Results 1 to 3 of 3
    Active Member Charlottes Web's Avatar
    Northeast PA.
    Default How do I turn my Avatar & Delete one of the maps?
    How do I turn my avatar and delete one of the maps
    Hi Charlotte, you'll need to flip the PIC on your computer & then reload it to your Avatar file to fix that - it seems the site uses the TOP LEFT corner of any pic as its 'anchor point', while many 'phones & digital cameras use the TOP RIGHT, so whenever you load a pic that has a top right anchor point the site software fli pos it like that. Often, all it takes is to turn your phone/camera anti-clockwise 90° and take the pic in landscape mode; but for all those pics you have already taken, you'll need to open them in something like photo-shop & either change the anchor point to top left, or flip/rotate them so that their anchor point is moved to the top left - that's at least partly why you see so many images on the internet, youtube etc that are reversed - they had anchor point conflicts & so were flipped to fix it!
    As for getting in to your profile to edit your avatar &/or your sig maps, just click on 'Notifications' up the top right of the screen, as tho you want to read your PM's - once that screen opens, there's a column of 'Edit' links down the left hand side. Pick the appropriate one & edit away! You can also get to the same place by going thru your own 'My Profile' link up the top right & then clicking on the 'edit' pen in the top right corner of whatever field your avatar or sig appears in.
    Good Luck!
    Ps: it looks like I've already inadvertently deleted one of your maps when I was checking to see that you could do it. Sorry. I hope it was the right one. If you msg back soon I may be able to recover the deleted one, it's still in my clipboard for now.... might not last long tho!
    Northeast PA.
    Thank you
