Results 1 to 9 of 9
Thread: Clutch
    Mar 2019
    California
    Default Clutch
    2008 Spyder manual transmission, when the engine gets to operating temp the clutch dies, when the engine cools down then clutch works again? What gives?
    Northern Kalifornia
    If you have a cable, check the slack. If you are hydraulic check the reservoir fluid.
    Mar 2019
    California
    I have a hydraulic clutch, fluid is full, no air in the line. The clutch goes to nothing only when the engine gets hot, then goes back to normal after the engine cools down
    Last edited by Peter Aawen; 04-04-2019 at 02:57 AM. Reason: Corrected spelling - inly/only & gors/goes :-)
    What oil are you running?
    Mar 2019
    California
    BRP XPS synthetic oil
    Last edited by Peter Aawen; 04-03-2019 at 09:14 PM. Reason: Fixed the quote display
    Oct 2015
    Lynden, WA
    Sounds like the problem I had on my 2013 ST.
    Change the clutch fluid. Moisture in the fluid can cause this type of problem.
    When the engine gets hot the moisture vaporizes in the fluid.
    Change the fluid with a good flush. Get all the black out of the reservoir.
    Perform a good bleed of the clutch followed by a long ryde.
    If the problem still persists you may need to change the O rings in the clutch slave cylinder.
    Good Luck, David C.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Default What part..?
    if we are talking about the clutch lever and it's operating the plates and discs. Agree it's a good place to start .... Check the fluid by removing the cap as the sight glass is not the best way to tell. Mine operated normal but when hot would not go into gear. Pulled the cap and found the reservoir empty. You can also pull the cover to the slave to see if it is leaking...
    20170314_122933.jpg if it looks like this replace the o-rings flush the system..
    Mar 2019
    California
    I actually replaced my whole clutch/cylinder, bled the system, fluid is running clear. Still doesnt solve the problem. Can you please post the slave pic, the jpg link doesnt work. Thanks
    Active Member kdp1308's Avatar
    Jul 2018
    Wichita, KS
    My question is, what do you mean when you say, "when the engine gets to operating temp the clutch dies"? When you pull in on the clutch lever does it do nothing, meaning the clutch doesn't disengage the engine from the transmission. Does it mean that the clutch acts like the clutch lever is pulled in when it isn't, meaning the engine spins but you don't go anywhere?
