Results 1 to 25 of 28
    Oct 2015
    Lynden, WA
    Default Do you carry extra fuel for long tours?
    I have a long tour coming up. Part of the ride will be beyond the maximum range of my Spyder, 2013 STS.
    I'll be near (Area 51) in the desert north of Las Vegas.
    I believe I will need to carry 1+ gals of extra gas. I'm considering using a couple of big Aluminum water bottles mounted on
    my left side passenger foot board. I ride solo so the foot board space is available.
    Any thoughts or ideas ??
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Johnson, Vermont
    I carried a 1.25 gallon Sealed gas can in the frunk of my RS on my western tour. I never needed it but there was a couple times when I was pulling into the gas station on fumes.
    May 2019
    Fort Washington, Maryland
    If that doesn't work try this.
    https://www.reda-innovations.com/reda-gas-can
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    I have ridden the Extraterrestrial Highway on 3 different bikes:
    Carried a gallon of Trufuel on the Honda CB1100.
    No need with the Moto Guzzi With 5.8 gallon tank.
    Had a 5 liter solvent can on the Triumph. Had to vent it a couple times before pouring into fuel tank in Warm Springs.
    Coming from Alamo, the last fuel stop before heading west is Ash Springs.
    No fuel in Rachel, but decent food stop.
    Warm Springs, where the Extraterrestial interacts Highway 6, is a ghost town, so no fuel until Tonopah, 154 miles from Ash Springs. That would be iffy on my Ryker, prohibiting speed bursts and a headwind.
    Photo is in Rachel, at cafe, with fuel can on back seat.
    TruFuel is expensive, but saved me buying a fuel canister. I carried a couple quart size in the tail bag of my TW200, as it’s tank was small. Putting a sock over each one helped to cushion their ride.
    https://www.lowes.com/pd/TRUFUEL-110...-Fuel/50328935
    May 2020
    New Mexico
    If you make it down to Beatty, 1/2 way from Tonopah to Las Vegas and a gateway to Death Valley, stop at Death Valley Nut & Candy. They make their own ice cream!
    From Beatty, highway 374 (Daylight Pass) is an enjoyable ride to Stovepipe Wells (only 87 octane) and/or Furnace Creek.
    Attached photos are of Extraterrestrial Highway.
    Active Member Charlottes Web's Avatar
    Northeast PA.
    I carry gas with me. Had to use it twice not for me. My friends ran out of gas.
    Danbury Connecticut
    When I got my first Spyder in 2010, I carried a REDA gas can just in case. It's designed specifically to carry on a motorcycle.
    I never used it. Never ran out of gas.
    If you're uncomfortable, get the REDA.
    It looks like they've improved the nozzle. I may pick one up myself.
    IBA #47122
    2020 RT Limited Asphalt Grey
    May 2020
    New Mexico
    The leakage issues of REDA gen 1 appear corrected by gen 3.
    However, for only emergency use, 110 ounces of TruFuel is $20, ethanol free, 92 octane and if stored sealed, has a 2 year shelf life.
    One year after first opened.
    Oct 2015
    Lynden, WA
    Thanks everyone.
    Traveling North to South via Hwy 6, Tonopah thru Rachel and beyond is my outbound concern.
    Will cruise thru Beatty on my return to Carson City.
    I'm going to check into the TruFuel at Lowes.
    Also considering a Small Red Fuel can from Amazon.
    My next challenge is fabricating a fuel can mounting plate to bolt to the footboard.
    David C
    2016 F3T
    Rear IPS Pack Rack
    May 2020
    New Mexico
    Enjoy your excursion!
    What are foot board dimensions?
    You may be able to secure can to foot board with a lashing strap:
    https://www.strapworks.com/Strap_Adj...ps_p/sas1h.htm
    Apr 2020
    tucson az
    My thought is to attach a fender bag to the rear fender and put a couple msr fuel bottles from the camp store in it. they each would carry about 1qt of fuel.
    2011 rt , pearl white
    I carry 750ml of gas in a nice small rectangular old Sauza Tequila bottle in the rear trunk ....attached to the right side in a homemade bracket ....I also duct taped the outside of the glass ....of course it's dangerous but so is the gas in your gas tank .... a racing fuel cell would be best ..... I have only needed it once, and that was when I was testing " how far on a full tank can I get "..... But I have given it to others who run dry ..... for my 14 RT the 750ml will get me 12 + miles ...... good luck .... Mike
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Haze View Post
    I have a long tour coming up. Part of the ride will be beyond the maximum range of my Spyder, 2013 STS. I'll be near (Area 51) in the desert north of Las Vegas. I believe I will need to carry 1+ gals of extra gas. I'm considering using a couple of big Aluminum water bottles mounted on my left side passenger foot board. I ride solo so the foot board space is available. Any thoughts or ideas ??
    The only place I've run out of gas riding a bike is in Nevada, and that's happened 3 times on two different bikes. Fortunately I do carry a spare gallon. But, that's me. Lots of folks see no point in it.
    I use a REDA in the rear side case.
    2014 RTL Platinum
    Aug 2012
    Central Coast, CA
    Another Reda vote for me. I have one that I bought for my 2008 GS. I carried it in the frunk with no fuel leak or odor issues. Super sturdy and well made. I never needed it, but had it on a couple of long trips out in the desert. I also have a fuel bladder for when I was distance dual sporting in the desert as well. The bladders are kind of cool, but they can be a PITA to use.
    2020 RTL SE6
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    I have .75 gallon rotopax can on my trailer hitch. So far i have not had to use it, but came very, very close to running out of gas our first year out with the spyder, so added it after that. It's nice piece of mind to carry
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    May 2020
    New Mexico
    A couple years ago, wife and I traveled from Whistler through Kamloops, then Kelowna.
    Not a lot of fuel options!
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by SportsterDoc View Post
    From Whistler to Kamloops, only 4 that I know of. But, it's a great ride........
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Central Oklahoma
    I keep a 1 lt red aluminum bottle with 93 mixed with some Stabil. silicone seal between the cap and the rim then tightly wrapped the top with that self-sealing rescue tape.
    2020 RT Limited , Petrol Metallic Dark
    May 2020
    New Mexico
    Quote Originally Posted by sduskin View Post
    I keep a 1 lt red aluminum bottle with 93...
    Is that about 8 miles less to push?!
    Aug 2015
    central oregon
    Carried extra once but didn't need it. I used the fuel and gave the can away. I always get gas when I can rather than when I need it. Even if it's only been 50-100 miles.
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by bcer960 View Post
    For the distance involved, that’s lots of fuel. I assume you’re going Whistler up to Lillooet, then either out to Lytton or from Lillooet up to Cache Creek, and then to Kamloops. Either way, plenty of gas. In any event, always fuel up when available, not only when needed.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Jun 2010
    Las Vegas
    Went to Alaska and didn’t carry gas, I live in the desert and don’t carry gas. I do make a point of knowing where I need to stop so I don’t run out.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2020
    New Mexico
    ... I do make a point of knowing where I need to stop so I don’t run out.
    Yep, but the 154 miles on the Extraterrestrial Highway between fuel is at best iffy on most bikes.
    It is the only route that I carry extra, other than some off-roaring.
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    In rural NZ, particularly at night, you can go a very long way between open gas stations, hence the large aux tank mounted on the rack which more than doubles the range:
    Even with this I still have a 1 litre primus bottle as a backup, though that's also for use with my camping stove.
    Before fitting this my panniers used to look like this:
