Page 18 of 22 FirstFirst ... 8141516171819202122 LastLast
Results 426 to 450 of 541
  1. #426
    Oct 2010
    Wisconsin Rapids
    The plug fits quite tight. I don't think it will vibrate loose.
  2. #427
    Houston
    You guys do know you can inspect the sprocket without removing anything or drilling holes right?
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  3. #428
    Glasgow, Scotland
    ........Aaaaaaand??
  4. #429
    Mar 2008
    Hesston, PA
    Default Front Sprocket part Numbers
    I am looking to purchase a spare front sprocket for my 2014 RTS...
    The BRP parts finder list the numbers as #705501986 as a 28T front sprocket...
    Is also see the 2015 RTS lists #705502137
    And the 2015 F3 as #705502134
    So my question is; Do all these different machines with the 1330 take a different 28T front sprocket or has just the part number changed???
  5. #430
    Dec 2009
    West Oz
    Quote Originally Posted by Black Pig View Post
    ........Aaaaaaand??
    ...........it's quick, easy and trouble-free to do so.
  6. #431
    Dec 2016
    Somewhere USA
    Why would you buy a spare sprocket when the failure rate is almost nothing (.001%).
    Don't get sucked into this very BS thread.
    Check for red rust every 5000 miles and have fun.
    Quote Originally Posted by larryd View Post
  7. #432
    Dec 2009
    West Oz
    Quote Originally Posted by SpyderF3-s View Post
    The new dealer said that the shaft should have been replaced the first time because the sprocket will not fit tight and will move on the sprocket when accelerating or slowing down causing the sprocket to wear faster. This is a picture what it looks like this time.
    BS thread eh? Low numbers? Yes, but better to have a spare on hand than awaiting the arrival of a new one if it unexpectedly happens to you, unlike the unlucky owner above who's machine was up for a major rebuild after the second failure in short order.
  8. #433
    Harrington, Australia
    Yeah, but that’s only if you’ve already got it up on a lift/hoist, JC. If it’s on the ground and you are about to head out and you think “oooooops, it’s been a while since I checked my front sprocket”, it would be just as quick to take the cover off as it would be to get the bike lift out....
    HeliBars Handlebars
    Kenda Kanine rear.
  9. #434
    Houston
    If you don't mind kneeling and getting your face close to the ground, you can do it in the driveway looking along the bottom of the belt up toward the pulley and holding a flashlight on the pulley from below. Admittedly it is much easier to see from below with the bike on a lift.
  10. #435
    Quote Originally Posted by Road-Kill View Post
    It’s called insurance, Road-Kill. Some people buy insurance and some don’t. That’s their call. I have never had a puncture, but guess what......I carry a tyre repair kit and pump with me.....insurance in case I get a puncture in the middle of nowhere. A bad sprocket would be even more disabling.
    BS thread? Really? Are you saying that the claim that these sprockets fail is BS? .....or are you calling BS on those who have made the call to carry a spare for their particular circumstances.
    HeliBars Handlebars
    Kenda Kanine rear.
  11. #436
    Dec 2016
    Somewhere USA
    Default .006% is nothing to get into a twist over
    I like to keep my life real.
    I'm calling this thread for what it is.....fear mongering BS.
    I'm also saying that with a very minor failure rate why buy something that will statistically never fail.
    Remember.........the failure rate is BELOW 1%.
    You will suffer a better chance of constipation or its evil brother diarrhea while being chased by Bigfoot.
  12. #437
    United States
    So, Roadkill, everyone is supposed to listen to you? I think the only reason you are slamming this thread that has helped numerous ryders catch theirs before they grenaded is to get it deleted. I ain't going to bite, and if I was monitoring this site, I would caution you to quit slamming people or topics that help someone, regardless how many. One thing about this thread and others is that they are a database for the future for anyone.
    I think that if you don't have anything positive and constructive to say, you need to just not say anything. Age will teach you that.
  13. #438
    Aug 2015
    Northern California-Sierra Mountains
    Default Sprocket BS?
    Just replaced the front sprocket on both of our 2015 F3S with a little over 14,000 mi. on both bikes.
    I did the work on my wife’s bike and there was a considerable amount of rust AND the sprocket was in bad repair. My bike had a moderate amount of rust, but the splines on the sprocket were were really worn through according to the mechanic that replace it. Although I did not see the sprocket on my bike, I trust this mechanic.
    Thanks to the dialogue on this site, I was able to catch a potential problem. NOT BS
    Also, both sprockets were replace with 660 loctite.
  14. #439
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Peteoz: My "stupid" comment was geared for those who trying to balloon this 1% issue. (actually less then 1%)
    cmarsala: Less then 1% is a nothing burger and very unlikely to initiate a recall.
    stebrock: Anything less then 1,000 is still less then 1% so 60-100-999 is still LESS THEN 1%.
    That 60 figure also includes people only with "rust" and not an actual failure making this argument even more pointless.
    Get a grip people.
    Rust is not a cause for great concern on an unprotected weathered gear like the front sprocket. (it happens on car rotors!)
    If you see "rust" it might be a good time to have a "looksee".
    This thread tells me to do nothing but keep an eye on my bike...........LIKE I'M SUPPOSED TO DO
    On a last note...I'm reading that some are playing with their belt tension and probably are the 60 with sprocket failure and thus rust.
    Don't play genius, you're not. BRP specs are there for a reason and why these machines are well built.
    In response to your post I decided to remove the plastic cover and have a "looksee". (3-5mm hex bolts)(see picture)
    Yes I have "red dust". I'm over 18,000 miles on my Spyder that I bought new this year.....trouble free.
    Can I remove the one 16mm bolt without removing the belt to have an even closer "looksee"?
