What are these holes for?
Looks like your missing a bracket or support that goes in that area.??
But then I could be way off.
Are you missing the belt guard maybe?
Guard
![Quote](images/misc/quote_icon.png) Originally Posted by Mahaflac
You are missing the plastic belt guard. #40 in the pic. that is for my 2011 RS, but should be the same. http://www.2wheelpros.com/oem-parts/...7213-part.html. Make sure you look it up to make sure it is the same. If you scroll down in that link, it shows all the diagrams for the years and bikes that part number fits.
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
BRP Passenger armrests
Baja Ron Anti sway bar
Lamonster's upgraded BRP vibration damper.
Thanks. That is exactly what it was. Ordered one and is on its way.
You are very welcome.
2019 RTL
Farkles
BRP Comfort Seat.
Foam Grips
Lidlox
There you have it....
Gotta love the quickies...question, some answers and solution on the way... isn't this place the best....
SpyderLovers Sponsor
They were installed with capnuts which would vibrate loose.
Check up around the front sprocket to make sure it isn't lodged up there, when they fall off that's where the belt will send it.
Belt Guard
1+ on the belt guard bolts.
My guard came loose and was flopping around the belt.
Get longer bolts and use lock washers and decent nuts to secure everything.
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
![](https://www.spyderlovers.com/forums/maps/map.png?states=CO.NV.HI.NM.UT.WY.IA.MN.IL.IN.OH.PA.NY.NE.CA.OR.WA.MD.VA.WV.KY.MO.MI.SD)
You solved the last one so fast, I thought I would throw another one at you. Does anything belong in this hole. Not sure why the pic is turning sideways
Not on my 2014 ST-L.
Ride Safe,
Roger
![](signaturepics/sigpic13984_7.gif) 2014 ST-L
The Lower Belt guard bolt
This would be for the top bolt in the belt guard. The other holes for this would have had bolts with capnuts.
thanks
Kinda what I was thinking, but wasn’t sure.
Glad your getting to know sorry if seemed ruff at first.
Miles of smiles ahead![yes!](images/smilies/pepper2.gif) ![yes!](images/smilies/pepper2.gif) get to meet & learn more at events when you can it will help hone the farkle list & get a first person view if not all out demonstion.
If you look at a parts diagram, I think you will see that the upper belt guard has no forward bolt, and the forward bolt on the lower belt guard is attached in a different location. I have no idea what that threaded hole is for. Probably for something when that frame is used for another model. The RT-S and RT-L. You have an ST.
Roger
That hole is for the rod/linkage going to the air ride switch.
