Results 1 to 14 of 14
    Active Member scwingman's Avatar
    Dec 2019
    Fair Play, SC
    Default Will anything stop the clunk when put into reverse gear?
    Is there always a loud clunk when going into reverse or is there a trick or procedure to prevent the clunk?
    I have a 2015 RT-s
    SCWing
    Sep 2014
    USA
    It clunks forward or reverse at times..No trick its normal for the most part.
    Dec 2019
    San Antonio, Texas
    2019 F3 does the same thing
    2022 RT , Marsella Red
    Nov 2018
    Waynesboro, PA
    Quote Originally Posted by scwingman View Post
    I have a 2015 RT-s
    SCWing
    Its normal they all do it.
    My Spyder
    2012 RTL , Brown
    It's because of the clutch design & the way it mates with the 'motorcycle' type gearbox; this combination means that they will clunk when selecting either first or reverse from neutral - in fact, if it DOESN'T clunk (at least some of the time ) you should probably consider checking the oil level & maybe getting your Spyder looked at, there's a good chance something's wearing &/or could be broken!
    Running the correct weight oil at the correct level (& using the approved checking method) teamed with idling a bit longer on your initial start to warm everything up properly, especially from a cold start, will tend to lessen the loudness & the abrupt nature of the clunk juuust a little, but it certainly won't make it go away.
    Really, it all comes back to being just one small part of the overall experience & the clunk is simply one of the unique features that you should learn to welcome & enjoy!
    Ride More, & Worry Less!
    What they said.
    Feb 2019
    Portland, Oregon
    Are you referring to the clunk you get when the engine is cold or fully warmed?
    Warm - Cold , it always clunks as stated by others ….. My 1330 RT is a little quieter if it is near operating temp ….. Mike
    Sebring, FL
    Noticed the 'reverse clunk' on my 2020 as well, less so when warm. Pleased to read that it's normal.
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    It is normal. One thing I have noticed is that once I back my Spyder out of the garage, if I press and hold the shifter paddle, it does not clunk going into first.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
    Aug 2013
    Northern California
    " It's Just the normal Noises in here!"
    Jun 2019
    Deltona FL
    It's letting you know the gear has changed......
    Jun 2019
    Deltona FL
    Gotta love Tom Petty! First album was his best......
    You get the clunk in both situations. For me, it seems that the clunk is loudest on that first start up in the morning, and going into reverse while backing out of the garage.
