Results 1 to 10 of 10
    Sep 2019
    Central Texas
    Default Showing my ignorance
    I have a 2016 RTL with the orange instrument cluster but I've seen pics of a blue instrument cluster. Is the blue cluster a different year or is there a way to change colors on my bike?
    Jan 2015
    southern WI
    Is it orange all the time, or just in the dark? it should switch colors between dark and daylight. If it doesn't, someone may have "rigged" it to trick it to think it's dark.
    2016 RTS , Pearl White
    Active Member SilverFox1's Avatar
    Dec 2010
    Chelmsford, Ontario
    Blue until 2012. They made them orange in 2012. On the RT model anyways.
    If you don't change anything,,,
    nothing is going to change!
    Ignorance??? Nah! Just think of it as "Excuse my having missed the opportunity to encounter and assimilate knowledge pertinent to this particular issue!"
    Look for a piece of tape that covers the light sensor somewhere on the cluster screen. It's possible the light sensor has failed, but if it has that would be the first one reported here on the forum.
    Sep 2019
    Central Texas
    No, light sensor works. Just not fond of that orange. Would have preferred blue.
    Quote Originally Posted by DanY View Post
    Looks like SilverFox has the answer. I wasn't aware of the difference since my first Spyder was a 2013 RT with the after dark orange screen.
    Oct 2017
    Las Vegas, Nevada
    Well, now I'm confused. My 2017 RTS is blue during the day and orange in the dark, like Mazo EMS2 said. Changes automatically. What did BRP do, change back and forth and then finally decide to alternate?
    2017 RTS , Blue
    Quote Originally Posted by johnsimion View Post
    Good question. I took SilverFox's answer to mean the screen turned blue after dark. Here is a quote from the 2011 RT Operator's Guide.
    The display will use a light color when
    the ambient light is bright and will automatically
    change to a darker color
    when the ambient light is dusky.
    It doesn't say what the darker color is. According to SF it must have been blue.
    Nov 2018
    Claremore, Ok.
    Isn't there a setting in the menu?
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Quote Originally Posted by Revalden View Post
    No. Just checked.
