Results 1 to 6 of 6
    Jul 2008
    Wilmington, NC
    Default 2012 spyder died
    Ok took about 25 mile ride
    on the way home in traffic she died cut off on me a few times then dead nothing at all
    called a buddy for a trailer pick up and about 1hr later she regained power,,,,,,, but would not start
    Pushed her up on the trailer brought her home now she starts like nothing ever happen
    Anybody have an idea????
    I think its the battery
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Any codes? I would start by checking to make sure each battery terminal is clean and tight. Then perform a volt and load test. If battery is weak or has a dead cell it will show.
    Joe
    2023 F3
    Jul 2008
    Wilmington, NC
    Quote Originally Posted by tibadoe View Post
    No codes at all!
    That what scared me
    Default Curious...🤔
    My 2012 RS Sm5 battery just died which makes it one of the long lasting ones. But if yours is still the original I would suspect the problem is there. So normally you need to check all battery connection and ground connections. Check that all fuses and relays are well seated and good. A good load test on the battery will be good. Try jumping it with a car (engine not running) and see if it starts up.
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default I had this too.
    I agree with all this. Sounds like the battery and or connections. MY '14 RT would
    be cruising right along then just die, at speed. Coast to the side of the road and it
    would take a few minutes but then start. I got no codes. I had it to the dealer twice.
    They dug a little deeper and found a ground cable corroded. Problem solved.
    If your battery is the original I'd say you got your money's worth.
    Chuck
    Sep 2016
    clark county indiana
    Default watching
    watching the thread , let us know what the results are !
