Handle bar play
2014 RT Limited. there is play in the steering... is it possibly adjustable? thanks.
hi there from aus,i have the same model and yep they have some freeplay.more noticable when the motor is off.as long as its not loose handle bars or wear but normal for some freeplay.
others can chip in and confirm im sure.
you can check the steer couplers sometimes those need to be tightened a bit. But you will always have some play and should not be excessive.
