Results 26 to 50 of 55
  1. #26
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by Valkrocket View Post
    Congrats
    Charleston...…… Velocity Power Sports?
    Yep. Good selection and trade in value. long (3 hour) ride though.
  2. #27
    Apr 2013
    Hartsville, S.C.
    Some initial thoughts.
    1. I've been riding F3's for 4 years now. I didn't necessarily feel "higher up" but the handle bars felt lower.
    2. No shake in sideview mirrors.
    3. Bluetoothing my phone on the F3 required the radio to be at about 80% to easily hear it. On the RT at 65 mph I had the radio at 25% and easy to hear.
    4. I'm 5'-11" with 32 inch inseam. With windshield at max height my eyes were about 1-2 inches below the top. No distortion. The vents let a whole lot of cold air thru. Wind was hitting my hairline. The shield tapers pretty quick and let air around the sides. Not a lot of wind noise.
    5. I was able to completely stretch out my legs to the equivalent highway peg position. If you're familiar with the F3 UFit system I'd say they span position 4. Taller than 6 feet then you're going to have to bend the legs a little.
    6. I didn't do any "twisties" but went through some nice curves. I didn't feel top heavy. I'd equate it to be at least as good as my F3 with it's stock sway bar.
    7. Heated seats and grips have 2 positions - high/low. This includes the same for the passenger.
    8. The seat has a relatively high back. I found i could lean back against it. Might not need a backrest.
    9. About 3300 rpms in 6th at 65 mph.
    10. LED lighting was excellent.
    11. Not sure about previous years but the saddlebags have a dampening piston when opening.
    12. As far as the color Fuel (blue) it looks dark in the shade but lightens up in the full sun due to the amount of metallic.
  3. #28
    Sebring, FL
    Stebrock, your windshield, believe the are two sizes, tall and not tall, was yours the tall OEM? Thanks for the bullet report, good info.
  4. #29
    Durham,Maine
    LUCK DOG!!!!!!!
    2012 RTL , Pearl
  5. #30
    Aug 2018
    Piperton, TN
    Quote Originally Posted by stebrock View Post
    This is EXACTLY the kind of feedback I have been looking for. Keep it up y'all!.
  6. #31
    Apr 2013
    Hartsville, S.C.
    This is a heads up to those that have picked/ordered their Petrol colored RT Limiteds.
    I found a paint defect on the left side of the top case. It was a circular pattern of paint droplets that trailed over the top in a row. Not easy to see depending on light and viewing angle.
    My dealer picked it up with the intention of swapping it with another one they had. It turns out the 2nd one had the same type of defect only worse than mine. They submitted a claim with BRP.
    So look real close at the left side of your top case lid. These could be the only two but who knows.
    Update: I've been told that this a defect that BRP is already aware of.
  7. #32
    Apr 2013
    Hartsville, S.C.
    Mine was the standard/stock size.
  8. #33
    Apr 2013
    Hartsville, S.C.
    I wanted to add this to my initial opinion post.
    As far as ride comfort the RT was noticeably smoother than my F3 Limited when going over railroad tracks and rough roads.
  9. #34
    Harrington, Australia
    Thanks for the feedback, Stebrock. A purchase, when they finally arrive out here in Oz, is looking more and more likely.
    Just using your best guess, do you think there would be room for highway pegs forward and to the side of the boards (I have a 38” inleg), or would the front guards get in the way?
    HeliBars Handlebars
    Kenda Kanine rear.
  10. #35
    Dec 2015
    Spokane, WA.
    Looking Good! But I'm biased. I just got word my 2020 RTL Blue/Chrome in on the truck headed to Spokane, Wa. Dealer thinks next week sometime.
    2020 RT-Limited , Petrol Metallic Chrome Edition
  11. #36
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by JackinSpokane View Post
    Make sure you look for the paint defect on the left side of the top case lid.
  12. #37
    Nov 2016
    Hummelstown.Pa.
    Congrats
  13. #38
    Aug 2012
    Central Coast, CA
    I haven't bought one YET, but I just sat on one at a dealer out of my local area. No test ride.
