Do you think you are using a LOT of Brake fluid ????
For my `14RT, I seem to be adding brake fluid too often ( yes it's necessary ) ..... I have checked the at the calipers and also near the brake lines .... I can't find anywhere it loosing it ..... I did a brake fluid change last year, but this has been going on for quite awhile .....thanks ..... Mike
The only way I know of for brake fluid to go down is a leak, or it will go down as the brake pads wear. The fluid takes up the space of the worn pad. That being said I have never had to add fluid for brake pad wear. If it was from brake pad wear it should fill the master cylinder when you push the calipers back to replace the pads. (I'm talking about cars and trucks same principle). If you are adding on a regular basis look very closely for a leak. Have someone hold the brake peddle down and check every inch of the line from the master cylinder to every caliper. Good luck, let us know what you find.
I assume you have the master cylinder cap vents oriented correctly. How frequently are you having to add? Are you getting a brake failure code?
![Quote](images/misc/quote_icon.png) Originally Posted by JayBros
Caps ???? ..... how are they oriented ???? ....frequency ... more often than on any other Spyder I've owned .....thanks ....Mike
Unfortunately ya been adding as well. Caps V slot in correct position (best I can) keep eye dropper special with the brake fluid. & rag on master cylinder if does leak from there. Been dry but still light comes on maybe 60~90 days. Seems mostly front. Pads good & recently replaced. Having other problems like shift arm Splines currently![Gaah](images/smilies/gaah.gif) ![banghead](images/smilies/banghead.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by Bfromla
Ditto shift arm and shift shaft splines.
Eckhard
Spyder RT Ltd, 2011
![Quote](images/misc/quote_icon.png) Originally Posted by BLUEKNIGHT911
As you sit on the bike with dead ahead 12 o'clock the cap vents are about at 5. When I unscrew the caps the vents are at 3 to remove them from the MC reservoir. If they are otherwise oriented they can leak but you'd see it all over the reservoir.
Pad wear or leaks. Only 2 possibilities. But you know that. So, not much help, I'm afraid...
![](signaturepics/sigpic963_3.gif)
Mike,
Have you checked the ABS control unit to see if there is where your leak maybe?
2021 Sea To Sky, 2020 RTL
but our benefits don't?
vent caps
Orientation of vent caps make no difference. The rubber boot under the cap isolates brake fluid from the cap and outside air. It is a sealed system. The air vent in the cap allow the bellows of the expand to follow the brake fluid level. If air was allowed into the system, you would have a lot of water in system as brake fluid absorbs moisture.
As far as leaking fluid, check for leaking by the VCM besides what others have mentioned.
![Quote](images/misc/quote_icon.png) Originally Posted by SpyderJerry
Orientation of vent caps make no difference. The rubber boot under the cap isolates brake fluid from the cap and outside air. It is a sealed system. The air vent in the cap allow the bellows of the expand to follow the brake fluid level...
I beg your pardon. The brake system is not sealed and the vent in the diaphragm in the cap is there to prevent the diaphragm from expanding as the fluid level in the MC reservoir drops as pads wear. Yes, brake fluid is hygroscopic and that's partly why it is recommended the fluid be changed every two years. Look at pg 113 of your operator's guide and you see in the picture of the two diaphragms below the cap the picture on the right is what happens to the diaphragm if the V-slit does not function properly because the vent in the cap is clogged.
I remember reading on here several years ago that there were several people with 2014 RT's that had leaks at the bottom of the reservoirs...I also think that I remember that BRP had a updated part number for the replacement reservoirs...larryd
You are very wrong, I am a mechanic(50 plus years) and I think you should take a closer look at the bellows under the cap. You will see that the Air vent only allows air in for the bellows to expand with fluid level.
Actually, JayBros is very right. Stay humble
35:15 in this video for vent and V-slit orientation.
https://youtu.be/U_44e4oh-A0
![Quote](images/misc/quote_icon.png) Originally Posted by allcd88
I stand corrected. In all my years and training, I have never seen a brake system that can allow atmosphere air into the system. That being said, it is not a what I would consider a good thing and would certainly require brake fluid change every 2 years or sooner.
As a high schooler in the late fifties I worked in a service station and remember seeing an occasional vehicle come in for a brake job with the diaphragm on the master cylinder cover sucked way out of shape from low fluid level, generally the result of leaking wheel cylinders. They weren't vented. With the exception of taking my 911 to driving school where a brake fluid flush was required as part of tech inspection every time, I don't think any of my cages have had fluid changed except at brake job time. Being an RTFM guy I just follow what the BRP manual writers say.
Agree fully.
Not sure exactly why they did it this way, maybe concerns for expansion from under body heat inadvertently applying the brakes. Truly though never considered it after that.
Even worse is I have seen water droplets within the cap threads after wet rides.
FWIW, I too, years ago expected a sealed system and was kind of surprised to see those V slits as vents.
For my `14RT, I seem to be adding brake fluid too often ( yes it's necessary ) ..... I have checked the at the calipers and also near the brake lines .... I can't find anywhere it loosing it ..... I did a brake fluid change last year, but this has been going on for quite awhile .....thanks ..... Mike ![thumbup](images/smilies/thumbup.gif)
As a suggestion, difficult to see, but take a look at the master cylinder area. With the master cylinder at the bottom of the vehicle, and so much debris gets thrown up into that area, possibly the master cylinder bore is leaking. Possibly statically it seems fine, but with use, and movement of the piston, it slowly weeps fluid onto the roads as you ride.
Just an idea, I am sure you will sort it out.
Customer Support
I for one will be curious to see how this turns out.
2015 Pearl White RTL
Baja Ron Sway Bar
Russell Day Long Seat
Strobe Brake Light
![](https://www.spyderlovers.com/forums/maps/map.png?states=AK.NV.CA.OR.WA.MT.HI.ID.WY.CO.UT.AZ.NM.TX.OK.ND.MO.MI.GA.FL.NY.DE.NJ.MD)
If fluid is leaking wouldn’t the underneath be eaten up or really bad paint ?
