Results 1 to 12 of 12
    Aug 2013
    Default Another Sticking Handgrip - works fine with no end caps! Solutions?
    2013 Spyder ST-S
    So, read all the threads, tried all the tricks
    Totally apart now after replacing a grip and throttle sticking.
    No have not started the bike since, is that the issue? Does it magically reset itself when started?
    With it totally apart, no start/cruise/hazard switch, no end cap, no end spring...it twist fine... and snaps back. What the heck?
    As soon as I add the end spring and cap it binds up. (lightly tightened)
    plenty of room between switch housing. Plenty of room to cup holder. End cap not too tight.
    Have heated grips but don’t see anything binding and never an issue before.
    So will it simply clear when I start the bike? If so, why?
    Default Tough one....
    from the explanation it would seem to be in the end pieces. You should have a bushing end spring and the end cap and holding screw. Something is not lining up or putting pressuer to one side causing the tube to dray or bind. Hard to say sight unseen.
    Default sticky throttle
    ..... the screw at the cap is a bit sensitive to the amount of pressure it provides ..... Mine was too tight ( after I had removed the spring inside ) and it would prevent the throttle from completely returning to OFF .... I played with it and now it's fine .....I see you have checked this so I have nothing now >>>> sorry .... Mike
    Aug 2013
    Two post about the end cap and spring.
    Ill have to make sure they are extra clean, then reinstall and not tighten too much and try again.
    Default clarification
    Quote Originally Posted by SNOOPY View Post
    " Two " post about the end cap and spring ???? ............Mike
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    Make sure you don't have anything mounted on the handlebars that might be squeezing them. I had one of those RAM hose clamp mounts to hold my phone and I really tightened it down snug. Went for a ride and the throttle wouldn't return when released - that really got my attention! I backed off the hose clamp a bit and all was well.
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    Aug 2013
    I have a cup holder, but checked that. Everything seems to have good space between.
    Funny, I’ve changed this grip twice over the years and never an issue.
    Trying again this morning.
    Aug 2013
    I think something inside the grip housing is rubbing. Can’t see inside it. May need a new part, unfortunately doesn’t look easy. It’s a heated grip and think either the wires or a part inside is rubbing enough to smoothly roll back.
    Default Curious...🤔
    you said that you removed the grip...that would be from the throttle tube... so I ask, did you use any kinda of heat that could have deformed the tube..?
    Aug 2013
    No, used warm soapy water and pushed on. Seemed really tight and struggled with it a bit.
    Seems I may have warped it or damaged whatever bushing it spins on by pushing so hard.
    Aug 2013
    Wow, $200 for a throttle
    And I have heated grips, which I don’t see listed anymore.
    https://www.amazon.com/2013-2018-Thr.../dp/B079RSQ26V
    Wonder if number superseded and all are heated? Who’s our parts expert here? Lol
    Aug 2013
    All day research , this looks more like it.
    http://www.2wheelpros.com/oem-parts/...0929-part.html
