Results 26 to 50 of 54
Thread: RT GAUGES GONE
  1. #26
    Dec 2016
    Iowa
    Can anybody sow what the digital displays for temp and fuel look like on the main screen after removing the analog gauges?
    2016 RT Limited , Black
  2. #27
    Nov 2013
    Central Texas
    Quote Originally Posted by Marr View Post
    I LIKE IT!!
  3. #28
    Phoenix
    Default replaced with 12 v and a usb dual port
    I started here at this website then decided to see what blue sea sold them for on their website then shopped the web for them after I got a part number...but bought the bevel and screws from this guy...http://spyderstore.com/index.php?rou...tegory&path=61
    http://spyderstore.com/image/cache/c...11-500x500.jpg
    https://www.facebook.com/photo.php?f...2042634&type=3
  4. #29
    Phoenix
    Default Dash after gages are taken out
    Quote Originally Posted by Tyris View Post
  5. #30
    Jul 2017
    Massachusetts
    Also, BRP does have the caps if you're looking for something a little more stock: BRP gauge cap #705003421
    Thanks spyderbirds for the part number! It's come in handy!
    2017 Can-Am Spyder RT
  6. #31
    Active Member duke50's Avatar
    May 2014
    IL
    Default Gauges
    I also have a 14 Rt, no plans to change mine out, they look and work fine.
  7. #32
    Mar 2015
    Tacoma WA.
    Default Oil temp gage And intake Vacuum gage
    Quote Originally Posted by oldguyinCT View Post
    Well, I finally got tired of the wildly inaccurate analog gas gauge, and figured that if I was going to disable it I would do the same with the temp gauge. To my surprise and annoyance, the gas gauge "remembered" what the fuel level was, and the needle stayed in that same position as before it was disabled. I kept looking at it and thinking, "I'm gonna have to get gas soon". Then I would remember that it was disabled, look at my mileage, and the bar graph on the center screen for the actual fuel level. So I decided to take them out. I went to a local boat dealer and had them order two 2" Euro Blanks (that's what the manufacturer calls them) made by Faria Marine Instruments. Took out the gauges, and put in the blanks with a small bead of black silicone around the bezel to keep water out. So here is the finished product at a cost of $35.00 and 20 minutes of labor. I like the way it looks. Now I have to retrain myself to look at the center screen, not at the - nonexistent - gauges.
    Those two holes would make a nice home for oil temp and intake vacuum gauges, and the best thing is you would barely have to "break into" the electrical system to install them. I wonder if it's doable (sensors, installation)?
    2017 F3-S Daytona , Yellow and black
  8. #33
    Nov 2016
    Upstate NY
    Quote Originally Posted by TerryTheSpyderRyder View Post
    A voltmeter is MUCH more useful than an intake vacuum gauge.
  9. #34
    May 2017
    Perry Hall, Md
    Quote Originally Posted by Joel The Biker View Post
    Agree. For my 2012 RTS I went with voltmeter and USB outlets for GPS/phone. Straightforward install.
    2011 RT , Yes Blue
  10. #35
    Nov 2013
    Central Texas
    I can't believe that this thread is almost two years old and still going.
  11. #36
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Well King Herald ( your avatar) I just switched out my gauges last weekend. I think it keeps coming up as those of us that are getting to the party late are finding neat farcles to do.
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
  12. #37
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Quote Originally Posted by bcer960 View Post
    I have a volt gauge and a really nice analog clock which is much easier than the tiny little on the digital gauge. USB ports fit real nice in between the switches below the handle bars
    2022 RT Limited , Silver w/ Black and Purple accents
  13. #38
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by campermac View Post
    The small clock on the dash was the reason I sought out this thread.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
  14. #39
    Danbury Connecticut
    Geez Dwight,
    I read the title to this thread, and I thought you were trying to come up with a clever way of saying you sold your Spyder.
    Can you ride yet ?
    IBA #47122
    2020 RT Limited Asphalt Grey
  15. #40
    Dec 2016
    Iowa
    What clock did you find?
  16. #41
    Nov 2013
    Central Texas
    Geez Dwight,
    Can you ride yet ?
    Yep, I can ride once I get it back from Arctic Adventures. It started throwing codes like crazy, and they have had it for 18 days so far meticulously going through it to try and get all of the kinks worked out once and for all. I'm also having them do some scheduled maintenance while they have it. Today would be a great riding day, but I'm gonna do yard work instead.
  17. #42
    Active Member El Dorado's Avatar
    Jun 2017
    NorCal
    NICE
    2015 RTS
    Replaced Catalytic Converter with Lamonster Pipe
    Rivco Flag Holders
    Tricled wideview mirrors
    Garage door opener
    Zumo GPS
    Ultimate seat
    F4 windshield with vent
    Doc's belt damper
    Value Accessories RAM mount
    Baja Ron sway bar and Links
  18. #43
    Jul 2018
    Camrose Alberta
    Default gauge
    I found the reason anaulog gauge dont work right is because speaker magnet screw them up on my 2012 RT.
  19. #44
    Jun 2015
    Hampton Roads, VA
    Default Magic Mirrors?
    Quote Originally Posted by rookieryder View Post
    Ok, so help me out on the "wildly inaccurate" comment. Was it overestimating how much gas you had or underestimating?
    And is it possible to show the digital gas gauge without disconnecting the analog?
    Many people complain that Magic Mirrors magnets influence them.
  20. #45
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Default I went with
    Digital volt gauge & digital clock.
    Ride safe!
    2022 Sea-T0-Sky
  21. #46
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by taxmyzer View Post
    same
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
  22. #47
    Jul 2018
    Camrose Alberta
    Quote Originally Posted by stevencovert View Post
    that could
    be to as I have them to
  23. #48
    Faribault, MN
    There have been threads posted about how to flip one or more of the mirror mount magnets to correct this. Though I find it's just easier and better to have removed the gauges and plugged the holes reverting back to the digital dash gauges.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  24. #49
    Feb 2016
    HAWTHORNE nj
    I had installed a volt meter on the left side. and I installed a clock on the other. The clock does not work any more and so I want to plug the 2inch hole, I have power outlets installed by providence accessories. any ideas on what I can put there that would be useful guys.....
  25. #50
    Dec 2015
    Oakley Utah
    Nice clean solution.
    2014 RTL Platinum
