Results 1 to 25 of 26
    Active Member snayl135's Avatar
    Aug 2019
    Pennsylvania
    Default Anybody have to repair a flat tire on the road?
    Just wondering if anyone has needed to change a flat on their Ryker while on the road?
    2019 Rally , Black / Yellow
    Member glorybiz's Avatar
    May 2018
    Ellicott City, Maryland
    I had to plug the front tire on my 2016 RTL on the road. Luckily, I had some help from fellow riders. I had the co2 cartridges to inflate the tire but could not find the hole. My fellow rider had a 12v air pump which we used to help blow up the tire, find the hole and plug it. It's been fine ever since
    2016 RT Limited , stock yes red
    Jun 2010
    Las Vegas
    It is a good idea to carry a plug kit and a small compressor with you on any bike!
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member a99miata's Avatar
    NW Florida
    or carry a can of fix a flat......
    Don't get mad at me if you don't like my answer.....
    Quote Originally Posted by a99miata View Post
    There is that.... But during my time testing tires, I've found that using that stuff almost guarantees that you'll soon hafta buy a new tire!! Very few tire techs will bother even attempting to clean the goop out & repair the puncture after someone's used that stuff, no matter how tiny &/or easily repairable the puncture might be!!
    These days, with radial tires & proper pressures so readily available, it seems punctures are a much rarer thing than they have been in the past, so I simply carry a small plug kit with a variety of different style plugs & patches, a couple of tire levers, and a small compressor. Not that I've needed to use it all that often, but when I have, it works every time!
    Very Active Member StanProff's Avatar
    Jun 2011
    Jonesborough Tennessee
    I always carry a plug kit on my bikes including the spider. I have plugged tires for my friends on trips. No big deal. Anyone can do it. Plug kit and small compressor and your back on the road.
    Happy Spyderlovers
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Agree with Peter, don't want to use fix a flat. I have a Kriega bag mounted onto the max mount of my Rally. Carry a plug kit, small compressor (bought a cheap one at Walmart and removed all the plastic housing to make it small), some extra fuses, an Anti-gravity power supply and a small assortment of tools. All I need.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Here is an interesting video. I personally like this guy. He does a lot of comparison testing. Not always informative. But always interesting. This one, I think, tells a lot. Hope you like it.
    https://www.youtube.com/watch?v=H5DWhIF1c0M
    Very good video Ron. I learned a lot.
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    Thanks Ron
    I have been using Slime in my mountain bike tires when riding in the desert in Arizona. It works well, but seems to need a ‘top-up’ every year. I had a flat this past winter, that Slime did not seal. I added more product and no more flats. I have tube type tires so no issue with sticking to rim, but lots of guys use it on tubeless tires.
    Bryant, Arkansas
    The first time you fix a flat on the road for a friend ................ They turn into a better friend
    Cruzr Joe
    Northern Kalifornia
    First time I used slime was on a punctured quad tire in the back country. I'd punched a hole in my tire near big enough to put your little finger through. My hunting partner had the slime and a small compressor. We used the entire bottle of slime and then filled the tire up with air. I could hear the slime sealing the hole as I took off and I could see drops of green slime passing me. Centrifugal force slung some of the leaking slime out until it compleately sealed the hole. Great stuff, don't leave home without it.
    Jan 2009
    austria
    I had one .. my neighbor repaired it for me in 10 minutes ..still use the tire since some tausend of miles, no problem ..
    (I don`t like to invest in Kendas and still could not find others..)
    Dec 2008
    Jacumba, CA
    Best way to fix a flat is with a round head Phillips screw (3/4 inch), Phillips screw driver, an air pump and a can of Fix-a-Flat. Pull out the piercing object, screw the screw in the hole, use one can of Fix-a-Flat, air up tire and continue your journey. I did that on a new tire years ago on my motorcycle. The fix held up until tire was worn and ready to change.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Jul 2019
    Phoenix, AZ
    I have the plug kit and small compressor as well. But how to hook up the compressor? A couple of alligator clips would be OK, after all how often will I use it? But for my analytical brain I wanted a more elegant way to hook it up. I have a quick connect plug dangling in the frunk that I use for my battery tender. So I bought a cigarette lighter socket and crimped it on to another quick connect plug. Now I can connect the compressor or any other device I need to the spyder battery. Hopefully I never have to use the compressor. But I wonder if my little coca cola 'fridge will fit in the frunk? A cold coke on the road would be nice.
