Results 1 to 14 of 14
    MetroAsian
    Guest
    Default Tow Dolly. Okay to use with Spyders?
    Just wondering if anyone knew if using a dolly would be okay and letting the rear wheel drag and keeping it in neutral. I already have a flatbed trailer but was thinking this would be a cheaper alternative but not sure if it will mess up the rear end.
    Found this company in CO that makes dollys.
    http://americancardolly.com/
    MOgang Member xpeschon's Avatar
    Mar 2009
    Waynesville MO
    Not sure but I'm sure you will learn a bunch from the members on this forum. I took a look at the dolly and it does look good --- possible depending on the info you recieve on this threat I may have one soon. Maybe they can build a dolly that has ONE rear tire on the back so that the dolly will look like the wheels of a spyder so we don't have to worry about draging the rear tire.. What you think??
    Joe
    Motorbike Professor
    Mar 2008
    Allegan, MI
    If I recall, someone here tried to fit a Spyder on a dolly, but had loading, clearance, and width issues. Not a viable alternative, IMO.
    Oct 2007
    London, Ontario, Canada
    Default Don't do it!
    Quote Originally Posted by MetroAsian View Post
    Absolutely not a good idea. It will certainly play havoc with your wheel bearings and final drive, even if the Spyder is in neutral.
    Bruce
    Very Helpful Member bjt's Avatar
    Oct 2007
    Grand Blanc, MI
    Quote Originally Posted by Director View Post
    Bruce
    I too would be apprehensive about doing this for anything more than just a few miles, in a pinch.
    Former Happy Spyder Owner
    Just decided it was time to move onto other things.
    Oct 2007
    Quote Originally Posted by HDXBONES View Post
    The transmission is lubricated with engine oil when the engine is running......Wonder how much lubrication would be happening if the engine isn't running, and the output end of the tranny is spinning away.....
    I don't think the results would be pretty....
    Apr 2012
    Brooksville, Florida
    Default Spyder tow dolly
    The closest thing I can find is the stinger trailer. It folds and stores upright.
    Aug 2008
    MA & NH
    You saw the date on that post correct ?
    Northern Kalifornia
    Quote Originally Posted by LadyDi'sSpyder View Post
    If you go with the dolly you may end up being sorry. Go with the trailer, less chance of damaging your spyder.
    See post #3 from Nancys Toy.
    Scotty is considered a guru of Spyders.
    If he suggests no, that is good enough for me.
    Nov 2018
    Waynesboro, PA
    Hello LadyDi, Ten year old post, but we do have a Trailer area on the forum that has many threads about different trailers here is a link to one thread for the Stinger Trailer https://www.spyderlovers.com/forums/...tinger-trailer good luck in your search. DO NOT USE a tow dolly. The only way to use a tow dolly and be sure and not damage your Spyder is to remove the drive belt, way to much work and even then its hard to load.
    My Spyder
    2012 RTL , Brown
    May 2013
    Apex, N.C.
    Check out my thread called "My spyder transport system" Just may get some ideas.
    Jun 2013
    Soap Lake, WA
    I wouldn't do it.
    Apr 2013
    Somersworth, NH
    Old thread, but, anyone considering towing needs to read the operator's manual under the section for "transporting". Simply put, it says don't do it.
    2016 RT-S Special , 2 tone black
Tags for this Thread
