Engine Light on
I was on a ride the other day and the engine light came on. My spyder is a 2014 ST Limited. It wasn’t running hot, checked oil and it was between full and Add. I tried to check to see if there was any codes by holding mode and set along with the signal cancel button but all it does is come up with a blank screen. I do have a power programmer on the bike. It’s been running fine but I did fill up with 88 octane gas. Does anyone have any suggestions on what to check or do next. Closest dealer is about a hour away. The check engine light comes on and stayed on but doesn’t flash and the bike never went into limp mode. Ideas please
Let's see...
First of all the check engine light will come for any reason including non engine issues. The code will tell you why. Now not having a code you should start by starting the ST then shut her off remove the key go inside and give it 30 to 45 minutes to reset the computers. Then start up normally and see if the check engine light is out then Ryde as usual and see if it comes back on. If it doesn't could have been a glitch if it does shut the engine off using the kill switch leaving the key on and check for codes. Not sure what a power programmer is unless it is a fuel mixture controller which can cause a rich or lean mixture problem. Let us know what you find out...
![Quote](images/misc/quote_icon.png) Originally Posted by Jjrk3
I would check and make sure all the relays are plugged in good
Took the Spyder out for a ride today and got back and checked the codes and it showed P1171 and P0130. From what I looked up it is too lean and a O2 sensor. I have a power commander on it so that may be what is causing it. How do I clear the codes to see if it stays active? Bike runs great still.
Well....
Dealer can erase the codes otherwise they stay stored in the computer. I have seen post with some button pushing sequence they say will erase the codes. Thing is if no warning lights are on you don't have to worry about them. Some controlers used their own O2 sensor some used the exsiisting one. if it was added because of a change in the exhaust you may have leaks be it from the gaskets the vaccum lines or falty sensor...
If you remove the power commander and the check engine light stays off you don’t have to worry about the code. It will have changed from Active to Occurred and it is stored that way until cleared with BUDS
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Just wondering how you made out with the P1171 and P0130 codes. Did you have to fix or adjust anything to clear those codes?
Thanks, Joe
