Rear shock question
220 overweight 60 year old man realizes rear shock on new 2015 F3 is way too stiff. The shock is too stiff, not the man, well maybe the man too....but I digress. What are options? For the shock again, not the man. Thanks! Dan
Elka
Went with an ELKA stage 2 on Cindy's bike and she loves it .
I put a 2 up on mine it's ok I think the Elka would be better but you know would a, could a, should a.
Pricey but worth it on the Elka just my 2 cents.
Too stiff? Most people find the original shock on the 2015 F3 too soft. Was it changed or is it bottoming out?
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Tighten the spring first. Check the air pressure, you may not have any air in it. It's too soft, not too stiff. Tom
2020 Petrol Blue Metallic RTL
On second thought, the spring may not be adjustable. Tom
and it might not have air either
the OP said '15 F3 but his profile shows '15 RT??
2 STIFF ?
i'm with Highwayman on this 1....
i'm 6'2", 260 lbs... i found the OEM way too soft... i bottomed out a number of times, and switched to the 2UP shock, and found it to be a much more comfortable ride... it dampens bumpy roads, and no more bottoming-out....
if you have a pal with a different shock, ask if you can ride his/hers a couple miles and see if that helps you....
Dan P
SPYD3R
both now
Have one of each now.
