Results 1 to 13 of 13
    Feb 2020
    N. Wilkesboro, NC
    Default What tire plug kit would you recommend?
    I have no idea what I did with my tire plug kit so I'm going to buy a new one (which means I'll find my old one as soon as the new one shows up). What does everyone recommend? (Links, please.)
    Thanks.
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by MONK View Post
    Thanks.
    I don’t have one. In over 50 years of riding motorcycles, I’ve never encountered a flat.
    Bruce
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Aug 2015
    central oregon
    I've always used the cheapo sticky strings with fresh glue each season and I carry one of the Xlime pump compressors.
    Aug 2019
    southwest oHIo
    I, on the other hand, have had several. This is the kit that I carry, along with a small Harbor Fright compressor.
    https://www.nealeytirerepairkit.com/repair-kits
    https://www.harborfreight.com/12v-15...tor-63152.html
    One advantage of the Nealey kit is that the strings are used DRY, so there is no tube of cement that will dry out.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Northern Kalifornia
    None are 100%, that being said I've used the cheapo sticky string plugs on trailer tires with a high degree of sucess. I also carry the slime kit with their small flat compressor and a small bottle of slime. The sticky string kit will also fit in the slime kit bag and it lays flat in the bottom of my frunk taking up as little space as possible.
    Don't forget if you get a screw in your tire you won't get it out using your finger nails. Get a Leatherman.
    Active Member Bob L's Avatar
    Oct 2014
    Massachusetts
    Have helped others with flats and have experienced them myself. My Royal Star Venture seemed to be a magnet for flats. I Cary the Stop and Go kit and have been very pleased with it. Probably have used it 6-8 times over the years.
    https://www.stopngo.com/
    Bob
    Bob L.
    Worcester County Massachusetts
    www.rk-mass2.org
    Clinton, MS
    Dynaplug Ultralite tire repair and their Micro compressor. It all fits in the compressor bag and takes up very little room.
    dynaplug_micro_pro_inflator_750x750.jpgdynaplug_dynaplug_ultralite_tubeless_tire_repair_kit_750x750.jpg
    Sep 2020
    New Jersey
    I worked in a tire shop many years ago, we used a plug kit made by SAFETY SEAL. Best kit available. $48.00 dollars, worth every penny
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    Quote Originally Posted by Bob L View Post
    Bob
    I have the pocket "Stop-n-go " kit. Never had to use it though. Mine uses CO2 cartridges of which I carry extras.
    Lew L
    2014 RTS , Circuit Yellow
    Aug 2018
    Chicago
    Quote Originally Posted by Time2ride View Post
    love stop &go
    Bossier LoUiSiAna
    Weather you find old kit or not good idea join AMA to get the roadside assistance deal with the automatic renewal
    https://americanmotorcyclist.com/
    Sure like what it coves & ease of use. Has worked great fo me so far anyway (dont rely on exclusively)
    PLUS all the other benefits with being a member
    Linden, CA
    Quote Originally Posted by bigbadbrucie View Post
    Bruce
    You are a luck man.... However.... I did get a flat on one of my early Gold Wings but it has spoke wheel and tires with tubes inthem
    I think it was my new 1977.
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    i have the stopngo had to repair tire on my truck worked very well ,dont think the plug could come out being mushroom shaped
