Results 1 to 3 of 3
    Phoenix
    Default screws air filter rts 2016
    What size short angle torx do I use to remove the air filter?
    what does m6x16 mean?
    I use a 3/8 drive T30 torx bit with a 6" extension for two of the bolts and no extension for the third. It's obvious which bolt needs only ratchet and bit. M6 is the size of the thread diameter and 16 is length of the bolt in mm. The bolts on my '14 remain in the cap when you remove it. There is an orientation arrow on the cap so you can't install it improperly.
    Phoenix
    Default Thanks
    thanks
