Results 1 to 12 of 12
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Default Another question about the 2018 dashboard, anyone knows how to access the tripmeter
    As anyone with a 2018 figured out how to access the tripmeter panel or is that feature gone?
    I've looked at the Stats screen but don't see any data about trip distance.
    2018 RT LTD , Black
    Suggest you look at pages 30-33 of your operator's guide. I admit the coverage appears to be minimal but it does say the trip meter is in the left lateral display and there must be a way to toggle through the options with the joystick.
    Active Member krazykat's Avatar
    Feb 2013
    Cape Coral, Florida
    When in the stats screen, just joystick left and it will move to one trip meter and joystick left again to the second trip meter. You can then hold joystick down and it will reset trip meter to 0.
    QUOTE=ottawa-rider;1354305]As anyone with a 2018 figured out how to access the tripmeter panel or is that feature gone?
    I've looked at the Stats screen but don't see any data about trip distance.[/QUOTE]
    2014 Cognac RT Limited #185 (destroyed in T-Bone wreck 3/21/2014)
    2014 Cognac RT Limited #5333 (replacement 5/16/2014)
    2018 Champagne RT Limited #1002 (traded 1/31/2018)
    Mar 2018
    St. Cloud Florida
    Quote Originally Posted by ottawa-rider View Post
    Go to stat screen if you look at the very top of the displythere3 very smalltrip switch indicatorsA B Total toggle up to hi light or toggle l or R then toggle up to display push the toggle switch in and hold it will zero out the trip meter
    It'll take a while to get used to the new procedures; it'll come to you!
    Mar 2018
    Ontario ,way up north
    I tried that and every time i push the enter button it will go back to previous screen. What am i doing wrong .
    2018 RTL , dark blue
    Aug 2009
    Cedar Park, TX
    Default Toggle display
    Quote Originally Posted by stmike 1800 View Post
    Look at the right side of the trip display and you see toggle functions. Down will zero the selected display a or b
    Aug 2013
    SF Bay Area
    You can move the joystick IN and it will be a select or return to previous screen. If you push/hold the joystick DOWN you can make a selection, holding it down will clear the stats.
    Here is a video on how to set the radio presets.
    2021 F3 Ltd , Magna Red
    Jul 2011
    Mitchell, Ontario, Canada
    Go to the stats/trip screen.
    The diagram on the far right of the right screen tells you what the joystick will do.
    Right and left are triangle arrows. Allowing you to change between Trip A, Trip B or Total screens.
    Down is a 0.0 showing that you can zero out the trip meter you are on.
    Up is a toggle switch symbol. That allows you to chose which meter is active on the left screen. so visible all the time. Only one at a time allowed. Notice on the right screen the Trip A is toggled on. On the left screen the trip symbol shows A and the mileage for Trip A is shown.
    The center symbol is a little house. That means home. Pressing in on the joystick will take you out of that screen.
    Mar 2018
    With "A" lite hold the joy stick in and towards the 0 and the trip will 0.
    Aug 2013
    SF Bay Area
    No you push the joystick down. If you push it IN you'll go back to previous screen. The joystick has 4 moves. UP, Down, Left & right and IN. Holding it in a position does more in some screens.
    Mar 2018
    I likely did not explain it right ,but yes it does work .
