How do I change my user name and signature? (Solved)
12/20/20, 02:12 PM #2 Woodaddict
you would have to IM Anthony, admin to get it changed
01/18/21, 03:32 PM #2 JayBros
Try this:
Go to Home page.
On top line to the right of your SL name click Settings.
In the left column select Edit Signature.
Edit your signature.
Click Preview Signature.
If it's the way you want it, click Save Signature.
Tried both and neither worked. As you can see, I have been searching for answers.
Coastie
(a.k.a. Newby)
Reason: solved
Coastie
Spider F3-S SS 2021
H-D Tri Glide 2012
Ozzie Ozzie Ozzie
Re your Username change, have you sent AnthonyG a PM? You can do that directly via 'Send new Message' thru Notifications & your Inbox; or you can click on the 'Contact Us' link down the bottom of every page - but in either case you may hafta send your msg then have a little patience, this isn't the only thing he does, so sometimes it might take a day or two...
As for the sig line, what have you tried so far?? The description above is pretty much it in a nutshell, unless you've set something else to tell it NOT to show or maybe you don't save it correctly - altho you may then need to log out & re-enter to see if it's been updated properly?
Just sent the message. I sent it to https://www.spyderlovers.com/forums/...1034-SpyderBOT before because he or it let me join the forum. Maybe he or it is a robot. And AnthonyG has done it before I completed this message.
Read https://www.spyderlovers.com/forums/...181-Rattlebars post first and got signature corrected.
Thanks,
Coastie
Spider F3-S SS 2021
H-D Tri Glide 2012
Welcome from a fellow Coastie. ET1 1965-1969 and Vietnam Veteran(Construction crew/first year crew) Loran C Station Sattahip, Thailand, July 1966-June 1967.
Thanks.
US Army '62 - 66 Germany '64 - '66
US Army '74 - '79 Germany '76 - '79 (8 yrs active)
USCGR '79 - '91 Retired w/20 had to go in as Port Security to keep rank and become a small boat coxswain then lateraled to Boatswain Mate. Loved operating those small boats about 10 weekends and 2 weeks a year. The 2 weeks seemed like a paid vacation after the Army and being away from my civilian desk job. Don't think I would have done the last 12 in Army Reserve or NG.
Coastie
Spider F3-S SS 2021
H-D Tri Glide 2012
