Page 14 of 79 FirstFirst ... 41011121314151617182464 ... LastLast
Results 326 to 350 of 1963
  1. #326
    I think Linda is going to wash my F3.
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Got the new Veredestein Q 5s' installed - see other post for impressions.
    Also, finally traced and removed the unsightly GPS mount from the handlebars. Couldn't find Stainless cap bolts so had to use SS Button head. Now I've got a mount and cable for an unknown GPS laying around. really need to get rid of this old stuff.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
  3. #328
    Active Member 2RTsGV's Avatar
    Sep 2014
    Grain Valley MO
    Installed: - F3 mirror wedgies (from Squared Away) - F3 Trunk Organizer (from Spyderpops) - GPS Handlebar Ram mount (from Lamonster) - Hardwired & mounted Garmin LM 396 GPS unit - F3 Tall boy Windshield (from BRP)
    I love how the earth rotates around the sun ... it really makes my day!
    Currently Own:
    2019 F3 Limited - Vegas White (Dark Edition) - His
    (Baja Ron bar/links-Short reach bars-Center footpegs-Tall boy screen-Flag holders-LED Skidplate-Spydercuffs-Ultimate seat-LED Headlights)
    *** BLOWN MOTOR Apr 21 @3,800 miles, motor replaced by BRP Jun 5, 21 ***
    2019 RT Limited - Phoenix Orange (Chrome) - Hers
    (Baja Ron bar/links-Skidplate-Spydercuff-Comfort seat-LED Headlights)
    Previously Owned:
    2013 RT SE5 (Orbital Blue) *31,000 Miles* - His
    2012 RT Ltd SE5 (Pink Full Body Wrap) *41,000 Miles* - Hers
    2021 Ryker 900 (Black) Sport Windshield - Foam Grips - Solo Comfort Seat
  4. #329
    Active Member nightcruiser's Avatar
    Feb 2019
    Indiana
    tightened backrest
  5. #330
    Jun 2017
    Rapid City, SD
    Oil change time.
    HE>I
    2017 RT , Asphalt Grey
  6. #331
    Mar 2015
    forrest above Reno, Nv
    Got the ready for an overnighter down 395 for about 4 hours towards Bishop, Ca. A superior bakery makes the trip a gastronomic pleasure after being cooped up for months.
    2014 RTS , Circuit Yellow
  7. #332
    Active Member RowdyScamp's Avatar
    Aug 2019
    Arkansas
    I had to take advantage of the roadside assistance today.
    Was ryding into town to top off the fuel tank, and got a check engine light and LIMP HOME MODE
    Pulled into a nearby parking lot, and got LOW OIL - STOP ENGINE
    Fault code came up P0254
    Checked oil level, it was covering dipstick.
    I called the nearest dealer (about 40 miles away), and they said I needed to get it in there for them to look at. So I called the roadside assistance number, and they got a towing service to pick up and drop off my Spyder (2018 RT).
    When I called the service department, they said they were looking at it, and would let me know what they found out. Depending on what they tell me, I may be considering the B.E.S.T. warranty (but not from them - they want $1399 for 36 months)
    2018 RT , Pearl White
  8. #333
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    Brought a new Akrapovic straight shot pipe brand new off of E-BAY for 450 bucks with free shipping about a month ago..today I installed my new RACE TECH shocks..front and rear..
  9. #334
    Oct 2015
    Lynden, WA
    Have to work from home today.
    Home is vastly safer than the manufacturing office.
    Will ride later to run some errands.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  10. #335
    Memphis, TN
    Got some lights from Lamonster and installed them.
    Added some extra tail lights
    https://www.lamonstergarage.com/can-...ure-lamonster/
    And a Lamonster Bright Ryder on the front
    https://www.lamonstergarage.com/can-...der-lamonster/
    Both were easy enough to install, and look great.
  11. #336
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Installed new front sprocket on neighbors 2015 RT. What a bear to remove old one, lots of red dust, Had to use a lot of heat and a puller. Also installed Lamonster belt tensioner.
  12. #337
    May 2020
    Walker, LA
    Installed new brake/run/turn LED lights from Spyderpops. Wanting them higher up than under seat, more in the line of sight of any vehicle following me, I chose to install them on back of passenger armrests. I am pleased with the end result.
  13. #338
    Feb 2012
    Spring City,Utah
    Picking up Spyder from dealer. With the broken ankle I did not feel like crawling around it to flush brake fluid and coolant so I bit the bullet and had the dealer do it. Many dollars, will never do that again. Next job is to replace the rear brake pads and add the side marker lights to the bags.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  14. #339
    Aug 2019
    Stoughton, WI
    Put on a license plate flag mount and Thin Blue Line flag. Time to represent. Police lives matter !!
