Relatively
    Kool,
    Likely
    Expensive
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Sebring, FL
    Agree Traveler, nuggets of information and ideas are where you find them.
    SoFlo
    Can Am Spyders are not difficult to work on. Absolutely not difficult.
    They do require additional time to gain access to items, but gaining access or closing bodypanels back up is certainly not difficult.
    There is a slight bit of complexity, but not difficulty, based on Spyders having / sharing current automotive technology. There is nothing difficult about that, simply requires proper knowledge and tools.
    Consider, replacing spark plugs on a Spyder, V Twin or three cylinder. Replacing the actual spark plug is certainly not difficult. The complexity to gain access does require more time to accomplish the task, but correctly done, there is nothing difficult to gain access. Yes, Can Am does state to use a certain thermally conductive paste on the threads. Again, nothing difficult about using that product, simply adds complexity and required knowledge to accomplish the task per the book.
