Dang, last week they were a must have item. ;-)
Originally Posted by 007james
This was obviously a challenge to my wrenching speed. My Rebuttal is,...don’t judge with out ..........
1) hopefully living until your almost 78 , and trying to remove all of the Panels, and Tupperware from an RT Limited to get to the Dampener.
2) searching for the correct Torx drivers to match the various Tupperware screws, after searching for the Tool Kit that has been misplaced. Then, struggling to pull out the two that presses in to the rubber mounts with out cracking the Tupperware. Not a small challenge , unless you have done it regularly. Then, trying to figure out how to take out the plastic compression lock fasteners with out breaking one, because you don’t have replacement spares as Dealers have on hand,....” some times.”
3) but before any of that is started, taking off the mirror with out breaking the top plastic mount, or breaking the clips on the bottom two mounts is also very difficult for even Dealer Techs, let alone a Do It Yourself Novice working in a dark limited space in an apartment garage with no Tools other than the Spyder Tool Kit,....AFTER locating it.
4) then, assuming all has gone well in disassembly, and the Dampener has been successfully removed,
5) “ Some One”..... has to put all that stuff back together, hopefully remembering which part has to go back on first, before the other stuff that goes on top of it lines up!! ( and that usually requires multiple removals!) , hoping none of the screws and fasteners were not either lost, or mixed up with different panels. ( Murphy’s Law)
6) Then, getting the Demon Mirror back on, .....is surely impossible with out at least 15 minutes of contemplation, Prayer, Begging,....and finally CURSING, ....before ordering a set of Magic Mirror Magnets in anticipation of surely needing to remove Tupperware Panels again, in some near future.
7) heck, I think my estimate of two hours for that Job was at least two hours less than ANY Neophyte could do it, even after spending a half hour watching Doc’s Installation Videos!!
007James
Well, the more you do it the easier it will get and you'll be a lot faster. PS Don't let the mirrors get you!
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
See how fast things change
Well with all this talk about the belt harmonic vibration dampeners failing-------- I had to go and check mine. It's in perfect shape, Roadster Renovations BTW. Rolls smoothly with NO play and original tension on the belt. It's a mod I'm glad I've done but---- also glad I checked. Now I'll check at least once a year. While down there I checked the rear tire pressure------ it had slipped to 16.5 psi with this temp drop ( 15*F outside) last night. A 30* change in a month ( average night temps) and it will cause a drop in tire pressure. It's back to 20 Psi now ( A General Alitmax).
Lew L
formerly pman2011
I discovered I had the BRP Belt Tensioner inadvertently on my girlfriends and my 2018 F3-T after installing the wiring for our heated gear connection under the passenger seat. Our Spyders were purchased from different dealers and we didn’t ask them to install the Tensioner, so apparently it came installed from the factory.
I immediately ordered two roller upgrades from Lamont. The quality of the roller he sells verses BRP is like night and day. The BRP roller feels like plastic with one little bearing and this one is rubber with double bearings.
The larger roller is from Lamont.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
There sure is quite a difference in the inside diameter measurement of the bearing of both rollers you pictured. How is that going to work out?
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
formerly pman2011
Lamont includes a bushing with the roller, you can see more pictures and a video on his store site, http://www.lamonstergarage.com/can-a...ley-lamonster/
[B]
Originally Posted by AY4B
Big shout-out to AY4B for bringing this to our attention. Checked my RR tensioner and found roller detached from one bearing and coming apart on one side. Would soon have caused belt damage for sure. Removed it yesterday and will throw it away - not worth the worry of a roller on my belt. 18 months old and about 12,000 miles. Money wasted. Everyone should check these carefully and often. Thanks again to AY4B.
2014 Cognac RT Limited #185 (destroyed in T-Bone wreck 3/21/2014)
2014 Cognac RT Limited #5333 (replacement 5/16/2014)
2018 Champagne RT Limited #1002 (traded 1/31/2018)
12,000 miles?!! That is only half of what Doc said the warranty was. Glad you caught it. If anyone continues to use their RR tentioner the roller needs to be replaced with every oil change IMHO. Thats probably true with any brand.
