Results 1 to 21 of 21
Thread: Seat cushion
    Sep 2014
    Hood River,OR.
    Default Seat cushion
    I would like to know what seat cushions some of you would recommend. I am riding a 2014 RTS. Seems like I have seen many have the Airhawk brand.
    Thanks Larry
    Feb 2012
    Spring City,Utah
    Try motorcycledave.com He is a sponsor here and I have this cushion in my seat.Very happy and works very well.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default Depends...
    There are the sheepskin, beaded, air, Gel etc. Hard to say unless you have tried them all... I would the best way to go....
    Active Member Triple B's Avatar
    Jul 2017
    British Columbia, Canada 🇨🇦
    I’ve thought about the gel pad from Motorcycle Dave, but damn....cutting into the seat scares the hell out of me, and I live too far away to take it to him, plus there’s the border issue.
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    Show Chrome Trunk Rack
    "You know that a politician is lying if his lips are moving"
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Quote Originally Posted by Triple B View Post
    Have a look for local vehicle upholsters as they will often do this sort of work at a reasonable rate, particularly if they don't have to make the cover.
    I was originally going to do mine myself but when I went to remove the seat I found I also had a small tear at one edge. So I took it to a local vehicle upholsters, had three to choose from and that's in a rural area. The guy there not only did the pad but also reshaped/replaced some of the foam where is was worn and did a new cover. Cost me NZ$110 (US$75) for labour and materials, not including the gel pad.
    I must admit I wasn't sure how much difference the gel pad would make and pretty much bought it on a whim, but I've done a 3 day iron butt (1000+ miles a day) run since and got to say its made a big improvement. Didn't have to stand on pegs once while riding and butt didn't feel numb or painful at any time.
    Nov 2015
    Tinley Park, Il
    I've tried a few things and found something I like.
    WonderGel Original Cushion in Black
    COLOR : BLACK | SIZE : 18" X 16"
    Durham,Maine
    Default Gel
    I am having Dave's gel pad installed as we speak. Was going to do it myself, but found out my staple gun would not shoot threw the hard plastic shell under the seat. can't wait to give it a test ride!
    2012 RTL , Pearl
    Apr 2013
    Somersworth, NH
    I have also been searching for that best fit feeling. I have tried the Butt Buffer but returned it shortly after getting it. I also had a set of beads, but didn't use them very long either. I am currently using an Airhawk with a sheepskin on top. My passenger has a beaded seat under the sheepskin.
    But to be honest, I'm still not satisfied and I'm seriously looking at a Russel Day Long replacement over the winter.
    Good luck with your decision.
    2016 RT-S Special , 2 tone black
    Very Active Member SpyderConvert's Avatar
    Catonsville, MD
    Quote Originally Posted by wmh9680 View Post
    I'm going to check out that pad. I was in Home Care sales in the mid 80's and we sold a gel pad made by Jobst. The thing that sold me on it was that to demonstrate the pad to physicians, I would ask them to place their keys on the pad and then sit on it. You could not feel the keys!! Wish that I had one of them.
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
    Oct 2015
    Cumming, Ga
    Quote Originally Posted by lmadsen View Post
    Thanks Larry
    My vote is Airhawk. Used one for the last 3 years. Wouldn't trade it. Worth the cost.
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    My wife likes the airhalk I recently bought her.
    Lew L
    2014 RTS , Circuit Yellow
    Very Active Member crazycanuck's Avatar
    Dec 2008
    Bellevue, WA
    Quote Originally Posted by Lew L View Post
    Lew L
    what size fits the RT?
    Linden, CA
    Default Your only in BC not to far....
    If you want to install the GEL/Memory foam into your seat, it's easy but if your are afraid to do it
    after looking at my website on how it is done, give me a call and can hook you up with a place near you
    who will install it.
    Dave
    Nov 2015
    Tinley Park, Il
    Has anyone installed heat on their stock seat
    May 2013
    Indiana
    Quote Originally Posted by crazycanuck View Post
    With my bony arse, and getting worse with age, my long time Butt Buffer stopped working, even with a full sheepskin on top. I had heard so much good about the Airhawk, I decided to give it a try. Been trying to find the "sweet spot" for me over the past week. It's true what Airhawk says, "less air is better". You need the LARGE Cruiser R. FA-Cruiser-R-REVB. Best price locally was @Cycle Gear.
    Mike
    2021 Marsala Red Metallic RT Limited
    Dec 2008
    Bellevue, WA
    Quote Originally Posted by MikeT View Post
    Mike
    ordered the Large; will test it on my journey to Deadwood.
    Active Member thereverend's Avatar
    West Monroe, LA
    Default I use the
    Thanks Larry
    ​AIRHAWK FROM AMAZON.COM
    Mar 2015
    Smile
    Hay crazycanuk,
    It's the R- REVB CRUSER . Large fits the passenger seat just fine. She does not have a big butt. But a play on words.
    We used to have a gel pad which I now use on the hard Corbin saddle on my old, slow V-Max.
    Lew L
    Linden, CA
    YES
    I also stock the OEM seat heaters, then come with all the wiring and controls
    Easy to install yourself and only $79.95 ea
    all you have to do is call me 209-887-3283
    Ride Safe
    Dave
    Dec 2008
    Bellevue, WA
    Hay crazycanuk,
    Lew L
    I ordered AIRHAWK Cruiser R Large, should have it early next week before my trip
    Mar 2015
    Thumbs up
    Hi,
    Just be sure NOT to over fill the air seat. Your own weight has most to do with pressuring the seat to you liking. You us a couple of tries.
    Lew L
