Results 1 to 25 of 25
    Jan 2018
    Australia
    Default Has anyone ever done anything with ram air intakes - on anything ? Need some advice!
    Next silly question ...
    Has anyone ever done anything with ram air intakes ? Obviously asking because in all the years of tweaking and playing, I have next to no experience with them.
    However, thinking I wouldn't mind crossing a semi forced induction ram air intake with a particle separator style intake, that are mainly used on aircraft. ( ... think about a normally aspirated engine - then go to the other 'extremes' of turbo or super-charging, ... now back up the train to about half way between these two extremes and there sits what I envisage)
    As an aside, particle separators, I'm very familiar with from my days of working with rotory engines and helicopters (Allison turbines especially ... And I see when I began 'googling' this stuff again, low and behold both Polaris and Can Am are all over it for their adventure off road series of turbos and the like ... bugger me ... C'mon BRP ... catch up with the Spyders yet again ...
    Greenville Tx
    What are you calling ram air intakes? Where the foglights are?
    2017 F3 Limited
    Default RAM AIR
    For my 08 GS, I put air intakes on the upper side panels to allow more into the engine area for cooling I THINK it helped .... For my 2011 RSS ( no fog lights ) I modded the OEM Air box rubber snorkels , made them much shorter and used a 4 in. aluminum dryer hose to connect to the right side Air Intake built into that panel ....This put much cooler Air into the stock air box so it was getting Ambient temp air as opposed to engine temp air ( about 200 F ) ..... did ir make a difference ...I'd like to say yes, but I never had it Dyno-ed so it would just SWAG ...... On my 1330 RT I re-moved the entire stock Air Intake and put a 3 in piece of thin wall pipe out the left side Panel ...I put a 3 in computer fan in that pipe ( fan = 36 cu.Ft. per min. ) ....but the fan is on the wrong side of the Air FILTER to give much RAM effect ..... I have a pic in my Album's ( the one that shows a pic of a trimmed "A" arm cover ........ Mike
    Default RAM AIR
    Very nice .....that's about what I did on the RSS ...but on the other side so the Air went into the Air Box .... I never thought about adding the Fan ....??? What size it that ???? .......... Mike
    Jan 2013
    Glendale AZ (formerly Oz, Albury NSW)
    Default The fan will restrict the intake!
    It takes kilowatts to drive a fan large enough to pressuurise an engine's air intake, not watts.
    All you are doing is restricting the air intake by adding a fan into that tube.
    Jan 2018
    Australia
    Quote Originally Posted by AY4B View Post
    No mate ... taking things if you will to an extreme ... We have all seen those big air dams that are placed toward the front of a vehicle (say a dragster) which traditionally has a larger opening that diminishes to a small intake at the rear all in an effort to catch as much as the air flow as possible. Traditionally then from an automotive sense the smaller area at the rear supplies the opening to the engine fuel managements air intake ... so it 'rams' the air into the intake
    Jan 2018
    Australia
    I've seen these a fair bit lately on 'greedbay' ... They are cheap as chips but reputed to run at about 55,000 rpm (if we are talking the same thing) ... So what are you doing here ... just turning it on and letting it rip or?
    Jan 2018
    Australia
    I've seen these fans a fair bit lately on 'greedbay' ... They are cheap as chips and reputed by their suppliers to run at about 55,000 rpm (if we are talking about the same thing) ...
    So what are you doing here to run / control it ... Just turning it on and letting it rip or?
    I am trying to achieve a more gentle, gradual radii and 'smooth' transition for the airflow to avoid turbulence as much as possible ... I would also like to implement a venturi effect for the enhancement of the same ... My thought is to 'possibly' experiment with mounting the air catchment from directly behind the F3-T grill there some where .
    (I know I know, I have too much time on my hands - Most other people would probably be scratching their heads as to why I would even bother ... but my response is why not? What can it hurt by having a dabble ... I suppose, just because I am a silly old bugger and can !!!)
    Any and all suggestions really appreciated ...
    Default Freewheeling
    Quote Originally Posted by fatenhappy View Post
    These fan are not powered they run on air flowing through them. The faster I go, the faster they spin. Have worked well feeding air to the filher and cooling the engine compartment. Dabble on and let us see the results...
    NorCal - Northbay
    There isn't much of anything you are going to "insert" in the intake tract that will do anything other than impede airflow. If you do some math ( (Displacement) (RPM) (Volumetric Efficiency) (Pressure Ratio)/5660 ) to determine CFM rates for the engine you are gonna see that a 1.33 liter engine spinning at let's say the midpoint of our rpm range, 4K, with a standard 90% VE figure will ingest air at a rate of 84.59 CFM... And pretty much double that at 8k. Even at a modest 2k it will ingest at a rate of 42.29 CFM.
    There is more to be had by cooling the intake air charge and removing restrictions in the intake tract (air filter etc). You have to be careful when enlarging the intake piping diameter when using a MAF type system as this will change the MAF readings to the ECM. You can get away with it if you are using a Speed Density System up to the limits of the maps' ability to self adjust.
