Results 1 to 25 of 35
    Sep 2016
    LI NY
    Cool Seat release tool
    After reading about seats not opening the other day I decided to be proactive and make a tool to do the job now as opposed to trying to fabricate something on the road while almost out of fuel. I will keep in in my trunk in case myself or someone I am with has the issue while riding.
    Photos aren't the best but you get the idea. It works like a charm.
    2010 RTSM5 , stock Stock Silver
    Active Member bscofield84's Avatar
    Aitkin Minnesota
    Thanks for sharing that. About what gauge metal wire did you use on that?
    2014 ST SE5 LT , Black Current
    You've given me a perfect project for tomorrow evening...
    (The Missus will be out of Town! )
    Sep 2016
    LI NY
    Quote Originally Posted by bscofield84 View Post
    0.125" SS
    Nov 2013
    Central Texas
    That's a great idea, one that I will be replicating ASAP.
    Default DIY TOOL FOR SEAT
    .....Good for you .... I realized this as a problem a couple of years ago .../..so I made a very thin cable pull for that latch ...... I vended a few at Spyderquest .......... you should put one on the FRUNK also ...it's easy ....... Mike
    Bossier LoUiSiAna
    Quote Originally Posted by Zip View Post
    Push or pull? Looks like a pull system never had to fool with yet, key has worked fine but always handy to know. SS wire say from a wire welder? If so great I have some from my dads don't know the diameter, what about bailing wire? Been recommended by bunch of 2wheel buds.
    Sep 2016
    LI NY
    Bailing wired old coat hanger
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    That's what I did put it on the seat and the front trunk
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    X2 on what Mike said.
    Faribault, MN
    Zip, great simple idea, MAN that is one well worn beadrider.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    May 2014
    Benson, NY
    Same idea but more permanent.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Active Member trikerbiker645's Avatar
    Apr 2016
    wi
    I just took a tie strap to the cable and hold the latch catch over and don't have to unlock anything. Took all of two minutes to do. Not the least bit worried about anybody stealing my gas or putting something in the tank. Do people even do that type thing anymore? They just rob you or carjack you.
    Baja Ron sway bar, Spyder Dock, Highway Brackets,Trident pegs, Spyder Decals, Signal Mirror led strips, Utopia backrest, 5 pc. Hopnel liner set, cargo nets side/rear doors. Mesh bag front trunk, foam grips, spare trunk key, passenger armrests/storage pouch's, ram mounts/GPS, Drink holder,Phone, Passenger clamp-on drink holder, rear trunk tap light, custom plate frame, spyder fastener bolts, adjustable lower mirror wind deflectors, F4 Customs windshield -wide,tall,clear,vent,Chrome Spyder grill.
    Active Member SilverFox1's Avatar
    Dec 2010
    Chelmsford, Ontario
    BRP paid lots of people big bucks to engineer this machine. There is more signs of intelligence on this forum than anywhere else! Love this idea. I’ll be working on this tomorrow. Thanks for posting!
    If you don't change anything,,,
    nothing is going to change!
    Default Great..!
    Have seen mostly the permanent hidden pulls. Have seen folks take the pin out and have a non-locking seat. But always nice to have a tool that way you can help your fellow ryder. I just carry two keys... will make one up cause not many do..
    Jan 2015
    southern WI
    Quote Originally Posted by trikerbiker645 View Post
    I went one step further and just removed the stud from the seat altogether. I think I'll make one of these releases for the frunk though. Thanks for the post
    2016 RTS , Pearl White
    Default seat issue
    Quote Originally Posted by Mazo EMS2 View Post
    Actually that " STUD " serves another function .... and this I learned from someone else's Bad experience ..... that Stud is a locator for EXACTLY where the seat pan will Position ... when it is down. Since the for and aft movement of the seat can be adjusted .... without that STUD, the seat can actually slide forward .....if this occurs ( and I know it can ) your seat will rub on your gas tank ( on an RT ) .....this can and will damage the paint ....... just a heads - up ........... Mike ......PS what I did on mine was , I wired the LATCH mechanism so it wasn't fully closed ..... It will catch when I close he seat and it stays down ....however a slight upward tug on the seat flap will release it ........ Mike
    Nov 2012
    North Las Vegas, NV
    Made a permanent release on our RT for the seat and the frunk. One of the first things I did was make a release for the frunk on the F3L.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2013
    Oro Valley Arizona
    Hey, you guys are a lot smarter than you look!
    Great idea!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Northern Kalifornia
    Default BRP should be embarrassed........
    Quote Originally Posted by SilverFox1 View Post
    But they're not.
    Dec 2015
    Oakley Utah
    How long is that? About 6"?
    2014 RTL Platinum
    Jan 2015
    southern WI
    I changed my thinking based on your advice Mike I put the stud back in and just tied the latch mechanism back. Never even considered that gthe stud holds the alignment of the seat.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Bensonoid View Post
    Ditto. I had some 14 gauge solid house wire so I used that. Works well, but doesn't need to be that heavy. I had to drill a hole in that metal piece where the OEM cable terminates, because the existing hole wasn't big enough for that large a wire.
    2014 RTL Platinum
    l don't remember the part # off hand but I replaced the gas strut on my seat with a stronger one. I believe Mike, BlueKnight911, was the one who gave us the part # one time. It works great and can lift the seat with my helmet and jacket on it.
    It can be a pain to find just the right spot but I would strongly suggest you all go through the process of getting the stud positioned just right so it goes in and out of the latch smoothly. When it's in the right spot, and with the stronger strut, as soon as I turn the key to unlock the seat it rises up on its own!
    Default WIRE TOO FAT
    I'm betting it would have fit without the insulation ....... Mike
