Results 1 to 19 of 19
    Dec 2017
    Ontario
    Default BELT TENSIONER RT
    Good or not good, tell me your opinion 800_6d6b31ca9b87171c24491c40143adb190c1c4397.jpg
    Active Member BernardD's Avatar
    Mar 2017
    Geneva, Switzerland
    Quote Originally Posted by rtlimited View Post
    I cannot give you my opinion as I do not use this one. But looking at advise on spyderlovers, I do not see this product has being rated or having comments on it.
    however, lot of person are using this one:
    https://www.roadsterrenovations.info/products
    look similar but different brand.
    Ride safe!
    Northern Kalifornia
    Default I have one....
    Good! As long as you install it properly.
    Jan 2015
    southern WI
    Unnecessary with the correct belt tension and alignment, but a lot of folks use em and really like em.
    2016 RTS , Pearl White
    Default that device
    Quote Originally Posted by Mazo EMS2 View Post
    ...... My belt tension is at 160lbs on the KritKit gauge ..... I have NO VIBES ..... Mike
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    roadster renovations. get one and you wont have to ask whether good or not.
    and excellent service too. look on the home page. they are a site sponsor too.
    [joyce & irvin toms]
    Apr 2018
    Harrisburg, NC
    Cool Found it Useful
    I have the Rivco one installed (by my dealer). I could tell a big difference at 70 mph.
    SoFlo
    Not many comments or posts here or on some of the FB groups regarding Spyder Extras products.
    There is one FB group managed by the owners of Spyder Extras, that may not be a good place to obtain an opinion that is unbiased.
    As another post stated, proper belt alignment and tension, it can reduce or eliminate vibration from the belt when done correctly and no tensioner is needed.
    Dec 2017
    Ontario
    thanks
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Go with Doc Humphreys at www.roadsterrenovations.com and you wont go wrong. Excellent product, excellent service, ans EXCELLENT people.
    Dec 2017
    Ontario
    Quote Originally Posted by nslowmotion View Post
    thanks
    Mar 2018
    Ontario ,way up north
    It is very expensive to get Doc's tensioner here in Canada ,with the price of shipping and the exchange on the dollar .So i just installed the BRP one ,$ 56.48 total shipped to my door ,20 min to install .
    2018 RTL , dark blue
    Jul 2016
    australia
    the brp one has issues with the bearings in the pulley,you will most likely need to replace the assy in approx 5000kay if you do highway criusing speeds.the idea is ok but the bearing/design of the bearing location is poor.run it untill you get freeplay in the end pulley,dont wait until the bearings fail or you could damage a very exspensive drive belt
    SoFlo
    Quote Originally Posted by stmike 1800 View Post
    Slightly confused. The blue bike in the photo is an RT series. Has Can Am started offering tensioners for the RT now?
    In the other topic, it was suggested to lower the belt tension on your bike. Was the dealer unable to find the lower spec service bulletin and readjust it for you?
    Mar 2018
    Yes you can buy the tensioner for the RT ,i just installed mine .They were to replace the rear pulley yesterday,and lower tension ,but when i picked up the bike the mechanic was gone for lunch so i do not know what he did .
    SoFlo
    Looks like this is the Can Am RT tensioner Part Number, 219800419. Never noticed they started offering them, or at least do not recall them offering it. Seems with so many variations and manufacturers plus most of us do not run a tensioner, just lower belt tension it was not important to me.
    Hope it works well and lass for you. I have seen some misery photos of failed BRP tensioners, but on the flipside, the aftermarket ones are kind of expensive. Almost expensive enough to keep replacing BRP tensioners frequently.
    May 2016
    mt morris il
    does brp list this in the parts breakdowns or is it listed elsewhere on their
    site? just wondering. i am happy with docs.
    United States
    We were the first one to ever install a vibration damper on the RT. BRP told us for years that there wasn't enough clearance to install one. I imagine there were some red-faced engineers at BRP when they saw this video:
    That was Nov 2016. We have been refining our Vibration Dampers since then. We have had some of the springs fail on a few units. I never liked that spring design. We now have a completely new spring design engineered to not break. We have got rid of that short 90, increased the spring arm on that end and used the bracket base as a resting point. What this will do is lengthen the area where the force is applied instead of concentrating it on one little 90 degree turn of the wire.
    We still offer 2 years on the roller and one year on the rest of the unit. You might want to check what the competitors are offering. Also, with the exception of the BRP unit ours are cheaper than anyone else as far as I know.
    Apr 2018
    Wesley Chapel Fl
    I have this model. Very nice upgrade from the BRP model. Very nice aluminum machining with dual bearings. I would highly recommend.
