My $35 version of "magic mirrors"
After I had been taking my mirrors on and off several times over the years for various MODS on my 2010 RT.
My clips broke here on the retainer portion of the top Clip. See the piece from the broken clip?
One day as I was passing by my RT, I bumped into my mirror and the darn thing nearly fell off. I was furious at first, but then I remembered reading about using magnets to hold the mirrors on (magic mirrors). I thought I might give it a try. So here is what I came up with;
The parts I used were:
6 each -Magnets from “eBay” - Round Countersunk Ring Magnets 25 x 10mm Hole 6mm Rare Earth Neodymium
6 each Steel Washers
12 each Countersunk wood screws
1 ¼ inch long metric screws
First of all instead of the washers being cut down to fit inside the clip socket, I made it so the washers would fit over the clip while it is still in the socket while using the same screw holes but longer screws. You will have to remove the clip so you can pick up the holes. See pictures below.
Once the holes are picked up they should be counter sunk (the screws must not protrude above the surface of the washer).
Now proceed to do the rest of the washers. Here’s how mine looked when I finished.
Now let’s prepare the clips, first I had to modify the good top clip to match the broken one.
To be continued on my next post. See you next time ![wink](images/smilies/icon_wink.gif)
[IMG]file:///C:/Users/WILLIE~1/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg[/IMG][IMG]file:///C:/Users/WILLIE~1/AppData/Local/Temp/msohtmlclip1/01/clip_image012.jpg[/IMG]
looking forward to the next installment......
![](http://www.spyderlovers.com/forums/signaturepics/sigpic23143_3.gif)
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
Where is the thread with the previous steps? This starts with 'next ...'
2014 RTL Platinum
![](signaturepics/sigpic20671_7.gif)
My Version of "Magic mirrors" part three
Remove the existing stud pin screws and replace them withthe magnet screw and washer assembly see picture:
By loosening the screw that holding the Tupper ware as shownbelow, this will allow for the Tupper ware slight movement to accommodate thespacer washer for the magnet:
After all the magnet assemblies are installed reattach themirror assemblies.
Aline the screw heads in the hole of the washers with aslight push and BAM! You have your very own set of “SNAPP MIRRORS”
I hope this helps someone outthere save some money and time !
Thanks for your time!![wink](images/smilies/icon_wink.gif)
My version of magic mirrors part 1
Sorry for the confusion but I will add it now.
[IMG]file:///C:/Users/WILLIE~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg[/IMG]
One day as I was passing by my RT, I bumped into my mirror and the darn thing nearly fell off. I was furious at first, but then I remembered reading about using magnets to hold the mirrors on. I thought I might give it a try. So here is what I came up with;
6 each -Magnets – from “eBay” - Round Countersunk Ring Magnets 25 x 10mm Hole 6mm Rare Earth Neodymium-( 350916709551 )
pic 4.jpgNow proceed to do the rest of the washers. Here’s how mine looked when I finished.
Next trim the tab on the bottom two clips and then use a file so that the washer will sit flush:
Ozzie Ozzie Ozzie
Whichever way you look at it or whatever order you might get it in, it looks like you've made a pretty good start on your own version of these Willie, Good Stuff! Well Done!
SpyderLovers Sponsor
Clever
Joe Meyer
![](https://www.spyderlovers.com/sponsors/squared.jpg)
I thank you for all the work you put into this. I have a question. in the parts list you said 6 steel washers, but it there one for each plastic "clip" and 2 on each magnet?? so, shouldn't that be 18 washers, or am I missing something?
Ray
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
![Quote](images/misc/quote_icon.png) Originally Posted by bcer960
Ray
Good point! I was wondering that too. They look like brass washers. How about the sizes on the washers too please?
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
![](signaturepics/sigpic20397_1.gif)
answer to the washer question
Thank you for your interest in my post. Now to answer the washer question. you will only need 6 washers ( 3 for each side ). the part number for the (steel) washers is 03830 and I got them from LOWES. You have to make sure that they are made of magnetic material.
the two washers that are on the magnets are PN " AN416 " washers and they are smaller and are only used for spacing.
![Quote](images/misc/quote_icon.png) Originally Posted by Williebbaker
Thanks for giving the part numbers, but i am a bit confused on there only being 6 washers....
You put the washers on the mirror side, and in the post i quoted, you are saying put the washers under the magnets. I was hoping to do this this weekend, so any clarification would be much appreciated.
Ray
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
OK, sorry, we were writing at the same time....
Ray
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
I like this, I think I'm gonna try it
I have had them on for a year. They work great. The only thing I suggest is keeping the top clip on the mirror. This hook is only used to "hang" the mirror off, and doesn't take any force putting the mirror on and off.
Last year when I first used this system, I was on a long trip, and hit a pot hole, and the mirror came off. Now, I had a tether, so it just dropped, but it actually did it a couple times on the trip. I put the top clip back on the mirror, and have not had another issue.
Ray
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
What size were the washers, I tried looking the number up and it did not work, Thanks, Mike
![Quote](images/misc/quote_icon.png) Originally Posted by wmh9680
I'm pretty sure they were 1" fender washers. but not 100%
ya, just reviewing, and that's what they are
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
Thanks, Mike
Thanks, Mike
I just ordered the magnets, they come from overseas, can't wait
Just received the magnets and 1 was cracked, may try to JB Weld it before separating it from the others. I mistakenly showed them to my friend and when he tried to separate one he broke it into 3 pieces.
The problem is, when a magnet is broken, the magnet field drastically changes. If it broke into 3, you now have 3 magnetic fields, and I do not if it will hold.......
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
Thanks, I guess that one is trash, what about the one that is cracked on one side
look closely, it is probably cracked through. If so, it is also "new" magnetic field. It MAY work, but I wouldn't trust it, as I think it will break at some point.
2017 RT-S
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
Glo-riders
Front Grills
Third Brake light
Larson Scanner
Well, I have proceeded to break 3 of the 4 magnets, guess I dn have the magic touch, you gotta keep a close eye on these little suckers, they wanna jump around and play bumper cars a lot
Tags for this Thread