2017 F3 Limited
I would not even trust it for the 9,300 miles between oil changes!!
To be fair, all experiences ”should” be shared, in order to choose who’s Dampener to install and use, if any. As I recently posted on this thread, after seeing the photo of the damaged Belt, by a failed RR Roller, I removed my RR Dampener from my RT Limited. As I posted, the Roller still rolled, but not with out binding, and the Spring felt much weaker, i.e. much less tension than when I first installed it after the first one broke. But what I failed to share was how many miles the RR Dampener had been installed on my RTL. I first installed it at 1500 miles, and the spring lasted about 1000 miles before breaking. I installed the new replacement Spring at around 2500 miles, and just removed the entire Dampener at around 38,000 miles. So, the RR Dampener “ should” last 25,000 miles, but I would not vouch for its usefulness , if any, after the first 5000 or so, after installation. As I said, I never ever got rid of my Belt Chatter, with, or with out the Dampener. But another thing I want to report is, since removing the Dampener, the high pitched Whine I always heard from the front left Sprocket area has almost disappeared, so I now believe that Whine always was created by the spinning of the small Roller Bearing of the Dampener, and not from the Sprocket Splines. Caveat Emptor!
007James
I have never understood the need to apply pressure to the idler pulley. I set mine to barely clear the belt when not on bike.
I have close to 20 thousand miles on my BRP idler and have no complaints - so far.
I have modified some parts but still use the single bearing roller.
To me it is amazing how something can be "better than sliced bread' today and when someone reports a problem with one , people come
out of the woodwork with negative responses.
We all have problems with our bikes - some worse than others.
Please don't stop reporting problems - everyone benefits by learning from them.
My 2 cents worth,
Tip
I have the updated brp damper (stronger spring) with lamonsters roller. 11k miles on my 18 F3L. Still going strong. All I know is without it my belt vibs bad around low 70 mph. With it only a very little vibe on decel only for a second over 70 mph. My belt is at lowest tension spec. I keep an eye on it regularly. So will continue to use it. If the roller gets loose I will buy another. Nothing last forever.
I’m getting a strong vibration at 77 mph (2019 F3L) which isn’t a huge issue under normal riding conditions. However, there are on rare occasions when I want to reach this speed on the highway.
Pretty sure it is a belt vibration and the dealer seems to agree but I’m going to take it in for them to take a quick look anyway. The bike is still under warranty so I guess now is the time. If it is in fact determined to need a belt dampener is it reasonable to expect this to be covered under the warranty? For some reason I suspect not.
Even if a belt dampener is needed I may hold off for awhile given some of the issues mentioned on this site concerning the belt dampeners.
Look at purchasing one of these and I doubt you'll have any problems...
https://www.smoothspyder.com/belt-tensioners/
Reason: Fixed quote display
I lowered the drive belt tension below what BRP has posted for it .... I don't have noticeable vibes ..... I don't have a belt tensioner either ... annnnnnnnnd I don't worry that the roller can Fail and ruin a $350.00 belt ..... good luck .... Mike
Follow-up. I did meet with my mechanic and he did take the bike for a test drive. He agreed that the vibration was from the belt and that a belt tensioner would be of some help.
Knowing that the belt is likely the issue and not any other major cause I think I can live with this for now. So far I have only needed the 77-80 mph speed on the interstate passing in the fast lane. This does not happen very often. I may rethink this issue if I plan an extended trip requiring a lot of interstate travel.
Poasttown
Poasttown
If you find that you have to go to the dark side and put one on, just make it a habit to check the bearings in the wheel when you check your oil, or make it one of your check points before a ride! If you give it a spin and it feels dry, well then you know there troubles ahead, and do some thing about it before you smoke a belt!! Myself, I like to keep it simple know and live with some things!!
