Results 1 to 20 of 20
    Jan 2019
    North Carolina
    Default Taking antenna off.
    Hi folks, 2013 RTL.
    Went to take the antenna off to put a cover on and Mark the place for the hole.
    Won't budge!
    It's not a backwards take off is it?
    No it's lefty loosey , but BRP has cornered the market as far as LokTite use is concerned …. a 7mm socket gripped with vice grips will get it off …. First I would put a bit of " thread breaker " like PB blaster …. and let it sit overnight.... then use the socket with vise grips..... after you get it off clean that crap off. outside and inside , and just use a small star washer, your reception might get better now also ….. good luck … Mike ……..PS it's always a good idea to say what Spyder you are working on
    Sep 2018
    Caledonia,Ontario,Canada
    If you get any movement in the threaded stud holding the aerial keep moving it back and forth to build heat in thread locker. It will eventually let go from heat generated. It is blue Loktite so it will come off. Take your time. I did away with the whip and used a stubby. No need for holes!
    Jan 2019
    North Carolina
    Nobodyjj, where would you get a stubby antenna please?
    Sep 2012
    Stetson, Maine
    I got my stubby antenna from Walmart. Works as good as OEM. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Vermont
    Quote Originally Posted by Jackhartjr View Post
    Hi folks, 2013 RTL.
    Won't budge!
    Use a 7mm socket to remove the antenna.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jul 2018
    Columbia,Tennessee
    Hi folks, 2013 RTL.
    Won't budge!
    what kind of cover is it?. The one I have had the holes in it for the antenna.
    Durham,Maine
    Some of the sponsors on the web page have them!!
    2012 RTL , Pearl
    Jan 2019
    North Carolina
    Two cats, just a rubber cover. Once that comes off, the fun begins.
    Thanks for all of the replies.
    I'll get some PB Bladter, let that soak in until next weekend, then run the 7mm sockets down the antenna, and get it off.
    Then replace with a stubby!
    Y'all are awesome!
    To much Loktite if you cannot get it off.
    Walmart used to have the shorties for about $10. They do work just fine.
    I had the opposite problem. No Locktite, and the antenna fell off. I used the shorty until a new replacement came in. It was on "their" dime...so I went back to OEM.
    Jul 2018
    Columbia,Tennessee
    Amazon has shorty 7 inch antennas with the rubber boot cover. Look under can am spyder rt accessories.
    Jan 2019
    North Carolina
    I just ordered a stubby from Lamonster. Nothing like keeping it in the family!
    Thanks for all of the replies!
    Jul 2010
    Las Vegas, NV
    You can always park a little close to the garage door, hit the button, and a broken antenna will be on the floor in the morning! The stub comes out with a7mm socket.
    Joe Meyer
    Quote Originally Posted by cptjam View Post
    ^^ Yep, that'll do it!
    Or you could just hang a small flag off the top of the OE Antenna & go for a ryde It really won't take too long for the antenna (& flag) to just disappear leaving that stub that you can take out with a (deep) 7mm socket!
    More'n just the one way to skin this particular cat!
    May 2018
    Chateauguay, Qc, Canada
    Check this out.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Durham,Maine
    Thank God I didn't have to go threw all of that to change out mine! The only thing I would not do is put the Loctite on the treads! The cleaner you can keep the surface and threads the better your radio will work, if there's a shoulder on the mating pieces put a star washer on there! Good Luck!!
    2012 RTL , Pearl
    SoFlo
    I doubled the fun...dual antennas
    Mar 2013
    I have that T-shirt!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jul 2010
    Las Vegas, NV
    LOL! Misery loves company!
    Joe Meyer
    Sep 2018
    Amazon,6 inch carbon fibre, several adaptors included. Smalll drop of blue locktite..
