Results 1 to 12 of 12
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Default For those of you using an Airhawk cushion....
    OK, Gracie's seat is way too hot this time of year. Looking at airhawk seat cushions and would like to know which model (Airhawk R or Airhawk 2) is the preferred model for a spyder rider. It appears that one is air adjustable and one is not.
    Also which size (Lrg. or small for the passenger seat) fits best.
    Thank you in advance for your words of wisdom.
    Glide-on>>>>>>>>>>>>>
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Mar 2012
    Beaverton, Oregon
    The R model is made specifically for men. The air bubbles are placed to give a bit more room for "The boys". My wife uses a 2 model.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Sep 2018
    Sneedville, TN
    Have you looked at Motorcycle Dave's medical gel pads?
    https://www.spyderlovers.com/spyders...cledave.com%2F
    Any model will work...but see R model above.
    I have used the older Medium and it works fine for me on the Spyders. Inflation is the key. You are supposed to sit "in" it and not "on" it. Once you get that figured out, it is a great pad. And yes, it will protect you from the heat if you don't let it bake in the sun also.
    Sep 2016
    Chillicothe, Oh.
    If the hot seat is the only issue then a sheepskin cover will help with that. I have an airhawk R and my wife prefers the sheepskin cover on the passenger seat. If you get the Airhawk remember it IS NOT a beach ball. Start with just a couple of big puffs of air and adjust from there. It should look and feel flat, but just a bit of air works perfectly. Lots of folks over inflate and then don't like the ride which is fine with me because I have bought several Airhawks pretty cheaply when they claim the pad didn't help and then they sell it.
    2015 RT , Black
    Sheepskin is also a good alternative. We also have sheepskin/gel. The hype about sheepskin (I used to sell car and motorcycle seats) is it keeps you cooler in the summer and warmer in the winter.
    Lots of places to get them. Just search sheepskin seats on here. P. S. Get the real stuff. Artificial does not retain its thickness very long.
    Be wary of "genuine, simulated, sheepskin."
    Active Member Bike-O-Din's Avatar
    Apr 2012
    Cross Junction, VA
    I understand the shape of the R is for the "boys", but the R cushion really seems to fit better on the pillion seat on our RT. With the shape of the cutout, it fits around the "hump" between the seats. My wife tired both, but likes the R better as a passenger. We use the medium R cushion front and rear.
    Yes, adjusting the air to ride "in" the seat not "on" the seat is the real key. It takes some fiddling, but it worth the effort.
    2011 RT-S , Silver
    Nov 2015
    Nebraska
    I’ve got an air hawk that I use in the cool months, when it’s summer time, I take it off and put a bead rider on. Wife and I both love it, not sure how it works, but it does.
    Linden, CA
    Take a look at this,
    give me a call 209-887-3283 this is an easy do it your self way to fix that seat
    AND nobody can steal it.
    Ride Safe
    Dave
    Quote Originally Posted by Valkrocket View Post
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Default Re Gel Cushion
    Ride Safe
    Dave
    Only one problem some of us are not do it yourself people
    Aug 2019
    Pilot Mountain, NC
    I had an Alaska Leather pad on my motorcycle. I plan to buy a new one for my 2019 F3T.
    Bryant, Arkansas
    AIRHAWK R for best results
    Cruzr Joe
