Results 1 to 15 of 15
    Nov 2015
    Myerstown, Pennsylvania
    Default Home Made Bumpskid on 2016 RTS
    I finally got the time to make a bumpskid for my RTS. I bought the 3/8 inch HDPE on ebay for $35. It was 2 feet by 3 feet before I started. Here is the photo evidence of what I did.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    …………..looks great …. I love DIY'ers ….. Mike
    x 2
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Good job!!
    Joe
    2023 F3
    Default Nicely Done....
    Did turn out great. Very clean and neat. Congrats..
    Mar 2017
    Salisbury,NC
    now you need to wrap it with LED strip lights for the BLING
    Mar 2015
    forrest above Reno, Nv
    Super DIY
    2014 RTS , Circuit Yellow
    May 2013
    Edmonton Alberta, Canada
    Another for a job well done!
    2014 RT-Ltd , Cognac
    Nov 2015
    Here is the HDPE board that I used.
    And the clips that I used.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Mar 2019
    France
    Well done - looks like a splitter I made for my OLD mini 20170204_103204.jpg
    2009 GS SE5 , Red (Ferrari Red :) )
    Active Member doncanfix2's Avatar
    Aug 2019
    MD
    Quote Originally Posted by SteveLaoyster View Post
    Sir,
    Great job! Being a like-minded DIYer I have been considering doing the same on my '18. Why the U-nuts, as opposed to the screws that seem to used on the commercial unit? Any further advice on your process would be appreciated!
    2018 RT Limited , OXFORD BLUE METALLIC Dark Edition
    Dec 2015
    Oakley Utah
    2014 RTL Platinum
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    I think this is going to be my next project for the bike. The Sypderpops version for the 2010 is out of stock (at least the cheaper version without the lights) and I'm a cheapskate at heart when it comes to mods and farkles.
    From what I can tell, the OP bought the sheet and temporarily attached it at the back with two bolts so he could trace the outline for the front. That looks to be a fairly straightforward procedure. After that, it's cut to size and smoothed out. And then the other holes are drilled and the U nuts installed and it bolts on. Again, nothing too hard.
    I may go ahead and make it out of 1/2" HDPE which might give me enough thickness to route a recess in the front lip and set some LED strips in as well if I feel the need. I just need to source the plastic first then get going. There is a local place in Norfolk that I have used before, and there is always Amazon and Ebay if that doesnt work. Hopefully this should be under 100 or way under depending on what I can find. Should be fun.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Aug 2019
    MD
    Default DIY RT skid plate
    Quote Originally Posted by Eviltwin View Post
    Eviltwin,
    Knowing this thread is rather old , I was hoping to renew the conversation and provide everyone interested with some options. For me the main reason is I prefer DIY (not that Harvey's product is deficient in any way!), irrespective of the $, its fun and I'm now a retired engineer/inventor who likes fun!
    Thus, did you ever make one yourself? Great minds think alike , thicker yes, such as to embed LED strips. From what I can discern, Spyderpops mounts the LEDs in a additional strip attached to and above the leading edge. I've made a prototype pattern using an 1/8" thick piece of polyethylene sign material but that is as far as I've gotten on the mechanicals. The material I've found in a marine grade HDPE (not certain what grade Spyderpops uses?) is made by Vycom Plastics and is available in different colors and surface finishes (not that finish is much of a concern). I also found King Plastics, but don't have all the particulars. Datasheets or website URLs (not affiliated in any way) available upon request. Gotta do something as I have had some under-body touch downs that left marks!
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Very nice DIY.
    Woops. Old thread.
