Sway bar question.
When I got my 18 F3L, I installed my stock 2015 RTS sway bar on My F3L. Looking at a F3 Baja Ron bar at a local dealer. The stock RT bar and F3 Ron bar seem to be the same thickness. It does handles better with RT bar. My question is would a Ron bar be stiffer or handle better than the RT bar. Has anyone here had both an RT bar and then a Ron bar on an F3. Did it make much of a difference.
You can not go by the thickness as the F3 bar is the same thickness as the RT bar - yet you noticed it handled better with the RT bar.
The same goes for the Ron bar. It's the same thickness as my RT bar, but when I installed the Ron bar on the RT I was able to notice the improvement.
I just put the Ron bar on my 2015 F3, but being winter locked I will not be able to experience the difference for awhile.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
The F3/RS/RSS/ST BajaRon bar, though the same diameter as the OEM RT bar, is stiffer. There are 3 parameters which comprise the end function of a sway bar. The quality of the spring steel used, the bar and arm length and the diameter. Bars of the same diameter are only equal if the other 2 parameters are the same.
My stock F3L bar is half the thickness of the stock RT bar.
I went off the bar from my F3s and compared that to the one off my RT, and they are the same. I am surprised the F3L is less thick!
I am surprised to being the RT and F3L are only about a 25 pound difference. But mine corners a little better. But not a lot. That is why I'm asking about the Ron bar. I had the Ron bar on my 15 RTS but it was thicker the the stock RT bar. It was a night and day difference in handling.
I had a Ron sway bar on my RT and Ron told me himself that the RT bar would not fit on my F3..... hmmm
RT bar and bushings fits F3L just fine.
Les, I wonder if someone had already installed a RT bar on your F3S. My stock sway bar on my F3 and my Daytona we're both smaller diameter than the stock RT bar.
There is some confusion about the different sway bar options. And frankly, some bad information as well. I think this is always the case with any product.
These are round numbers but close enough for the discussion.
The stock F3 bar is 9/16" diameter. The stock RT bar is 5/8" diameter.
The F3 BajaRon Bar is 5/8" diameter (essentially the same as the OEM RT bar) and this is what gives the impression that the OEM RT bar will function the same as the F3 BajaRon bar.
The RT Bajaron Bar is 11/16" diameter. I won't go into the other important sway bar parameters as I've already covered this in a previous post. With a bar this small a very small amount of difference can make a great deal of functional difference in the way a Spyder handles.
Those who have gone from the OEM RT bar (installed on an F3, etc.) to the BajaRon bar have noticed significant improvement. Of course, not as much as going from the OEM F3 bar to the BajaRon bar. There is a money back guarantee on all BajaRon sway bar kits if you are not satisfied with the improvement it gives you.
This may have been a misunderstanding. I have never told anyone that the OEM RT bar will not fit the F3, as obviously it will.
What I do tell customers is that you should never install a BajaRon RT Bar Kit on anything but an RT (though it will physically fit other Spyder models). This is because too much sway bar can be dangerous. A too stiff sway bar will handle amazingly well under good traction conditions. But as soon as traction conditions are less than ideal, you may get out of shape and lose control with a too stiff sway bar. For example, wet roads, sand, etc. Though you will lose some handling improvement under ideal conditions with the correct stiffness sway bar, it will not give you this negative downside in poor traction road conditions.
Race cars have tune-able sway bars which can be perfectly matched to tire traction and current track conditions. But a street sway bar needs to work well in any and all possible conditions. This is why it is important to install the correct bar kit on your particular model Spyder. The right sway bar correctly installed will not only make your Spyder more fun to ride. But it will also make it a safer ride. And that is what we all want.
If anyone has any questions about the BajaRon bar kits or anything else I carry, I am always happy to give you as much information as I can. Customers who know the facts are much more likely to get what they want the first time. And much more likely to be satisfied with the results.
I hope this helps.
Mike,
This must be the case as I assumed (an we all know what that means) that since it wasn't a Ron bar on mine - that it was stock.
My apologies to everyone for my miss-information!
Les
Mike,
Les
Just don't ever do it again!
Can someone clarify the differences and pros/cons of the various links available?
Thanks, Rick
Sorry I didnt say the OEM RT sway bar I said the BR RT swaybar. but exactly what you said about safety you also told me.. makes sense now.. thanks.
Ill be getting a sway bar from you soon. Just trying to find the best place for shipping to canada. everyone I look at is extremely high imo...plus the $$ is crap right now for us up here
thanks
Stiff
Thanks, Rick
the stock plastic links wear and can break, especially if paired with the better stiffer swaybar.
the one thing I will say about the baja ron links tho is after a while they will start to squeak. So if you hear a squeak from the front suspension and you have those, give them a shot of grease...just FYI
Stiff
Does anyone know a dealer in the Minneapolis area that will install bajaron bar on a 2015 F3S? I asked one dealer and they said they could not because of some BRP rules or something.
I do not have a list of dealerships who will install a sway bar kit. But a dealership who makes a statement like ... 'they could not because of some BRP rules' is not being honest. There are Can-Am dealerships all over the US and Canada who put my bar kits on customer's Spyders all the time. Some dealerships have put my bar kits on floor demo units because they say they help sell the Spyder.
You do not need a Can-Am Dealership to install a sway bar kit. Any decent mechanic can do the job.
Look around. I'm sure you can find someone who will do the job for you. It's not that difficult. A good number of customers have done the job themselves.
Caswell's in Mora will. If that's to far for you send me a PM and I will.
Les
thanks
Stiff
https://www.canamspyderaccessories.c...yder/sway-bar/
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
If it was a 2012 or earlier, they aren't close.
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
Les
Les & BajaRon - thanks for the feedback. Now I just need to convince my better half it is worth the investment while she sits on the back seat!
The passenger usually notices more improvement than the driver with a sway bar upgrade. This is because they sit higher and, for them, the lean is exaggerated. So they also tend to notice greater improvement.
