Results 1 to 15 of 15
    Active Member iridenow's Avatar
    Sep 2019
    Phoenix, AZ
    Default Rear left storage compartment is stuck
    Not sure how to get it open. Any suggestions? Before you ask, it is unlocked.
    Fred is a 2010 RT SM5 - Sold.
    I am not a mechanic. When I have a tool in my hand, 911 needs to be on Standby.
    Mar 2015
    forrest above Reno, Nv
    Quote Originally Posted by iridenow View Post
    Hi I,
    Push ( medium hard) on the compartment door as you pull the lever to open it. Lubing everything will help but the cable can be adjusted. It isn't to hard to get to the cable adjusters.
    2014 RTS , Circuit Yellow
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    +1 on what Lew L said. Our left saddlebag on our '18 RTL needs to be pushed in as I pull the opening lever. It's not that much of a problem as it always comes open, but I probably should adjust the cable and lube it. Oh, well, I'll just call it an anti-theft feature.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Vermont
    + 2 on what Lew says.
    I have the same problem with my 2014RTS-SE6.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Read page 137 of your operator's guide.
    Northern Kalifornia
    Yep, +2 on Lew. My 14 stuck for a while when it was new and a gentle push with my knee popped it right open. A little lube seemed to cure the problem. A light whack with the heel of my hand makes sure both sides are latch 100%. You'll never forget that if you ever have one that pops open on the freeway. Thank goodness the dash lights up and goes crazy when that happens.
    Apr 2013
    Hartsville, S.C.
    Be careful. I've read on Facebook post where more than one owner has snapped the lever off.
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Saddlebag lid stuck!
    I recently sold my 2014 RT-S with 188,000+ miles on it to my brother, Ken. He brought it over to get the right saddlebag lid to open, I couldn't. The other side works right, but the right doesn't even feel like the cable is hooked up. It won't budge. Any ideas?
    Chuck
    Nov 2018
    Waynesboro, PA
    My Spyder
    2012 RTL , Brown
    Jun 2015
    Zanesville Ohio
    Unlocked, the other side opens as it should
    Thanks!
    Jun 2015
    Zanesville Ohio
    How is the cables adjusted when the saddlebag won't open. Are the cables adjusted from the back, or each side. Either way the rear side covers have to come off, but how? The side screws are under the lid.
    Chuck
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Buckeye Chuck 54 View Post
    Chuck
    You have to remove the rear panel to access the cable adjusters.
    2014 RTL Platinum
    Jun 2015
    Zanesville Ohio
    Yes, I know. But the rear side panels are screwed from inside the bag lids> they can't be reached!
    Chuck
    Dec 2015
    Oakley Utah
    Chuck
    Good point...
    2014 RTL Platinum
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    Try giving the compartment lid a small slap with the palm of your hand. That works for me! Yes, I need to adjust mine but have not gotten around to it.
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
