Results 1 to 13 of 13
    Sep 2020
    La Luz, NM
    Default Wide Vu Mirrors Upgrade
    Mounted Wide Vu Mirrors today.
    Took a ride, wow, big improvement .
    Can see to the rear much better than with the stock mirrors.
    Easy upgrade.
    2020 RT-L , Lamonster brake pedal riser Red
    We had them on our two previous RT's. Thinking about adding them to the F3's.
    Nov 2016
    Franklin North Carolina
    where did you get your wide view mirrors
    Sep 2020
    La Luz, NM
    Quote Originally Posted by Doc McCoy View Post
    https://tricledusa.com/products/spyd...pr_seq=uniform
    Active Member Ryan12's Avatar
    Apr 2017
    Wichita, Kansas
    I just bought a set for my 2020 RT and at first they were great but they keep coming loose. The edge isn't deep enough to completely cover the stock mirror and is a super tight fit and keep popping loose. Do they not test their product before they sell them?
    Sebring, FL
    Thanks Ryan, was thinking about some wide views, now thinking I'll wait a while.
    Aug 2012
    Central Coast, CA
    I had these on my 2014RT and was super pleased with them, so I bought a set for my 2020RT. Again, super pleased with the results. No negative issues for me, only positive so far. Honestly, these are the mirror lens that should come from the factory.
    2020 RTL SE6
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    I have them and like them a lot .... but one of my mirrors did start to vibrate and come loose after a couple seasons. So I pealed the mirror off and put a new piece of 3M a double sided foam tape back on the mirror and stuck it back on the bike. Good as new, at least for now.
    P.W
    2019 Phoenix Orange RTL
    LED head lights, LED fog lights, Lidlocks, Brake light kit, Sway Bar, J&S Jack, Cat Delete, Akrapovic silencer, Idler pulley Kit, Gold Drain Plugs, Magic Mirrors, Bumpskid, Tires, Centermatic balancers, Wick-it Stage 1 tune, Convex mirrors, EBC Brake Pads, EBC brake Rotors, Speed Bleeders, M-2 Custom Shocks, Odyssey Battery, Tinted Windshield, Windshield Arm, Gps Ultimate Seat, Dual air Horns, Modesta BC05 Ceramic Coating, Redline 10w40 motorcycle oil, BRP Passenger arm rest, BRP hitch, Syderpop rock guard 2015 Freedom Trailer
    Dec 2018
    Long Island
    Quote Originally Posted by Ryan12 View Post
    I would contact TricLED and fully explain your problem. They are excellent at responding to customers and providing resolutions to their problems.
    Apr 2017
    Wichita, Kansas
    Ok so last night i carefully removed them and sanded the inside edge all around. Looks like there was a build up of glue that makes it a tight fit over the stock mirror. Cleaned up real good and restick back on. They fit way better now. I still think the width of the mirror edge needs to be wider to fully cover the stock mirror.
    May 2012
    Panama City, FL
    I have them on my '16 RTS and really like them. Dale
    Jun 2011
    Near Lexington, NC
    Do the stick on's change the rear view objects from appearing much further back than they really are, similar to OEM's?
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    They are the bomb! I had Tricled install at Spyder rally in Springfield. After 3 years, rock solid.
