HEADS UP DISPLAY - My newest mod
Added a GPS heads up display speedometer today. Nice and bright and easy to read accurate GPS speed now! You can see the speed projected on the windshield in the photos. Please be aware, it is not waterproof and should be removed for washing or in rain. Mine is held on dash with velcro, so it is easy to remove.
What HUD display system did you install? Does/can it display more than Speed?
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
More info on components please.
Nice GPS! Thanks for the pictures.
Also AWESOME looking painted dashboard! Gee I wonder where you found that idea the painted dashboard. I like your painted dashboard.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
I bought the HUD on ebay for $25. It shows speed and has a compass. Simple plug-n-play.
I have HUD in my BMW, Obviously, I love it. Does this one also show the GPS directions? I see that there appear to be some of those on Ebay, didn't realize they were so cheap. I'm getting one ASAP and for my van too.
Originally Posted by Chupaca
Looks great and a nice feature for those with the touring windshields... would have to put my chin on the center panel to enjoy the feature
Actually you would be able to see it fine. I have a shorty windscreen and it is easily visible with the windscreen in the up or down position. Just depends where you place it on the dash.
This one only shows speed and compass direction. It uses satellites to calculate speed. It does not give gps directionns. Speed can be calibrated if necessary. It also has auto brightness and overspeed alarm.
Specifics, please...
Would you mind posting a little more information about the equipment you bought on eBay for around $25? I'd be REALLY interested in part number manufacturer, etc.
Thanks in advance!
B
2017 Can-Am Spyder RT
What are these?
Joel, since I don't know what all you have on your bike, I'm a bit confused and modified one of your pictures with a couple of colored ovals.
What are the two items circled in Yellow and Light Blue in this picture.
And I also have to agree with Deanna777, your color matching dash and carbon fiber inserts really do make your dash "POP". Nicely done.
Safe Rides,
IBA 70020 |
The radar detector is in the yellow circle and the heads-up display projector is in the blue circle.
Here is the link to the Heads up display I found on ebay for $25
https://www.ebay.com/itm/Universal-C...72.m2749.l2649
Works great!
Took the spyder for a nice long ride and I love the heads up display. Works great! Its nice having the speed projected on the windshield near my line of sight. Its not distracting at all and is easy to read in bright sun. Highly recommended. I should also mention that it has auto brightness and dims at night.
Hi Joel,
Re: Power through Vehicle Cigarette Outlet Jack
So how did you power your unit?
Jerry Baumchen
It is powered through the cigarette lighter plug on my dash where the fuel gauge used to be. You can see it in the picture.
Oh I wish....
As you can see from my signature picture I have an RS with a bit bigger screen with flip...
Joel, thanks for the PM and the follow-up to your original post!
I'm buying one based on your recommendation. Again, thanks!
I'm a little late getting to this post (a whole month) but I am really impressed with this.
I got to play with this stuff in its infancy 30 odd years or so ago with its Military applications ... To me this is great ... its functional and not just a bunch of tizzy BS ... I don't have a problem with my display on the 2017 3-T, but this, this is something else again and to me well worth the investment ... NO BS and practical ... What's the Brand and Model of the HUDs if you don't mind me asking .. Thanks again for the post ... Greg S ...
PS ... apologies for the edit ... again having a closer look at the original post .... looks to be a tinted windscreen you have there .... Back in the days I am referring to aircraft didn't have (and still mostly don't) have tinted windscreens, but still looks very impressive .... Looks like I'll have to go 'tint' the inside of my windscreen on the F3-T ... (... easy and cheap enough to do ! .. Thanks again!)
its a no-name brand HUD, but works flawlessly. It calculates your speed by GPS signal and you can calibrate it to read your exact speed. I compared it to my GPS navigation speed and adjusted it to read the same. The speedo on the spyder tends to read a bit fast, so this HUD is nice to show my true speed without having to take my eyes off the road. It does come with a piece of reflective film you can put on the windscreen, but you most likely wont need it, even with a clear shield. Try without first.
well that's just great. now the cops can just read how fast I am going without their radar gun
j/k .... nice farkel
You can do this with your phone and an APP called Sygic GPS. Works in the car but have not tried it on the Spyder.
Bob