    2013 RT , Copper
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Check out Dynaplug, as cheap as $21.95, with free shipping direct from Dynaplug.
    http://www.dynaplug.com/carbon.html
    As for inflation, I have a super compact German made footpump, which will inflate a P/U tire in reasonable time. Carried it on last 4 M/C.
    Not had a M/C puncture since 70s, but prefer to be prepared for solo rides in remote areas out of cell service.
    Without a plug kit, I would be walking along the shoulder, looking for a screw to insert in a puncture to get me home.
    Some riders are satisfied with a cell phone and credit card, but many of my rides have limited cell service.
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    Are any of the plug kits better than others? Any specific recommendations?
    2016 F3-T , Intense Red Pearl
    Active Member Northofthesix's Avatar
    Sep 2019
    Leamington, Ontario, Canada
    I have a 12v compressor out of my old Mercedes 230C that I scrapped a few years back (compressor is small and works well) along with plugs.... when we tour with friends we decide who is bringing what so we dont end up with 4 compressors and no plugs.
    You can't get there from here....
    Mods and Tweaks:
    Showcrome Trunk Rack
    Showcrome LED Trunk Light
    Garmin 390LM
    Spyderzone Floating Hiway Boards
    Spyderzone Mount Dash Bracket
    BajaRon Antisway Bar
    Showcrome full-size brake pedal
    Spyder-2-Go Driver Cup holder
    Ram X phone mount
    SpyderExtras 12 volt Docking Station
    BRP Driver Backrest
    Monster 4K Action Camera
    Spyderzone LED Fender Mount Spotlights
    CASA LED Headlights and Foglights
    2018 RT Limited , Ashphalt Metallic
    Harrington, Australia
    There’s some great advice here on the best way to plug a hole, but I haven’t seen an answer yet as to exactly how you find the puncture in the rear tyre of something like an RT or F3 Touring with all the surrounding plastic. You can only feel the tread on one very small piece of tyre unless you can lift the rear.......and I have been told (albeit jokingly) by my local tyre guy that if I turn up with Slime or similar in my rear tyre, our relationship may be strained ....and we have a great relationship currently.
    HeliBars Handlebars
    Kenda Kanine rear.
    Quote Originally Posted by MNF3 View Post
    I've never found any major diferences in the plugs themselves.... But if you're going that way, just make sure your 'sticky dog-turd' plugs are fresh!! If they're more'n a year or so old, they probably won't work too well, and trust me, that's waaayy more frustrating than having a flat without any way of repairing it!
    Sep 2019
    illinois
    There’s some great advice here on the best way to plug a hole, but I haven’t seen an answer yet as to exactly how you find the puncture in the rear tyre of something like an RT or F3 Touring with all the surrounding plastic. You can only feel the tread on one very small piece of tyre unless you can lift the rear.......and I have been told (albeit jokingly) by my local tyre guy that if I turn up with Slime or similar in my rear tyre, our relation may be strained ....and we have a great relationship currently.
    The shop where I bought my Ryker told me 20$ extra to clean out the mess. I carry plugs, air cartridges and a 12v old Bell compressor.
    Jul 2010
    Las Vegas, NV
    I have a massive magnetic pull. Screws and nails leap at the opportunity to imbed themselves in on both of my tires! Plug kit, Aerostich compressor, and problem solved. The nails and screws stay imbedded, making them easy to see. Or, soapy water, poured over a filled up tire. Typically, you are miles from anything, so, take your time! Once you find the puncture, fix it. I usually replace the tire when we get where we are going, or, if none are available, when we get home. The idea of fixing a tire with a Phillips head screw nearly had me, as I thought it was in jest. I hope it was. If not, very scary!
    Joe Meyer
    Feb 2012
    Spring City,Utah
    Haven't had to fix a flat in years. I think I still had tubes the last time. Still carry plugs and compressor. Probably jinx me now.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2014
    Benson, NY
    Quote Originally Posted by SportsterDoc View Post
    I have the dynaplug. Haven't had to use it so I don't know if it will work as good as i think it will.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Feb 2020
    Violet, Louisiana
    I have the stop n go mushroom plugs and compressor kit. Hope I never need it, but you have to be prepared. I also carry a lithium battery jumper which has an emergency light. Hope I never need that either. The folks on this forum helped me prepare.