    2022 RT Sea To Sky
  15. #340
    Feb 2019
    Portland, Oregon
    Worked on a friend's F3S that he recently acquired. Moved the pegs from 3 to 4. Swapped brake rods. Cut windshield down so he can see over it. Loosened handlebar clamp and lowered them. Yeah, they move up and down.
  16. #341
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    Took delivery on a new 2019 RTL and got a short ride in before the sun cooked me medium-well. It's 110+ here today.
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
  17. #342
    Feb 2019
    Portland, Oregon
    I watched Nuke's video about installing bright LED rear turn signal bulbs and was inspired to do that to my F3L after seeing how dull the stock ones are. Ordered a pair and put them in. Holy Lumens Batman, those suckers are REALLY bright! There will be no doubt now when my flashers or turn sigs are on.
    https://www.youtube.com/watch?v=ls5l_AMQVBI
  18. #343
    Jan 2019
    Toowoomba Qld Australia
    Yesterday got the Shad brake light installed. Thought I would have issues with connectors but the local Autobarn had the correct ones so a nice neat job. Previous weekend did my first oil and filter change on Spydey. GPS mount I think will be next.
    2014 ST-S SE5 Cognac
    2014 ST-S , Cognac
  19. #344
    Jun 2020
    Ashburn, Va
    Cool Some repairs and upgrades.
    I just got my 08 Spyder GS SM5 back from the shop after almost a month. Had the DPS Unit replace , new front tires, ball joint replaced and had an alignment done.
    They also fixed two recalls. Something with a gas evap hose and a new gas cap. I replaced the battery when I bought it. I got it from my local Batteries Plus store.
    In the last week since I got it back. I've replaced the Frunk seal. I got it from Spyderprops
    Then I removed the rear Pin Up Girl decal that came on it. (https://amzn.to/3gUPbLy)
    I've left the decal on the front on for now. I've gotten some compliments and she's growing on me.
    I also upgraded the headlight bulbs. I ended up using Sylvania (H7) SilverStar zXe Gold bulbs.
    https://amzn.to/38SEhDf
    I got a key holder and key chain. Link shows it in red. Wasn't able to find the blue one. (Link on my past orders has changed)
    https://amzn.to/30bFX73
    I'm a Star Wars fan so that explains the key chain (https://amzn.to/2BYA7hf).
    And lastly I got a cover for it. Which I have yet to put on, cause I've been driving it almost everyday since I got the Spyder back from the shop.
    https://amzn.to/32hbbw2
    I'm having too much darn fun on the Spyder!
  20. #345
    Sebring, FL
    Lot going on there, nice ride, like Capt Scoundrel name, very creative.
  21. #346
    Active Member scorpion56's Avatar
    Jun 2020
    Boston
    Performed my first oil change. Did the change on the garage floor with a bucket shallow enough to slide under the Spyder. Learned a lot as I went along (watched Lamonster's video before starting). Pretty sure that I can do the next one in half the time.
    2019 Can Am F3 Limited
    Spyder Upgrades/mods:
    F4 Windscreen,
    Ultimate seat and Driver's backrest,
    Lamonster Fog lights,
    Lamonster Brake Rod kit,
    CanAm Short Reach Handlebar
    Other Current Bike: 2009 Honda Shadow 750 Aero
    Past Bikes:
    2018 BMW C650CT
    2013 BMW C650GT
    2011 Honda SH150i
    2019 F3 Limited , Oxford Blue Metallic
  22. #347
    Jul 2020
    Austin, TX
    Installed passenger armrest, driver back rest and touring windshield. It was like a walk in the park!
    2020 Can-Am Spyder RTL
    2009 Yamaha V-Star 1300T (sold)
    2007 Yamaha V-Star 650 (sold)
    "I wasn't born in Texas, but I got here as fast as I could!"
    2020 RTL , Asphalt Grey Metallic
  23. #348
    Feb 2019
    Portland, Oregon
    Did my first and hardest, of course, oil change. Hard because I didn't know all the tools needed. The good news is, next time will be easier and my uphill sloping driveway gets the bike level without having to lift the back end.
  24. #349
    Sebring, FL
    Hmmm, I like it, wonder if it would work on the 20 RTL? I need to check if the drain plugs are at the rear of the oil pan.
  25. #350
    Feb 2019
    Portland, Oregon
    The plugs are almost at the rear, enough that most oil will drain out. However, my slanted driveway had the bike perfectly level.