    I'm making an appointment with my dealer tomorrow for the 18,000 mile service, I'll leave the cover off and ask his opinion as well.
    If I do have sprocket wear.............will BRP replace it BEFORE it fails?
    I'm not admitting that I am wrong.....yet.
    I made an appointment with my dealer for next Thursday for both my 18,000+ mile service and the evil "red dust".
    This still could be a nothing burger so I'm not admitting I was wrong.....yet.
    So until I'm told my front sprocket is grinding you can all blow it out your *sses.
    I just got home from my dealer. He told me my front sprocket is shot and will need replacement. He never ordered a new sprocket when I made the appointment 2 weeks ago. I do not know if not ordering this was a BRP or dealer mistake. Now I have to wait till the new part comes in, make an appointment and go back. I feel this was an unnecessary and easily correctable issue on both BRP and my dealer. They know as my dealer indicated this is a problem so the dealerships should have at least one sprocket in stock ready to go......but they do not.
    Road-Kill, these are just a few of your many less than helpfull posts to this thread.
    Your posts on this thread drive me nuts(probably your intention)! Your one of the less than 1%(your number) that this thread has helped!!! How can you possibly continue to criticize and call this tread BS? Please stop posting on this thread and let it help the people who really care!
    2020 RT Limited , Petrol Blue
  15. #440
    Florida
    Michaelscs, It seems that this individual, Road-Kill, likes to provide his opinions on a frequent basis. I think we are all grown up enough to know that when people start bantering around statistics that they have no way of ascertaining that most of just ignore the more ignorant pronouncements. However, Road-Kill, like all of us on this forum should have the right to express his opinions even if they lack credible evidence.
    One thing that is true about Forums that I have noticed over the years is that there are a few people reporting problems that do tend to get magnified possibly beyond the proportions of the actual problems. If we had everyone who has a Spyder weigh in and determine if they have had problems with the "red dust" issue, then we would know the true extent of the problem. However, it is still useful for fellow posters to share their experiences and observations without being subjected to too much negativity. Maybe Road-Kill can consider this in future posts and still get his point across without seeming to demean anyone?
  16. #441
    Dec 2009
    West Oz
    The best substitute for brains is....................silence.
  17. #442
    Dec 2016
    Somewhere USA
    Default A failure rate of .001% is a big nothing burger on a great machine
    I had "red dust" and found it prior to failure because of this thread.
    Even with that stated I still think this issue is a big nothing burger.
    There is no citation on how many bikes suffer(ed) from this issue.
    We can "guess" it at a few hundred bikes but that is still way under 1%.
    Of that few hundred "red dusted" bikes maybe a few had epic failure on the road requiring a tow.(making it 001%?)
    My point....I don't want someone thinking the bike has a fatal flaw and not understand were the decimal point is located.
    BTW...Can Am REPLACED my red dusted front sprocket and it was a stress free ordeal.
    The riding season is kicking in and I plan on doing another 20,000 miles this year and not gonna worry about "red dust".
    Quote Originally Posted by Michaelscs View Post
  18. #443
    United States
    This all boils down to one thing;
    Check your front sprocket at the beginning of the season and at every oil change. More often if you feel the need to do so. If red rust is there, contact the dealer.
  19. #444
    Houston
    Has anyone here actually changed out one of the pulleys themselves? Mine has a bit of red dust on it but out of warranty. Decided to just change it out rather than wait for it to fail. I removed the bolt, removed the belt but darned if I could get the pulley off. It seems to be rusted in place. I tried a pulley puller but there is not much room around the edge of the pulley and did not want to damage it beyond use. There are no threaded holes in the face of the pulley so a jaw type puller was all I could think of. It refused to come loose. I gave up, installed and torqued a new bolt and washer.
    How does one remove this pulley, there is nothing in the service manual as its not a press fit, its supposed to come off pretty easily. Do I just wait for the rust to progress and the splines to fail then it will come off when loose?
    I have spoken to a few Spyder techs I know and most come off without too much persuasion. Some do not and things can get 'bad' Seems there may be more wrong with the design than just the lack of proper lubrication on the splines.
  20. #445
    SoFlo
    i suspect you read the info and saw the photos I posted on Facebook a while back. On our 2014 the front pulley was lubricated at first assembly. No red dust, no wear and easily slid off with hand pressure.
    Fretting corrosion is an unpredictable event. Obviously you had the drive belt removed, and with that the pulley is a slip fit.
    My suggestion would be to add oil to the splines with the bolt and washer removed. Fire the engine and roll forward and aft, working the lube into the now excessive clearance of the splined joint.
    In theory, the pulley slides off easily, however worn splines may snag that. It could also require additional rotating back and forth as you draw the pulley off the shaft.
  21. #446
    Glasgow, Scotland
    Does this look okay to you guys?
    Just looks like surface rust to me.. No sign of martian dust..
  22. #447
    United States
    I think you are right. Usually will fill in the holes.
    This was sent me a couple days ago by a ryder. He is getting it replaced.
  23. #448
    Dec 2014
    NY
    Quote Originally Posted by Roadster Renovations View Post
    This is my sprocket after 10,500 miles. Guess it's time to call my original dealer, since the closer one in Stamford, CT never heard of this problem. I'll have them install a new belt that I got from Amazon, since they were telling me that mine was shot the last time I was there. Any suggestions on how to handle them if they put up a stink?
  24. #449
    United States
    Quote Originally Posted by johnny pop View Post
    Yep, yours got bit. I wouldn't tell them where you got the belt (has to be a BRP one anyway). I would just tell them you have a spare belt and would like it put on. Also, you might get them to warranty the belt. Ryder on FB just had his sprocket done and the dealer did the belt also.
  25. #450
    Dec 2014
    NY
    Is there a service bulletin # that I could quote, since this is the first they are hearing of it as well?
