Results 1 to 6 of 6
    Aug 2018
    Tennessee
    Default 2015 st headlight change
    Anyone changed headlights out to LEDS on 2015 ST if can you provided info or vidio?
    Jul 2018
    So Cal
    You can get the fan type in after you pull the Instrument Panel. Small and/or young hands, help. The big mushroom looking passive heat sink type won't fit around the bails. (Ask me how I know this). Your illumination pattern will change. For me a big improvement over the Halogen fireflies.
    2015 STS , Bajaron Black/White/Red
    Oct 2015
    Lynden, WA
    Default LED headlights
    I installed LaMonster LED headlights in my 2013 Spyder.
    Definitely take the instrument panel off.
    I took off the windshield also.
    Small hands help to attache the bulb clamps.
    The LEDs are pre clocked so filament rotation alignment is not an issue.
    For me the only issue is the projected height of the light pattern.
    I have to significantly lower the light beam at my next major mechanical service.
    The illumination of the LED lights is worth the effort
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Aug 2013
    SF Bay Area
    If you don't already have one, get a service manual from an online site. canammanuals.com
    Here are some pics of when I replaced the headlights with LEDs. The LEDs had metal mesh ribbon for the cooling and the newer bulbs will have a cooling head that fits better. It will be very helpful if you have someone with small hands as they are hard to get at and the spring clips are strong.
    IMG_1184.jpg F39E3245-73AD-4560-9A6B-FF6BD4145F7B.jpg A125670D-AC82-4E48-888D-DDF71A14EE82.jpg 3CEDDB32-C04C-4B44-92CF-7C78097BF454.jpg
    2021 F3 Ltd , Magna Red
    May 2017
    Central Texas
    Quote Originally Posted by Haze View Post
    WOW, Holy tight quarters Batman!!! I just bought my wife a set of metal ribbon heat sink style. (Fan motors create RF noise) I got the Instrument Panel off and I can get my finger to the back of the bulb. But NO Possible way can I grab or turn anything in there. It looks like the best solution would be to remove all Tupperware, and remove the headlight housing. I wear 3X gloves, there is no way I can see to get in there.
    Active Member wd8ajj's Avatar
    Las Cruces NM
    3 years ago installed LED's with the fan and one fan failed and so did the LED. Installing Lamonts LED this spring when get back riding. With his I know they will fit.
