Results 1 to 14 of 14
Thread: Dead Spyder
    Jun 2014
    Southern New Jersey
    Default Dead Spyder
    Went to start my 2015 RTL yesterday, had it on the battery tender/charger over the winter. Even though we had some nice days this past winter I was side lined with a Knee Injury (that's Another story). I started the Spyder about 3 weeks ago with no problem but yesterday I unplugged the Battery Tender it turned over once then died.
    The dealer I go to is off Sunday and Mondays so I will not be able to get the battery checked or a replacement battery until Tuesday if that is the problem. Other than the battery what else could possibly be wrong?
    1. How long is the battery good for?
    2. Other than the dealer are there other places to get the batteries?
    3. what is the best battery to get?
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    I've gone to Wal-Mart and Batteries+, they're cheaper. Wal-Mart people don't usually know what they have and what it fits, so you'd have to know what battery you're looking for. Batteries+ will be able to look it up by year/make/model. Both are usually cheaper than the dealer.
    2014 RT-S , Orange
    Jun 2014
    Southern New Jersey
    Thank you
    What brand battery maintainer were you using?
    Check both battery cable connections for tightness...
    Jun 2014
    Southern New Jersey
    Battery Tender Plus......Tender + charger
    Jun 2014
    Southern New Jersey
    The connections seem tight and I use the pig tail that comes out near the front left wheel well
    Default Bummer.....
    Couple things.... if you have a jumper pack or jumper cables (if using your car leave the engine off) you can jump start it and see if it is only needing more voltage. Then if you have a voltage meter you can check the voltage and the charging rate to make sure all is well. If not and you get it started run by your local autopart and have it tested. Batteries last, in most cases depending on acc and use, 2 to 7 years. The best battery is the YUASA..in my opinion and experience, but there are others out there that will do the job...
    Bryant, Arkansas
    Feb 2019
    Portland, Oregon
    If you order online for a store pickup, you get a 10% discount, which makes this one $90. CCA (cold cranking amps) is 350, that's very strong. I like their terminals, strong and versatile. If I selected correctly, here's yours....
    https://www.batteriesplus.com/batter.../cyla24hlbsxta
    This factory fill battery is the consensus best one for Spyders by those on SL with a lot more experience than I: Yuasa YUAM7250H YTX24HL. You can get on Amazon.
    Jun 2017
    Hanmer, Ontario
    Check out Shawn Smoak's video on batteries...he strongly recommends the BRP batteries(Absorbent Glass Mat). A cheaper lead acid battery might cause you problems.
    Jul 2010
    Las Vegas, NV
    We did 2 of them yesterday. Batteries plus had Duracell in stock. Sealed AGM battery. We find that batteries last 2-3 years. Anytime after year 2, if it gives any trouble, replace it. Piece of mind is huge! Joe
    Joe Meyer
    Default Batteries
    I had a Yuasa ( un-filled ) waiting for my 5 year old battery ( For a 2014 RT ) to die …. well it just did so I filled mine new one with Acid and put it on a 2 amp trickle charger ….. 24 hrs later ( or maybe less - I was sleeping ) it's now ready to re-place the OEM one …… I think 5 years is a decent longevity …… Mike
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Quote Originally Posted by Commander View Post
    Check the fuse on the lead that connects to the battery. Mine was plugged in all winter and the light was green but the battery was dead as a door nail. Some of the older Battery Tenders would give a false reading on the light. Finally I found the fuse was blown so I charged the battery with a regular charger and no more issues.
    2022 RT Limited , Silver w/ Black and Purple accents