    Chuck
    Jan 2018
    Australia
    I would suggest you cannot create 'free energy' from a free spinning propeller ... I would be really surprised if these 'free spinning' fans are achieving much of anything at all except maybe initially some turbulence or and a more direct air flow ... like your style and love your creativity though ... I'd imagine you would get a better result from just having a free air / direct ram duct with no fans
    Jan 2018
    Australia
    Quote Originally Posted by hypurone View Post
    Oky doky .... lets play some ... My figures for a 1330cc engine come up to 81.16 ci ....(In my mind the first thing we do is to convert its displacement into cubic inches, allowing easier conversion into determining lbs/min of air mass flow. So, 1330 /16.387 Cubic Conversion Displacement = 81.16 ci) ....
    Now that we have our displacement in cubic inches we need to calculate the engine’s air-flow in CFM in its naturally aspirated state. (CFM is a recognised constant (K) and generally accept at max air flow to be 115cfm / inch sq through an orifice, as per when calculating eg exhaust gases etc or alternately inlet manifold max flows. This is very easily done and expressed as follows ... CID x 0.5 x Max RPM / 1,728 = CFM
    This formula takes the engine’s size in cubic inches times .5 because in a four-cycle engine it takes two complete engine revolutions for all cylinders to completetheir cycles. This value is converted from cubic inches per minute to CFM by dividing it by 1,728, thenumber of cubic inches in one cubic foot (12 x 12 x 12 = 1,728). So, all up the formula with our engine should now look something like 81.16 x .5 x 7200 / 1,728 = 169.083 ... (7200 because that is where our 1330 produces peak HP .... however, I am still in a quandary here also, as for 'response' (ie when we want to gun it) we would - again in my mind, be looking towards peak max torque and not max HP output - which again is expressed by the CAN AM spec @ 5000rpm)
    Now also bare in mind we probably need to be looking towards what we 'want to achieve' rather than what is currently advertised as max ...
    Next we take our 169.083 CFM and adjust it for the land of reality as very few naturally aspirated engines could ever achieve anything like 100% efficiency without a whole shed load of 'tweaking' .... The above calculation contains an assumption of 100 % VE. Since most engines in the naturally aspirated state do not operate at anything like 100 percent VE, we need to compensate and recalculate. Now again this is where conjecture comes into play, depending on the 'source' of your reference....
    So again, a typical two-valves-per-cylinder, push-rod engine is somewhere around 80 to 85% VE, four-valve engine w/variable valve timing maybe 95% VE .... (if you are real lucky ) ... So lets stay really conservative and say for this example, our four-valve banger is getting about 85 percent .... (... my choice!)
    So now, that's ... 169.083 x 0.85 = 143 CFM (realistically) .... And that is what I am working on as my solid starting / base line and the lowest possible numbers so I am not fudging ...
    From here on in, what ever (if any - and I know I can produce them) increase the Spyder has will be because of the increased inlet air flow efficiency ..... (as yet I have not even touched the stock exhaust ) ....
    I am just explaining - my back ground is aviation - aerodynamics - airflow and all that good stuff etc and lucky enough to have been able to both 'play' and instruct on this stuff for years - so I am really confident of being able to achieving something special here ... If not, it will have been fun trying ... I'll go look for a link I saw just the other day from Eventuri .... (who look to be a UK company that specialise in this stuff - obviously I am not the only believer ... and .... PS .... Just looking today so apparently are the US space agency NASA ) ... to what I am talking and thinking about ... In the mean time some great thoughts and tricks to come (promise) ..... Stay safe and please keep the input coming ...
    https://www.youtube.com/watch?v=kRuaLm_TT4o&t=9s (apologise for the length its 18 minutes plus ) .... and
    https://www.google.com.au/search?q=t...=1524490723898
    Jan 2018
    Australia
    .... Just saw this send part of the quote
    Just realised there was this second part to your prior response quote ... I am not overly concerned with going out side the current mapping for the ECU as I want to take the 'beast' in to Jason at Xtreme here on the Gold Coast to get the mapping tweaked in any case. I'll just let him work his magic after the exhaust goes on ...
    NorCal - Northbay
    That could work as long as the injectors/fuel pump can deliver what you need fuel wise without reaching an unsustainable/inefficient duty cycle rate....
    Chuck
    Jan 2018
    Australia
    Well its been a few weeks, but there's heaps of research going on and if anything everything has been getting harder along the way, with all sorts of evolving ideas ...
    Above all else and just as important to me if doing this is to 'do things right and do them neatly.'
    Current problems with my lower left leg prosthetic have given me the perfect timing and excuse to pull down a bunch of panels and start to really have a close look at whats happening as stock. Like anything mechanical, I need to know the starting point before I just head off blindly ... The more I have this bike the more I am truly impressed with the engineers employed to build it at BRP .... Everything is or has in my mind at least, been vary well thought out for fit, function and form ...
    So right now both sets of side panels are off the beast ... The Frunk and enclosed liner have been removed, as has the front under headlight combing shroud ... And so I spent a good couple of hours today assessing and just looking towards the quality of what is there ... all in an attempt to mindfully and genuinely improve that dreadedinflux of cool air.
