Results 1 to 18 of 18
    Apr 2012
    Florida
    Default Tire Size Help Needed
    Have decided to replace the tries on my F3L. I want to use Vredestein Quatrac 5 tires. For the front tire I see they have a 175/65/15 or 165/55/15. For the rear, 215/65/15, or 205/55/15. Tom
    2020 Petrol Blue Metallic RTL
    Mar 2013
    I am running the 175/55R15's on my F3s. Great tire that I purchased from tire rack.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Apr 2012
    Florida
    Quote Originally Posted by PW2013STL View Post
    What size rear? Tom
    Jul 2015
    Kamloops B C
    Quote Originally Posted by Tango View Post
    I have been using a Yokohama S Drive 205/55R15 on the rear of my F3T for about 10,000 Kms. Almost no sign of wear, and the tire works Really well.
    Neil
    2016 RTE6 , Black
    Mar 2013
    What size rear? Tom
    Same tire and size as Neil.
    When I replace that I will go with the Vredestein's in the 205/50R15 size.
    Jan 2018
    Plantation,fl
    Default I have all 3
    I am running 175 up front and the 205 in the rear. I did a lot of research and it seemed that was the best combo. They all fit fine, no issues. They also run smooth. I have to tell you, the rear looks narrow and the tread pattern isn’t as good looking as the Yokohama’s... had to let you know. I
    believe I am still the only one on this forum running all 3 Vredestein Quatrac 5. The Sportrac 5 is actually rated better on wet surfaces.... harder to find though!
    Apr 2012
    Florida
    Thank you all for the help. Tom
    Apr 2012
    Florida
    Well, now what? No 205/55-15! They have a 205/65/15. What did you guys that have Vredestein on your bike use? Tom
    Jan 2018
    Plantation,fl
    Tom, I'm pretty sure I have the 205/60R15 on the rear.
    Apr 2012
    Florida
    Quote Originally Posted by Jeffmal View Post
    Jeff, can you make sure? They have that size available. Tom
    Jan 2018
    Plantation,fl
    Default Compare sizes!
    Tom and everyone...
    Very Important!
    Go to a site like tiresize.com and you can plug in the sizes and do a comparison.
    I did all of the research and that's how I came up with what sizes worked together...
    The height is important.
    Jan 2018
    Plantation,fl
    Tom and everyone...
    Very Important!
    I'm pretty sure that's what I have but I will double check when I get home later this afternoon...
    Jan 2018
    Plantation,fl
    I did check... I have the 175/55 up front and 205/60 rear. The strange thing is, it may be a mistake! Double check before you order, the 205/50 may be a better match height wise.
    Jan 2018
    Plantation,fl
    Actually, I just recalculated and my size choice seems correct, height wise the oem Kenda rear is taller.
    Apr 2012
    Florida
    The 205/60/15 will have the speed reading 2 mph higher than actual.
    The 205/50/15 will have it read 2 mph slower than actual.
    Mar 2013
    Since the Spyders run about 2 mph slower than the actual speed the 60 should correct that. At lease it did on our RT.
    Jul 2018
    Missouri
    The reason your 205 looks skinnier than the factory is because it is 20mm skinnier. Factory width tire is a 225.
    Jan 2018
    Plantation,fl
    Default I know that, but...
    Quote Originally Posted by CJ.RamMan View Post
    Vredestein 205 width claim to be 8.5” as opposed to 8.1” like the average 205 width.Remember every manufacturer uses a different method as there is no real concrete standard!!
    Yokohama 205 have a similar claim... bottom line these 205 widths should be just slightly narrower than the 225 width Kenda. I did a ton of research and the outcome is only as good as the info I am receiving!
