Results 1 to 25 of 30
    Dec 2016
    Nj
    Default Gas Cap so difficult to close and lock
    again another key/closing/locking problem
    brand new F3T
    my first gasoline full up--key opened up the locked cap nicely--but when i went to close and lock--it took an ungodly amount of downward force on the cap to allow the key to fully get into locked turn position so as to remove key--the gas station attendant had to put all his weight downward on the cap while i separately turned the key--again help, what did i do wrong? how can this be remedied?
    needs grease somewhere , or just stronger me?
    Greenville Tx
    Get a Lamonster gas cap, problem solved.
    2017 F3 Limited
    Bay of Plenty New Zealand
    Quote Originally Posted by Petrom714 View Post
    brand new F3T
    Simple as fix spray WD40 or silicone spray on the rubber gasket, now when closing it make sure the key at 3 o'clock then a simple push with the thumb and the key will give a click as it turns to the left by itself, l have only 1 thumb and have never had a problem once l used that method and l have had my F3 since 2015 and now with over 63,000 kl on it, so have had that cap open and closed heaps putting fuel in it like 2 fuel ups yesterday LOL.
    Default Common problem....
    This happens with most caps of this type. There are several threads on the subject.. The trick is to leave the key alone close the cap and apply pressure to the sides of the cap till the key snaps back on its own. Many have added a bit of grease to the gasket area to help...
    Jan 2018
    Plantation,fl
    Default I had same issue...
    I have same byke. I thought I was going to bust the key off in the lock. I put some white lithium grease around seal and kept opening and closing. Like the previous response, push it down evenly and it kind of locks itself! You aren’t the first or last to have this issue!!
    Apr 2012
    Arizona
    Mine seemed not to be the gasket but the tongue that slides into the opening. I lube that and all is well!
    May 2018
    Seattle
    Agreed. Seems like there's a few places on the F3 that could use a little grease to help close up. I see you top case!
    2017 F3-L , Red/Black
    Greenville Tx
    It definitely requires some hand strength to get it to lock. I have a friend whos wife can not lock it without her husband to do it for her.
    2017 F3 Limited
    Oct 2017
    Ontario
    brand new F3T
    I had the same issue with my new f3s 2015 ..... last year when I bought it... its a little easier now but not much... I have to stand on the foot pegs and use force from my arms down onto both thumbs on the sides of cover to close it. I was concerned about not getting it closed ever time I went to fill it, but my husband is usually with me and is able to assist on the few occasion I haven't been able to. Interesting - I took a 2017 F3s out from the shop this year while mine was in. No issues with that gas cap at all. So easy to close, I couldn't believe the difference. I think it is hit and miss, personally I think the difficult ones to close should be replaced at no cost by the dealers. I really like the shop I bought it from, so I will again bring it up to them when I get my next service and see if I can get it replaced. I did ask them last year if I should put some grease on it - they said no, they didn't recommend doing anything like that. They said to see if it worked in a bit, it has a bit but not much
    Jun 2010
    Las Vegas
    With the cap open spray silicone on the pin that goes in and out as you turn the key. Spray it and turn the key several times and problem solved. You need to keep the gasket clean and you shouldn’t have any issues.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    Silicone worked ok but now i use wd40 which makes it close very easily. Spray the key part and the locking mechanism underneath as well as the gasket, wipe off excess and you should be good to go. Smooth as butter now.
    2016 F3L , Big Bike Parts Black
    Dec 2016
    Somewhere USA
    Default Lets start a "Lube War"......lol
    WD-40 is not a lubricant.
    I use white lithium grease, turn my key to 3 o'clock and this works like a charm.
    I "lube up" every time I'm in garage and remember to do so.
    I sick and tired of arguing about tires, idlers and sprockets.
    Lets beat each other up about...………………………………………………...LUBE!
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Quote Originally Posted by Bruce B View Post
    ...make sure the key at 3 o'clock then a simple push with the thumb and the key will give a click as it turns to the left by itself
    Yes turn the key before applying any pressure to the cap. I had noticed a couple of F3 riders pressing down hard on the cap and then trying to turn the key. This is self-defeating as you are effectively jamming the latch that retracts when you turn the key.
    If you follow the lubrication tips in ths thread, turn the key first, then press down the key will snap back on its own when you press down on the cap.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Aug 2016
    central texas
    Road-kill, my can of WD40 says it lubricates. What does yours say?
    Dec 2016
    Nj
    Default that is a great idea about dealer replace--
    and thank you all for suggestions
    this community is a life saver--literally
    i will try the lithium grease and let you all know how it resolved--it doesnt help that my mild disability prevents full strength push down on it--
    thanks again
    Quote Originally Posted by LA2015FS View Post
    Mar 2017
    All good suggestions, but the solution is simply to turn the key to the left (anti-clockwise) until it stops. Push down the cap until it clicks. Finish turning the key and remove.
    Dec 2012
    Murphy, NC
    Default GAS CAP
    I agree with AY4B. Get Lamonster’s keyless gas cap and problem solved.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Springfield, MO
    To date this is our best selling product. I've tried all the other fixes and they work for a while but this is a permanent fix and it looks great too. We have a hard time keeping them in stock and dealers are buying them 20 at a time. Here's a few customers that have them and love them.
    http://www.lamonstergarage.com/can-a...bly-lamonster/
    Loving my new fuel cap from Lamonster Garage!! The BEST mod for the F3 IMHO!! Thank you for a GREAT product...very satisfied customer!!
    Got my fuel cap installed. Looks great. Thanks Lamonster. Another great product.
    Thank you Lamont Bryden and Lamonster Garage!!!
    Looks awesome on my bike!
    Took about 20 min and it was FUN!!!
    Now we gotta go get gas and we don’t even need any!!!! HAPPY GIRL
    The LM gas caps look great.
    Dec 2016
    Nj
    Default one of those is in my future
    looks great!! first the mirror/turn light LEDS I bought from ya last month have to get in$talled, and my phone holder, ..and my cup holder, then fix the obstinate gas cap--thanks for input...not driving that much in this rainy weather up here anyway, so i wont need a fill up for a while again..lol
    Quote Originally Posted by Lamonster View Post
    Dec 2016
    Nj
    this is causing me to think that i might have no choice but to open with can am a warranty claim. im severely deficient in muscle strength and having to fear the few times a month visit to the gas station is getting tedious...i have to beg the gas attendant to help me close it--thank you all for you replies and input
    Mar 2017
    Closing the gas cap on a Spyder"
    Member Phatjac's Avatar
    Oct 2015
    North Carolina
    Quote Originally Posted by nhoj View Post
    I agree....I've owned a '15 F3s and now a '16 F3 Ltd and both worked the same for me, Turn the key before pressing on the cap!!
    Phatjac
    2015 F3s - sold
    2016 RTS - sold
    2016 F3 Ltd Special Series
    2016 RTS (wife's)
    Aug 2019
    TX
    White lithium grease on the slide under the cap seal. Mine wouldn't move at first. You have to work it back and forth to free up the slide with both hands and then wipe off the excess. . Now I just push mine down to close. Don't need to turn the key first, but it is easier I supposed. The click let's you know its closed. When I first bought it it would not close at all unless I turned the key and the cap would not fully seat once it latched.
    Active Member deer30084's Avatar
    Tallahassee, FL
    I thought about the keyless gas cap FOR ABOUT 60 SECONDS. Then I decided a locking gas cap is best. Just think if they sold Spyders with keyless gas caps. Some entrepreneur would come out with a locking one and everybody would buy it. We seem to want what we don't have. Get some silicone lube! Put some on your fingers and rub the rubber gasket with it. It will last for months!
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
