Results 1 to 9 of 9
    Jun 2018
    Pa.
    Default How long do heated handgrips operate for?
    Morning All:
    I have a 2017 F3-Limited with heated grips. I do not use the grips much and I am do not fully understand their operation. When I activate by depressing the button, do they stay active even between restarts until I depress the button again? I tried testing and it seems I get lost in the button pushing.
    Thanks in advance,
    Jim
    Aug 2013
    Northern California
    Once you depress the button, they will come on every time you start.
    Aug 2019
    southwest oHIo
    Not sure about your F3, but on my wife's RT-S, the switch latches into one of three positions, OFF, LOW, HIGH.
    I would guess that if it was a momentary switch, it would activate the function until the switch was moved or the key was turned off, but the latching feature tells me that it would stay ON.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Jun 2018
    Pa.
    Thanks for the answers all - the button only has on and off based on the responses.
    Thanks for your time.
    Jim
    Feb 2019
    Portland, Oregon
    Do press the button until it locks down. If it is flush with the bezel, it's in the off position. Locked down, keeps them on even when restarting.
    Active Member justsmile0808's Avatar
    Oct 2019
    Southampton, NJ
    Quote Originally Posted by JimH View Post
    Morning All:
    Thanks in advance,
    Jim
    Doesn't much matter, Jim - those grips are so anemic, you will find yourself randomly pushing the button because you are not quite sure if the damn things are working or not. "Heated" grips its a term used loosely on the F3 Limited ...unfortunately, we were robbed.....
    Feb 2019
    Portland, Oregon
    My heated grips do a fine job and I even put Grip Puppies on them and wear insulated gloves. Guess I'm lucky.
    Active Member Big Juice's Avatar
    Jul 2017
    Hot Springs Village, AR
    I also have a 2017 F3-Ltd, and my heated grips work just fine in my 35K plus miles so far. Doesn't overheat my gloves so my hands sweat, but keeps the chill off. If you leave the button down, it turns off when the ignition is turned off, and then turned back on when the ignition is back on, so there is no drag on the battery or overuse of he heated elements. At least this is the way MY bike works and I'm well pleased with it (have had to turn off the heated grips a few times after the sun comes out, or put on thinner gloves is my preference).
    O. J.
    Ridin' "Lucille", the MusicMaker
    a 2017 F3 Limited (Pure Magnesium Metallic)
    Wife, Jan, riding "Ruby Jane"
    a 2016 F3-T (Intense Red Pearl)
    2017 F3-Limited , Magnesium (light grey)
    If they're like the ones on the RT, and I'm sure they are, the grips are powered through the load shedding relay. That means the engine must be running for them to turn on, just like the headlights and rear air bag compressor.
