Results 1 to 24 of 24
Thread: Motorcycle Lift
    Sep 2016
    LI NY
    Cool Motorcycle Lift
    2010 RTSM5 , stock Stock Silver
    Default I'm sure....
    And they will chime in. I have the other model and it works well for me. Mine is from Sear's but the the same set up...
    Mar 2013
    Marion, Arkansas
    I also have the Sears version of the harbor freight one. They all work fine on the Spyder.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Active Member Navvet's Avatar
    Apr 2016
    NC
    I'm not to proud to say, have it and it works like a champ.
    I also use it on my Goldwing.
    2013 F6B
    2016 F3 Ltd
    2016 F3 LTD , Triple Black
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    I have one as well, not the greatest engineering, some really cheap parts, but it works fine once you get past those issues. Now would I buy it again, probably not. At the very least I would probably upgrade to their aluminum version, it looked much better made and in the long run, the price difference would be long forgotten.
    Bob
    2010 RT SE5 , Black
    Faribault, MN
    Used regularly on my Spyder RT Limited, even made a wood platform to help raise the Spyder high enough (With jack stands) to change my sway bar. Has worked great!
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2016
    Akron,Ohio
    I use J&S jack with Spyder adapter!!
    Faribault, MN
    RussRT, Your adapter cost more than my lift! Thanks for pointing that out. I spent the $600+ bucks the J&S lift costs on trips last year. I could've saved that and bought a new lift every year for the next 7 or so years, but the $80 lift I bought last year still works....<G>
    BUT the OP was asking about the HF Pittsburgh lift, not what lift everyone uses.
    Sorry, I couldn't resist.
    Safe Rides,
    IBA 70020
    May 2017
    Mesa, Arid-Zone-A
    I have one. It is a little tight getting it under the bike so I routinely run the front wheels onto 2X10s before putting the lift in place. Works just fine.
    Semper Fi
    Jul 2017
    sarasota, fl
    looked at the Harbor freight version of this one the other day. Almost double the cost of the red one but very cool looking.
    The arms that go under the bike are a bit shorter than those on the red lift.
    How do you like it?
    Easy to get under the Spyder?
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I have and use the HF lift. Works like a champ. I will say this though, for our 11 RTS, we have web boards on and it keeps from getting centered on the Spyder. So to fix this I jack the Spyder up and then use jackstands under it.
    Just so folk with the older version with the web boards know, that you can get up under there and centered with them installed.
    I also have the ramps from HF and use it to jack up the spyder and use the ramps to change the oil, that way I can just drive off and don't have to leave it up teetering around.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Zip View Post
    I have an old HF lift like that only mine is yellow. I bought back in 2008 for my Royal Star Tour Deluxe,it works well on the lift action but the let down is very abrupt. I still have it and still use it on the Spyder.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Faribault, MN
    For the folks having to drive up on 2x's to get the HF lift under their Spyder, have you checked the rear air bag pressure? My '13 needed the 2x's until I upped the airbag pressure from approx 20lbs to 50lbs. Still rides great and fits over the lift every time.
    Safe Rides,
    IBA 70020
    Apr 2011
    GREENVILLE, SC
    Default yup
    yup.....
    had mine for about 8 yrs now... just used it the other day on my F3....
    the silver paint must be expensive.... mine is yellow, and only cost me $49.....
    also use it for my John Deere.... very handy tool....
    Dan P
    SPYD3R
    Mar 2016
    Akron,Ohio
    DGoebel. I find your post to be inappropriate! What does your financial lesson have to do with the OP question. I did not pay $600.00 for my
    jack and adapter. You really should know what you are talking about before you act like an *******!! I couldn’t resist!!!
    Jan 2015
    southern WI
    yup, I have one and it works great!
    2016 RTS , Pearl White
    May 2010
    Knob Noster, MO.
    Thanks for this post. I was thinking about getting the J & S, but for the little I would use a jack looks like I'll be going to Harbor Freight.
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by canamjhb View Post
    I do the same thing. Mike
    Jul 2017
    Massachusetts
    Default I use the HF jack you mentioned
    I ride the Spyder up on ramps first sometimes, or I jack it up and use stands, but either way it works just fine!
    2017 Can-Am Spyder RT
    Jun 2017
    Hanover Ont Canada
    I just bought the exact same jack as you have today. How do you position the jack under the bike to get at the engine oil drain plug without it being in your way. I need a oil pan under neath to catch the oil.
    Faribault, MN
    RookieSpyder (One day you're gonna outgrow that username...<G>)
    I push the jack under the spyder so the back rail of the lift is under the rear end of the center rail. Lamonster has a blog showing that where the rearward rail lines up with the front peg/footboard support. The safety release bar just barely touches the lower deflector when I do this.
    Once I jack the Spyder I place 3 ton jack stands under the front A Arms as close to the wheels as possible, and under the rear shock mount. My jack stands have the rubber caps to protect the bikes finish. Once the spyder is solid on the jack stands, I lower and remove the lift. Then I do the oil change using standard oil pans. I do have one of the FloTool 16 quart oil pan collectors. So I collect my used oil over several changes before recycling it at the local WalMart.
    Last edited by DGoebel; 04-01-2018 at 06:39 PM. Reason: Added Lamonster Video link
    Safe Rides,
    IBA 70020
    wisconsin
    I use one of these lifts. Works well enough, except you can't go from the front end under the frunk. So have to place it from the side, close to the front wheels to lift it for tire changes and to get it close enough to C.G. so it will balance good enough. Mac
    Faribault, MN
    Mad Mac, not sure why you'd want to lift it from the front, but you might check out lamonster's blog on lifting a Spyder (linked above) though i did use the same HF jack to lift off my Frunk when I needed to, AFTER the Spyder was up on Jack stands.
    Safe Rides,
    IBA 70020
    wisconsin
    I d/n want to lift it by the frunk, I was hoping by going from the front of the bike, I could balance it better. But it works out OK by going from the side, and I can stabilize it enough to do front or rear tire(s) with just the jack ( as long as the grand kids aren't around!). Mac