    Please do not take this as being at all demeaning in the way it 'may' sound, but 'for the uninitiated' and those who have never ventured there ... The 'air-box' intake on the F3 is located just in front of where your left knee is positioned when riding ... But, just under that too is the hot air being omitted by the engine. So there in lies the quandary and area for any possible airflow improvement ... Why? Just because its there and I can!
    The actual open air intake to the air-box is a little over 75mm or 3" in diameter ... A huge thing that is directly located behind and inboard of the F3's EMU/ECU. Main problem there is, ... Just how to get the extra cool air flow up and into that air intake without impeding or restricting the existing airflow.
    Once again I say the engineers at BRP have done a pretty amazing job, but everything with regards mass production is impaired by the holly dollar! As it is designed it is a restricted area of a little over 30mm or just over 1 1/4" to the left main support brace and directly above the front 1/3rd of the engine to that main air duct, so to me that's another reason it can be improved ..
    Beginning to look at the science behind this, I know as we move forward the hot air is being cooled by forward air pushing it rearwards as we ride, but in reality it is very seldom we are doing 'highway' speeds to sweep away all that hot air for any real length of time ... So come on in cool air ... Just how to I get it there in an efficient way so it can best do its job? Particularly with-out cutting, chopping, sawing or inhibiting any of that adjacent fitment or design ..
    My current thoughts ...
    1) Possibly slightly (and stylishly) elevate the face of the hood of the frunk by an inch or so, so as to create an 'air dam' for a ram tube effect. Then also do incorporate the 'added yet removable' bodywork without drilling and screwing anything other than to the existing drilled holes and support areas of the hood frunk area.
    2) Supply 2 x Ram air catchments then duct from either side of about the area of the fog lights bringing that back possibly under pressure via that open air 3" intake ... which again is quite 'doable'
    3) And my least enthusiastic thought so far, is to access another forward inlet into the 'face' of the giant existing air box itself from about the area immediately behind the existing F3's grill ... could be under added pressure flow as well ... any other suggestions appreciated ...
    Jan 2018
    Australia
    The entire front of the F3-T tonight is all but totally stripped of nacelles and bodywork ... right back to the seating area .... I have to say I am stunned at the cavernous area that's hidden away immediately behind the grill ... I fully understand its been made as a captive area for the forward influx of air flow for the twin radiators, but gee wiz ... there has to be some potential there to be played with ...
    I was also amazed at the sweeping 'laid flat type oval shaped' sweeping pipe from the inlet air supply on that opposite left hand side of the bike ... again, I reckon there is a huge potential there ... I guess only time will tell ...
    Dec 2015
    Oakley Utah
    Default Interesting thread
    I probably won't do any of these mods, but I find the discussion fascinating. Particularly enjoy the back-and-forth between the 'try-it-and-see' approach and the strict engineering approach.
    Hi Trevor!
    2014 RTL Platinum
    Jan 2018
    Australia
    Hi Trevor!
    I really don't get how you can not 'try it to see' (as in proving a theory) to see if the theorem and maths aligns.
    Eg ... 'Oh I think a wheel will role along' ... No wait on, we won't 'try it to see' first before we go into production .... Who the hell would just chop into something all guns blazing without trying out the basis of the theoretical ?
    Apr 2015
    Green Bay, WI
    I agree--these fans would slow air intake---nothing rides for free...
    Darrell
    Default EXPECTATIONS VS. MONEY
    I've already stated my opinion of this sidecar thing ...... I'm curious as to the amount of money you think this is going to cost ...... If less than 6 figures, you are wasting your time ....... and since we are only allotted a certain amount - I think you would happier riding and enjoying life ..... Mike
    Apr 2015
    Green Bay, WI
    I see these all the time at the track aka NEVER...A windmill generates power from free air. The vehicle can't do it for free.
    Darrell
    Jan 2018
    Australia
    So much for that idea …
    youtube; cbGWgvJN1_8] youtube.com/watch?v=cbGWgvJN1_8[/video] … apparently not … ha ha ha … back to the drawing boards … Oh well … The ECU should be back from Monster early this week and that will be amazing no doubt!
    Apr 2013
    Michigan
    To reinforce what Hypureone said; I read a well written tech article (years ago--I'm sure the laws of physics haven't changed) on the efficiency of sport bike ram air systems. They instrumented the air pressure feeding into the air box from the test bike's factory ram air scoop. They got no pressurization at all until well over 100MPH! At around 160MPH they had a fair bit of pressurization, and estimated it was good for an additional 11HP over the factory rated static HP.
    If your objective is to duct additional cooling air into your radiator/oil cooler etc--that's pretty feasible. But if you're trying to pressurize your intake for additional HP--that's a Unicorn; unless you've got strap on rockets on your Spyder to get that aerodynamic brick up to 150+.
    You could always try several leaf blowers to pressurize your intake. If you do---be sure to video it and share!
    Apr 2015
    Green Bay, WI
    I've seen ram air extension intakes on the Hayabusa bike but I've never heard anyone brag about power increase.
    https://store.schnitzracing.com/carp...300r-hayabusa/
    A cold air intake would be nice but my ice cubes only last for 30 min or less :-(
    Darrell
