Results 1 to 7 of 7
    Glasgow, Scotland
    Default Anyone know what the 'Load Sheeding' circuit/system does?
    I'm looking to get rid of the stock 'pansy' horn with something a bit more appropriate, however, the horn shares a fuse with the 'Load Shedding' thingummy.
    Anyone know what it does or what it's load is so I don't overburden the fuse?
    Cheers all.
    Apr 2010
    Thorn Hill, TN
    Contact Reggy at TricLed, he has an F3 air horn that is hidden.
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    I would get a Motorcycle Air horn it comes with a relay
    Just wire it up as per instructions and you shoul be good to go
    see:-
    https://rover.ebay.com/rover/0/0/0?m...2F282363851101
    Othes are avaiable
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Glasgow, Scotland
    I was thinking about that but I do have a twin horn unit here that is much louder than stock (about 130db) and it only draws 8 amps (only.. HAH!), so if the stock horn is only a couple either side it'll save a whole lot of messing about with additional wiring.
    Trying to find the easier route 's'all.
    Mar 2017
    Quote Originally Posted by Black Pig View Post
    If they draw 8 amps, you will need a second relay and I would feed the hot of the new horns +12v straight from the battery. Too, the stock system relay is set up to switch the ground terminal of the stock horn while the +12v is always hot even with the key off. Look to the circuit I have here. Much more info and horny lights too found >HERE<.
    Mod Maniac
    May 2008
    North Texas
    Quote Originally Posted by Rattlebars View Post
    If they draw 8 amps... >HERE<.
    Hi, Chet! Been a while.
    Durham,Maine
    I was in Harbor Freight this weekend and I hand a Badboy Horn in my hand reading the info on the package and was wondering if I could make it fit under the skirt of my rt!
    2012 RTL , Pearl
