Results 1 to 7 of 7
    Jun 2019
    South Bend, IN
    Default Changing Display to show MPH not Km/h
    All,
    I just purchased a 2019 F3-S, and some how changed the speedo display from MPH to Km/h. Owner manual is not providing and instructions so I need your help to set it back to MPH.
    Thanks!
    JABPA
    Feb 2019
    Portland, Oregon
    No sure about the '19 screen, but on my '17 I tap the MODE button until the PREFERENCES screen appears. Then scroll to what you want.
    Florida Swamp
    Display Settings
    Setting Metric/Imperial Units
    1. Push and hold SET button on the
    RECC for three seconds.
    2. Push _down arrow_ to select KM,
    push up arrow to select MI.
    Setting Clock
    1. Press LEFT or RIGHT arrow button
    to select clock display.
    2. Push and hold DOWN arrow button
    for three seconds.
    3. Press down arrow to select 12:00
    AM PM or up arrow to select 24:00
    time base.
    2019 F3-S , Black & Silver
    Jun 2019
    South Bend, IN
    I believe those instructions are for the old 2018 displays, this is 2019 display and has a toggle/button
    Nov 2015
    Chardon, OH
    Quote Originally Posted by JABPA View Post
    In the 2019 manual, page 34. Unit Selection.
    Doug
    ”Freedom is not a loophole”
    Florida Swamp
    Quote Originally Posted by Gwolf View Post
    Display Settings
    Setting Clock
    for three seconds.
    time base.
    __________________________________________________ _______
    That is from 2018 pdf manual. The printed manual for 2019 F3-S says go to Settings, then find Units, and hold the button to change the Units between
    klicks and Miles.
    Be sure you hold it for 3 seconds to make it go into change mode.
    When I originally downloaded the shop manual the 2018 owners manual was in the back of the pdf shop manual. It was not yet available for download on the BRP Manuals website. It is there now. I just downloaded the pdf version of the 2019 owner manual.
    The 2018and the 2019 manuals are pretty much the same on most things. The wording is a little different, but the basic operation is the same. I reset mine and changed the clock using the 2018 manual.
    Jun 2019
    South Bend, IN
    That worked, Thanks all!
