Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
  1. #26
    Nov 2014
    Hammond LA
    Well said Ron. Was wondering if you can clear something up for me? Which type of trans does the Ryker have ? As on my 2011 RT 5 speed or 2014 RT 6 speed ? I hated keeping up with revs and tacs much less the fuel mileage on the 5 speed.
  2. #27
    Jun 2012
    Nevada
    The one main factor for not very good mileage with the Ryker
    and the Spyders is the Rotax engine.
    It develops it max horse power at high rpm and that is where
    it runs best and gets it best mileage. Lugging this engine
    at low rpm and the mileage will suffer even more.
    The Rotax and the auto trans in the Ryker were made for each other.
    Even though its not the most fuel efficient engine it is a proven
    bullet proof design for its small size that will take a beating.
  3. #28
    Nov 2018
    N.E. Ohio
    I ryde it, take care of it, and enjoy it. My last mileage reading nearly 35mpg. cueman
  4. #29
    Ft Pierce/Lk Placid
    Quote Originally Posted by leenanj View Post
    Only time will tell if this notion is indeed correct.
  5. #30
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by NU2Spyder View Post
    It's a CVT, twist the throttle and go. No shifting.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  6. #31
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by Aufgeblassen47 View Post
    He may have been talking about the similar motors used in the snow machine and ATVs. They seem to be able to take a licking and keep on ticking. cueman
  7. #32
    Jun 2012
    Nevada
    Hardly a notion, the Rotax engine has been around since the 1920's.
    Used in autos, aircraft, quads, snowmobiles, motorcycles, you name it.
    One tough little engine that like to rev and work hard.
  8. #33
    Ft Pierce/Lk Placid
    But they run at rediculously high RPMs at any speed!!!
  9. #34
    Active Member IdleUp's Avatar
    Jul 2008
    Hey guys - Since CVT drives are new to a lot of bike riders, here's a fairly descriptive video on a CVT drive.
    While this differs from the BRP clutch, it shows the same working principles. While these clutches are simple in operation, on motorcycles they have always been prone to problems. Unlike a gear box transmission, the CVT drive require maintenance on a mileage schedule.
    Enjoy- Mike
    https://www.youtube.com/watch?v=xHWqlfDZnmQ
    Military Drone Designer & Pilot
    www.rotory.com
  10. #35
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I admit that I was surprised to find out BRP used the same final drive ratio on the 600 and 900 CC models. On all of my other shaft-drive bikes (BMW) the smaller motor models used a higher final drive ratio (higher RPM at a given speed) than the same model with the larger motors. The ROTAX engine produces a relatively flat torque curve and would operate more fuel efficiently at 1,500 RPM's lower at highway speed.
    2019 Ryler Rally , Shock Yellow
  11. #36
    Johnson, Vermont
    I have been riding snowmobiles with the same clutch(es) found on the Ryker for about 30 yrs. They have been trouble free, dare I say bullet proof under some very harsh weather and riding conditions. Only maintenance required is a belt change and quick cleaning. That can be done in 5 minutes on a sled. It will take a bit longer on a Ryker because of housing covering that area. This type of CVT drive system has been used since the 60's that I know of on all types of recreational vehicles. My experience started in the 80's with them. Sleds, quads, sxs, etc from a number of manufactures, not just BRP use this set-up in outside air temperatures from -40 to over 100 degrees on vehicles that travel through, water, mud, dirt, snow, ice. It's very rare users of these vehicles say, I blew my clutch. The entire clutch system has very few parts and even fewer moving parts. They are used in the powersports business specifically because they are known to be reliable, effective, easy to service and cheap. I think they have proven their reliability over the years.
  12. #37
    Jun 2012
    Nevada
    Quote Originally Posted by Rob Rodriguez View Post
    I agree, the clutch system is nearly bulletproof.
    They take much more abuse in an off-road machine than it will ever see in the Ryker.
  13. #38
    Active Member Dragracer's Avatar
    Oct 2009
    Lecanto, FL.
    129.1 miles today, 33.4 mpg.
    Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
    2019 900 ACE , Stock Black
  14. #39
    Dec 2018
    NY
    My wife reports being comfortable on the rear seat. We have the passenger comfort seat with the high folding backrest.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
  15. #40
    Kansas
    Quote Originally Posted by Jsmith8695 View Post
    My wife absolutely hates it with the same seat and backrest. I will admit the Ryker seems a little tippy riding 2 up
  16. #41
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by KC61 View Post
    I have the Rally and ride 2 up quite often and have never felt tippy. Do you have the Rally version?
  17. #42
    Nov 2018
    N.E. Ohio
    Rally with no tipping feeling. cueman
  18. #43
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    If you want good mpg then buy a Honda PCX-150 I had 2 of them that my wife and I used to ride 110+ mpg over 200 miles on a 2.1 gallon tank and they would run out to the limiter at 73 mph
    2022 RT Limited , Silver w/ Black and Purple accents
  19. #44
    May 2019
    NY
    Almost 1700 miles on my 900 ace and I get 31-36 mpg in sport mode. I do have a heavy hand and considering that I’m totally happy with that mileage.
  20. #45
    Ft Pierce/Lk Placid
    I just bought a VW Touareg TDI. It is a pretty heavy SUV, not as aerodynamic as a car, and has a 240 HP 3.0L V-6 engine. I'm getting 33-35 MPG, so a little HIGHER than my Ryker. Crazy, eh?
  21. #46
    washington state
    now you made me thinking about putting jetta engine on my spyder.
  22. #47
    Quote Originally Posted by jerpinoy View Post
    I don't think you can do that now. Weren't they the ones that were programmed to override the EPA standards, and VW got dinged for it?
    May 2019
    NY
    Turbo diesel? 30+ mpg doesn’t surprise me. My Audi is a 2.0 turbo that is tuned with mods and will do 30+ as long as I’m not making boost.
  24. #49
    Ft Pierce/Lk Placid
    My new VW was bought from a VW Dealership (that got it directly from VW). It is immaculate inside and out, had only one owner, is a 2012 Touareg TDI Sport with 80K miles that was never exposed to road salt (judging by CarFax) for only $15,800.
    BTW: It was bought back by VW a full two years ago and was in storage until they came up with "the fix", so effectively it was like buying a 2014. The funny thing is, after driving 250 miles, the check engine light came on, and when I read the code, it said it is putting out too much NOX!!! Perhaps their "fix" could only last temporarily, long enough to pass EPA???
