Anthony,
Thank you for working on this. I knew the problems with the map function could be fixed. Oh ya----- My new years resolution was to be more positive.
Lew L
Reason: speeling
Server Admin
I would like to edit mine for tools/etc. It appears as though it will only let you edit location. Is this correct?
Thanks, Bob
Server Admin
Thanks, Bob
What browser are you using?
Chrome - It appears thats a bug in the code, odd i did test chrome when creating a pin, the radio buttons work for making your tools/trailer etc selection, but it appears they do not function when editing a pin in chrome.
Firefox - It does work on both, when creating or editing a pin.
Thanks for the reply. Chrome don't like it - Firefox does. Just made the edit.
Is something down with the map software?
I only see a blank screen. Thanks
Clicking on the tab at the top brings up the full US map. It is working for me. Go up or down from there with the controls.
Nothing but white page within the map area. Using IE11 windows 10. It did function prior but something is astray with this map. Everything else functions great.
Again, thanks.
Server Admin
The bug in chrome is now resolved.
Server Admin
Again, thanks.
I dont have windows 10 available, but there is no issue with the map, id clear your browser cache & try again.
Ill test on windows 10 tomorrow w/ ie11
FYI:
Today
I get this message:
do not have permission to access this page. This could be due to one of several reasons:
1.Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
2.If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Tried it. I was able to drop a new pin, but the radio buttons for tools/trailer, etc. did not show up except for one unlabled set of yes/no buttons and two text windows. Tried both Firefox and an older Seamonkey browser on Win 7, same result in both. I tried it several times, sorry if it makes multiple pins show up.
Edit - tried it in Chrome also, same results.
Server Admin
Confirmed as working on win 7 in chrome & ff, try clearing your browser cache in those & try again please.
I dont have seamonkey to test with it.
The map I am having this message displayed is the new Spyderlovers user map not the US map.
FYI:
Today
I get this message:
I'm getting the same error. What do we need to do get permission to access to the map?
I only have an iPad & iPhone. Apparently, I can’t add my location with these devices, unless there’s some way to do it that I’m not aware of. Can anyone help? TIA
Server Admin
I tested the map using both my i6 & ipad when i set it up, both worked without issue.
I just verified on my old i6, it works as it should.
1. Just touch the map with 1 finger
2. Hold for a sec or 2 & release
3. The popup will appear after removing your finger from the map.
Just realized I never thanked you for this. Thank you!
