Results 1 to 20 of 20
    Aug 2015
    Cleveland, GA
    Default Pair near-new of front wheels
    Two multi-spoke aluminum front wheels with 165/55R15 Kenda tires showing very little wear
    $275 picked up in n.e. Georgia
    Pete Tamblyn
    Cleveland, GA
    2020 F3 Limited (black)
    Time Out XL1800 cargo trailer
    2019 Royal Enfield 650 Interceptor
    2018 Kawasaki Versys-X 300
    2013 ST (sold)
    2015 F3-S SOLD
    2014 RT-Limited (cognac) SOLD
    Dec 2015
    Default still have the wheels
    sent you a pm
    Aug 2015
    Cleveland, GA
    Default ALUMINUM wheels FS
    As stated, these wheels are not chrome; instead the finish is bright aluminum.
    And, since the tires are shown as 15", it is safe to assume the rims are 15" as well.
    Thanks for looking.
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Aug 2015
    Cleveland, GA
    Default price reduction
    Fall clearance;
    now $225 (picked up) in n.GA
    Willing to drive reasonable distance to meet half-way.
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Sep 2016
    clark county indiana
    Default sent message
    I am looking at these big time my friend
    Dec 2016
    Louisville, KY
    Cool More info please ...
    Hi, I'm interested in knowing more about your wheels. Are the tires off of a Spyder or are they motorcycle tires? Did the wheels come off of an RT? I have a 2016 RTs. And where exactly in n. Georgia? We're in Louisville, KY.
    Thanks,
    Janeellen41
    Aug 2015
    Cleveland, GA
    Default wheel info
    The wheels and tires came directly off another forum member's trike. The spoke pattern appears to be that of an RT (someone feel free to correct if I'm mistaken).
    The tires are OEM Kenda.
    As stated in my signature line, the items are in Alto,GA (30510)
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Sep 2016
    Default Metrics
    I am wondering if B R P. Is using a metric hole pattern ? And the ones you have are English ( or standard pattern ). Being out side of the measurements to fit spyder?....
    Those rims look to be exactly like those on my 2013 RT Limited! And I reckon that if they came off another Forum member's Spyder, then there's probably gonna be a pretty good chance that they'll fit any other Spyder that takes 15" rims!
    Shame they are so far away really... I've been looking for another pair of rims so that I can fit different sized tires on the spare rims without having to leave my Spyder boot-less while I'm stripping my 'normal' tires & fitting the testers or vice versa! But somehow, I think the cost of freight to South Aus might negate any potential benefit...
    Nov 2016
    Upstate NY
    What???? They will fit any spyder. No difference between bolt patterns, just diameter of wheel. Has lower profile tire than older models with 14" tires and should fit under the front fenders of any spyder just fine.
    Sep 2016
    Default thanks
    thanks for the replies on the rims
    Jul 2018
    Fountain Hills,AZ
    Quote Originally Posted by Joel The Biker View Post
    So they will fit a 2012 RT that came with 14" rims? How would that work? fitment? speedo reading ect?
    Nov 2016
    Upstate NY
    Quote Originally Posted by wilpir View Post
    Yes...Absolutely. The wheel diameter is larger, but the outside tire diameter is the same as the 14" tires. Bolt pattern is the same on all models. Speedometer reads from rear tire, not the front.
    https://www.tacomaworld.com/tirecalc...5r15-165-65r14
    Jul 2018
    Fountain Hills,AZ
    Thanx Joel Good to know..I should of bought the 15" Black pair I saw on ebay at a good deal then!...
    Aug 2015
    Cleveland, GA
    Cool prefer black wheels?
    There's always spray-on bedliner.
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Jul 2018
    Fountain Hills,AZ
    Quote Originally Posted by motoswami View Post
    doesn't last,powdercoating better
    Jul 2017
    sarasota, fl
    if spray on bedliner doesn't last it was applied wrong. It's difficult to even scratch when applied correctly
    maybe you're thinking of PlastiDip (or similar) paint
    Aug 2015
    Cleveland, GA
    Cool pirated thread
    Looks like I pirated my own thread by facetiously suggesting the person wanting a set of black wheels could paint mine with truck bedliner.
    NOT a good solution!
    To be clear, these wheels are still in the pristine original aluminum, no bedliner to be seen, and it would appear could be used on most any Can-Am Spyder.
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Aug 2015
    Cleveland, GA
    Default still available
    This thread got somewhat convoluted, what with the comic comments about spray-on Bed Liner and such.
    No bed liner involved; just a pretty set of aluminum rims and low-mileage tires, still for sale and presently located in north GA.
    I could deliver in the Tampa area after Dec 5, when I'm coming to my FL winter residence.
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
