Results 1 to 25 of 30
    Active Member Clary's Avatar
    Feb 2015
    Nova Scotia canada
    Default Rear tire queston
    Will have to purchase a new rear tire for the upcoming season. Has anyone tried the general altimax RT43 radial tire 215/60R15. Would it do any harm to install this car tire to the spyder?
    By the way I ride the 2014 RT Ltd. thanks.
    Quote Originally Posted by Clary View Post
    I discovered that tire years ago and have been recommending it here ever since ….. But in all honesty it's not the best spyder tire anymore …. the Vredestein Quatrac 5 , now holds the title. Michelin has re-designed the great " Defender " tire ….. It's now the Defender " T&H " model...…. that's #2. on my list ….. PS If you are putting an Auto tire on the rear of your Spyder ( any brand ) I & Peter Aawen highly recommend using 17-18 psi in it for Best performance ie. traction wet & dry , comfort , and mileage …… good luck …….. Mike
    Nov 2012
    North Las Vegas, NV
    The Altimax is a fine tire and will not harm your RT.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Mar 2015
    forrest above Reno, Nv
    Many folks here have the General Altimax tire on their 's and are pleased with them.
    2014 RTS , Circuit Yellow
    Oct 2015
    Lynden, WA
    I have the Altimax on my ST.
    Its a great tire.
    Its also is a diameter that corrects the Speedometer to match my GPS.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Nov 2017
    San Francisco Bay area
    Ditto on my RTL
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Sep 2016
    Chillicothe, Oh.
    15,000 miles on my Altimax and it still looks and rides great. 90% of my riding is two up and 22 PSI seems to be the sweet spot for me.
    2015 RT , Black
    Aug 2017
    laurel, mississippi
    I had the General Altimex installed on my 2017 RTS at 15,000 miles. Love it
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    Just put one on my 2012 rts
    Apr 2015
    Tucson, AZ USA
    I like mine just fine.
    Rob
    Dec 2012
    Murphy, NC
    I installed the RT43 on my '15 F3-S after I could not find the Michelin Hydroedge anymore. Only have 5,000 miles on it but am really liking it!
    2020 F3 Ltd
    Spyderpops Bumpskid
    Feb 2015
    Nova Scotia canada
    Thanks for all the info guys and gals. I feel confident now to go head and install the general tire. Great site for us non mechanical people. Thanks again, ride safe.
    Jul 2013
    Brights Grove, Ontario, Canada
    what was the size of the altimax tire for 2017 F3-S
    2017 F3-S , circuit yellow
    Quote Originally Posted by Doug View Post
    215/60-15 …… annnnnnnnnnnnnnnnnnnnnd it will make the speedo & odo closer to correct ….. Mike
    Vermont
    I am also running the general Altimax RT 43 tire on the rear of the spyder. I have at least 16,000 miles on the General. I have 22,000 miles on the spyder.
    I'll purchase on other general Altimax tire next month.
    I have a 2014RTS-SE6 Spyder.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jan 2015
    southern WI
    Its a great tire...had one on the 2010 RT and now again on the 2016 RT
    2016 RTS , Pearl White
    May 2017
    Mesa, Arid-Zone-A
    I run that tire. Have a little over 15K on it and by the looks of things, I should get another 10-15K miles..... Jim
    Semper Fi
    Quote Originally Posted by canamjhb View Post
    You should PM " Deanna777 " She is planning to change Hers at 16,000 mile s.....I doubt it needs changing …… jmho …. Mike
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Good roll and as others have said the 60 profile gives a little more circumference and puts the speedo within 1 MPH of the GPS at 60 mph. I got 23,500 miles out of the last Kumho Ecsta on my RT, but the General Altimax on the wifes F3T only had 18,500 when I took this picture last July... General18.5.jpg
    We ran it for another month and took it off with just under 21,000 miles. We Have a couple more Generals on now with less than 10,000 miles.
    We have been satisfied with the wear and ride from both the Kumhos and Generals on the rear..
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Vermont
    I have 22,400 miles on the spyder.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Deanna
    ...…….However the amount of miles on the Spyder is only relevant if the tires are the ORIGINAL ones …………….. you stated the Generals had approx. 16,000 miles and that's the number that is meaningful ………………. Mike
    Vermont
    The rear tire is the ORIGIANAL General Altimax RT 43 ( which was installed in 2015,).
    Thanks!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Thanks!
    Deanna
    …. omg !!! ………. The " original " tire was what came with your Spyder - - - it was a Kenda !!! …. you replaced it with the General ( at my suggestion ) …. at about 6,000 +/- miles …….Your General NOW has about 16,000+/- miles ( you said this ) and plan on re-placing it ….. At about 16,000 +/- miles that is ( by far ) the LEAST amount of miles reported for needing a change for the Gen Altimax RT43 ….. just trying to clarify things here ….. Mike
    Vermont
    I know the Original tire was a Kenda, Yes I did replace the General ( per your suggestion), yes I did say that.
    Hope that clarifies things.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Deanna
    Yes this post does clarify something that I have suspected for years ...…………….Mike
