2020 RT Safety Recall. Not everyone is affected.
https://can-am.brp.com/on-road/us/en...y-recalls.html
If you have your VIN number, the above mentioned website will tell you if your 2020 RT is involved. If nothing comes back, call 888-272-9222. They'll be able to clarify.
I did both and mine is unaffected.
I need mine modified.
I've already called, just waiting for the part.
IBA #47122
2020 RT Limited Asphalt Grey
Thanks.
My VIN is not affected. (Apparently, and for now.)
2020 RTL SE6
I just got a call from my dealer, my name was on his list to call. waiting on parts to come in next week.
Some people are like Slinkies good for nothing but fun when tossed down the stairs
My VIN# isn't showing anything due on the website, so I called BRP. The customer service representative says I should take my spyder to the dealer for a visual inspection. So I called the dealer, and he looked up my spyder and said, Yes, you are affected. Parts are now on order.
2020 Petrol Metallic RT-Limited Dark Edition
2014 Silver Platinum Satin RT-Limited SE6 Project Road Warrior Edition (previous ride)
2009 Red SM5 (Previous Ride)
Retired MSgt ('89-'13) U.S. Air Force - A-10 Crew Chief
Same here, they of course have to order parts. Probably back ordered as well.
The recall bulletin does say
Which models are involved?
Specific serial numbers of model year 2020 Can-Am Spyder RT.
but based on the comments above it is hit or miss when checking your VIN. With BRP being closed down maybe they don't have the list of VINs owners can access updated. They probably focused on the dealer site info first.
I just put in my VIN and I’m not part of the recall. I bought my 2020 about a month ago.
So far the only item not working as it should is my outside temperature sensor, it consistently reads 5-10 degrees above the actual temperature. I can live with this one until I take the bike in for the 3000 mile service.
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
I put in my vin# and nothing came back so I guess mine is okay, but I think I will call my dealer to
be on the safe side.
Toby
2020 RTL
I bet it will always read at least 5 to 10 above just due to mounting location
That's normal, it has been like that since the very first Spyder.
The sensor is mounted low on the engine intake to monitor the air temp for the fuel injection system (ECU).
The display is only for show.
I posted above that my on line VIN checked showed I was not affected. However, after reading Mr. Bling's statement I decided to call the dealer to verify. Yes, my bike is covered in the recall. So, I would suggest everyone call their dealer in an abundance of caution, since it appears the website is not up to snuff.
2020 RTL SE6
This is currently a Safety Bulletin so I would not expect anyone will have their VIN cone up in the mentioned site which is for recalls. Everyone with a 2020 should contact their dealer to find out for sure.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I hate to be contradictory, but BRP is calling is a "Safety Recall", not a bulletin.
2020 RTL SE6
Check your VIN now. The VIN lookup box on the page linked to in the first post has this note on it:
*Results last updated: Sun, 05 Apr 2020 00:00:00
Dm/D
When I put the VIN in, my vehicle comes up in the lower box but does not say whether or not it is part of the recall. Just gives a vehicle description. Does it give a message when yours is under the recall? It does have the letters DM/D behind it. What does that mean?
2020 CAN-AM
RD SPYDER RT LTD 1330 ACE SE6 DM/D
Reason: Left something out
The printed notice that I saw said bulletin. But my point is that don’t rely on the VIN lookup at this time, everyone should contact their dealer for a definitive answer.
2010 RT- 622
Does anyone know exactly what parts are affected?
2020 CAN-AM
So for my spdyer it's:
2020 CAN-AM
RD SPYDER RT LTD 1330 ACE SE6 PM/D
I have the Petrol Metallic/Dark Edition
Do you have the red one? Deep Marsala/ Dark Edition?
Mine is on the list. Will contact the dealer tomorrow. Tom
2020 Petrol Blue Metallic RTL
Aaaargh! I posted previously that I wasn’t affected, but this morning my VIN showed that I’m included. Oh well.
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
Dm/D
Yes, it is the red one. I see it now. (Deep marsala red dark edition) DM/D. Thanks for the info. BTW, checked NHTSA and it shows no unresolved safety recalls on my vehicle. I do have the boot issue on the passenger grips but that is aesthetic. Haven't checked for tie wraps under the seat yet.
Its an official NHTSA Safety recall. I posted the bulletin in a separate thread with some other documents as well.
And FYI, its essentially all RTs produced up to Feb 18th according to what BRP has told the NHTSA.
Curious that it doesn't show up on the NHTSA site I linked to above.