    The floorboards are MASSIVE and offer a ton of leg mobility. However, given your inseam length I would opine that you could affix some type of highway peg arrangement to the front/side of the floorboards. The floorboards are extraordinarily thick and beefy. The brake pedal is much bigger than the previous editions, either F3 or RT, but I don't think that would get in the way.
    2020 RTL SE6
  14. #39
    Quote Originally Posted by KX5062 View Post
    Thanks KX, much appreciated. Of course, I won’t know for sure if I’ll fit until I sit on one, and they won’t be out here for a while, but I haven’t seen or heard of any showstoppers yet
    HeliBars Handlebars
    Kenda Kanine rear.
  15. #40
    SpyderLovers Sponsor
    Nov 2012
    Twinsburg, Ohio
    Very Nice Ride! Looks great
  16. #41
    Apr 2013
    Hartsville, S.C.
    Don at F4 Customs gave me a 2019 RT to see if it would fit my 2020. It does. Exact same height but wider at the top. The OEM windshield's vents let in a lot of air. Too much when it's cold. Don's has the adjustable vent. Highly worth it. I laid the BRP windshield on top of the F4. If you look close you can see the difference. 20200205_182739.jpg20200205_182651.jpg20200205_133731.jpg20200205_130103.jpg
    The F4 pushes the wind wider to the sides. I'm 5'-11" and the wind coming over the top touches the top of my head.
  17. #42
    Sep 2016
    Clifton Springs, NY
    This is one of the questions I have had. I have the F4 28+3 windshield on my 2015 RTS and was hoping I could swap it out if I decide to trade. What size windshield in the picture?
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
  18. #43
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    Default 2020 RT Itch
    Hi all. Need some insight from you all that have recently purchased a new 2020 RT. I have got an itch and I may need to scratch it. How much do you all think I can get for 2017 F3 S Daytona with about 3500 in add-ons, it has 3000 miles on the clock?
    2021 900 Ace , Black & Gold
  19. #44
    Quote Originally Posted by Texas Al View Post
    Texas Al, it would be worthwhile starting a new thread with a new heading of “F3 Trade Value”, or similar.. There are plenty of F3 riders out there who have a good idea on trade prices, but they will probably skip over this thread as its heading is for a 2020 RT .....
    HeliBars Handlebars
    Kenda Kanine rear.
  20. #45
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    Default Congratulations!
    My new 2020 R T Limited.
    Pic taken on the way home from Charleston SC.
    Is the blue different from the older models or is it just the way the light is hitting it?
  21. #46
    Jun 2017
    Azle TX
    OK But how do I start a new thread? Never have done a new one
  22. #47
    Click on the Forum button.
    Go to the Forum you want to post in.
    Click on the thread starter. Red Oval at the top
    Put in your title and post in the box.
    Jun 2017
    Azle TX
    Thanks ARtraveler if it where any closer it would bite me. Al
  24. #49
    Texas Al, further to AR's post above - when it comes to choosing your thread title, remember that it is the ONLY way you have to invite potential readers to come on in & read your thread, so please, try to briefly ask your question in there, or at least tell those potential readers what you want from the thread.
    Your 'post title' above, the '2020 RT Itch' that you entered in the title field for post #43, is fine for an individual post (altho you should note that some readers never get to see those individual 'post titles' buried in a thread, so you really shouldn't put anything important in there when you're entering a post reply ) but if that was used as a thread title, it clearly wouldn't tell any potential readers what you're after from the thread, so there will be at least some if not many potential readers who simply won't bother to open the thread & read any or all of the posts it contains....
    So if you want to know what your F3 is worth, entering a thread title that's something more like:
    "What is my 2017 F3 S Daytona worth? Trade in or Private sale?"
    is probably going to get you a heap more readers actually opening the thread & reading on, and that means you stand a waaay better chance of getting some helpful replies! Make Sense?!
    Now, let's get back to the subject of this particular thread - Stebrock's New 2020 Ltd!
  25. #50
    Sebring, FL
    Peter, well said and I might add, without offending.
