Results 1 to 8 of 8
    Dec 2018
    Albert Lea, MN
    Default BRP Connect/Radio Version ??'s
    I'm having a problem getting BRP Connect to load to the infotainment system on my 2018 F3 L. I asked the dealership to make sure that it had the latest version. I was insured it did. I knew it would be needed as my F3 was built in January of 2018 making it one of the early ones (#399). I was able to get my iPhone 8s paired with no problems. Had the phone plugged into the USB port in the glovebox. After 10 minutes of it saying that it was "loading" I unplugged it and turned the trike off.
    Two questions.
    1.How long does it take on average to load MAPS?
    2. See the picture below. Is this the latest version?
    2018 F3 Limited Dark , Stock Intense Red Pearl
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    NO, not the lastest version.
    Where on your display it says 10.05, it should be 13.20.
    2018 RT LTD , Black
    Sep 2018
    greensburg,pa
    Heres my 2018 RTL and I dont know the time it takes to load maps.
    2018 RT-L , Blue
    Aug 2013
    SF Bay Area
    The maps are loaded into the phone and all the bike's dash does is show it in the one half of the screen. So as fast as it loads on the phone will be the same when connected to the bike. Your current version would need the phone connected both with cable and BT, unlocked and BRP Connect open when starting the bike. Once you get the dash updated you still have to be cable and BT connected and unlocked. The bike will open BRP Connect.
    2021 F3 Ltd , Magna Red
    Dec 2018
    Albert Lea, MN
    Thanks all!
    Dealerships program shows that they did the update, but obviously something went wrong. I found a thread about this and forwarded it to them. Anyway, they will of course fix it.
    Jul 2018
    Long Island NY
    Morning Ken. After u download the apps to your phone, open each app on your phone and go through set up process. This has to be done on phone for each app. Then when u open BRP Connect on your phone, each app should be displayed. If the app is grayed out, w a key icon covering it, you have to do more set up on phone. After all apps u want show full color icon, you’re good to go. Also check out YouTube, tons of great videos.
    And since your F3 was early production, and you have to bring it to your dealer anyway; to get 13.20- ask them to run your VIN through the BRP system, and have them look for BRP Warranty Bulliten 2018-005. Some 2018’s have problems w “Left Hand Multifunction Switch “. After riding for a few months you will not be able to downshift or go in reverse. It starts out w it not downshifting from time to time to full failure. They can check your VIN, and if yours is listed, they will replace the Left Hand Multifunction Switch for you for free (of course). This will help avoid future problems and frustration. I believe I have a pic of the warranty Bulletin on my page.
    Good luck, enjoy the new ride!
    2018 RT Limited , Metallic Champagne
    Jul 2018
    Long Island NY
    Default Warranty Bulletin 2018-005
    I found the pic of the bulletin. It's a lot easier posting pics on PC than iPad.
    Jul 2018
    Long Island NY
    BRP Connect new version.
    Good news Ken. I just spoke w BRP, there is a newer software version than 13.20
    The new version is 20.3 so when you go to your dealer ask for that update. Can’t wait to see new update.
    Good luck.
